B050-000
B050-000
    TRIPPLITE
    REMOTE ACCESS UNIT IP FOR KVM
B050-000 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States KVM Switch Accessories - IP Remote Access Unit MODEL NUMBER: B050-000 Highlights ● Remotely control your servers via LAN, WAN, or the Internet ● Works with most KVM switches ● Compact and Lightweight takes up no rack-space System Requirements ● PS/2 KVM Switch ● Internet Explorer 5.0 or higher ● Java enabled web browser Package Includes Description Tripp Lite's B050-000, IP Remote Access Unit, offers convenient and economic remote KVM access and control via LAN or Internet. It captures, digitizes, and compresses video data and transmits them, with keyboard and mouse signals, to and from a remote computer; work from anywhere in the office, remote locations, or from home! The B050-000 provides a non-intrusive solution for both remote access and control. The remote access and control software runs on its embedded processors only, but not on mission-critical servers, so that there is no interference with server operation or even impact on the network performance. The B050-000 may be accessed using a standard Java enabled web browser. You may use the HTTP protocol, or, a secure encrypted connection via HTTPS. Just enter the configured IP address of the B050000 into your web browser. There is only one user who has unrestricted access to all of the B050-000 features. The unit also features Lightweight Directory Access Protocol ( LDAP ) support, an application protocol for querying and modifying directory services running over TCP/IP. Features ● KVM access (keyboard, video, mouse) over IP or analog telephone line ● Works with Microsoft Internet Explorer 5.0 or higher ● Senses video resolution automatically for the best possible screen capture ● High-Performance mouse tracking and synchronization ● Features 256-bit SSL encrypted security ● Additional port to connect a local user console for direct analog access to the KVM switch ● Flash - upgradeable firmware ● Supports SNMP and LDAP ● Compact size: 3.75"L x 1"H x 2.75"H Specifications OVERVIEW 1/2 ● 1 - B050-000 Base unit w/CDROM ● 1 - External Power supply ● 2 - KVM cable kits ● 1 - Null Modem Cable ● 1 - Quick Start Guide ● 1 - Owner's Manual CD 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332121530 Accessory Type Remote Control Module Accessory Class KVM Switch Accessories POWER AC Adapter Input: 100-240V, 50/60Hz, 0.2A Output: 5V, 1.6A PHYSICAL Shipping Dimensions (hwd / in.) 4.00 x 9.50 x 15.00 Shipping Dimensions (hwd / cm) 10.16 x 24.13 x 38.10 Shipping Weight (lbs.) 4.60 Shipping Weight (kg) 2.09 CONNECTIONS Included KVM Cable (Equipment Side) - Connector 1 HD15 (Male) Included KVM Cable (Equipment Side) - Connector 2 (x2) MiniDIN6 (Male) Included KVM Cable (Equipment Side) - Connector 3 USB A (Male) Included KVM Cable (Equipment Side) - Connector 4 DB9 (Male) © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
B050-000 价格&库存
很抱歉,暂时无法提供与“B050-000”相匹配的价格&库存,您可以联系我们找货
