P758-006
P758-006
    TRIPPLITE
    CABLE FOR USB KVM SWITCH 6'
P758-006 数据手册
USB Cable Kit for KVM Switch B006-VU4-R, 6 ft. (1.83 m) MODEL NUMBER: P758-006 Highlights ● Required to connect a USB computer to the B006-VU4-R KVM switch ● KVM switch side of the cable kit consists of a USB Type B Male cable and a SVGA (HD15) Female monitor cable ● Computer side of the cable kit consists of a USB Type A Male cable and a SVGA (HD15) Male monitor cable System Requirements ● A USB computer ● A USB KVM switch (model # B006-VU4-R). Package Includes ● Features ● Required to connect a USB computer to a B006-VU4-R KVM switch ● KVM switch side of the cable kit consists of a USB Type B Male cable and a SVGA (HD15) Female monitor cable ● Computer side of the cable kit consists of a USB Type A Male cable and a SVGA (HD15) Male monitor cable ● Molded ends with easy-grip textured overmold ● Supports any VGA/SVGA monitor ● Constructed of mini-coax (RGB) and paired video wire ● Superior molded cable with integral strain relief and double shielding (foil and braid) for maximum EMI/RFI protection ● Hi-Resolution cable Specifications OVERVIEW UPC Code 037332014986 Accessory Type Cable Kit Technology VGA/SVGA Accessory Class KVM Switch Accessories PHYSICAL Cable Length (ft.) 6 Cable Length (m) 1.83 1/2 6-ft. USB Cable Kit for the B006VU4-R KVM Switch Shipping Dimensions (hwd / in.) 7.00 x 9.00 x 0.50 Shipping Dimensions (hwd / cm) 17.78 x 22.86 x 1.27 Shipping Weight (lbs.) 0.50 Shipping Weight (kg) 0.23 CONNECTIONS KVM Switch Side 1 HD15 (Female) KVM Switch Side 2 USB B (Male) Computer Side 1 HD15 (Male) Computer Side 2 USB A (Male) FEATURES & SPECIFICATIONS IP68 Rated No IP20 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
P758-006
- 物料型号:P758-006 - 器件简介:该电缆套件用于连接USB计算机至B006-VU4-R型号的KVM切换器。 - 引脚分配:KVM切换器端有USB Type B Male和SVGA (HD15) Female显示器电缆;计算机端有USB Type A Male和SVGA (HD15) Male显示器电缆。 - 参数特性:电缆长度为6英尺(1.83米),支持任何VGA/SVGA显示器,采用mini-coax (RGB)和配对视频线构造,具有优越的成型电缆,内置应力缓解和双层屏蔽(箔和编织),以提供最大的电磁干扰/射频干扰保护。 - 功能详解:该电缆套件是连接USB计算机至B006-VU4-R KVM切换器所必需的。 - 应用信息:适用于需要通过KVM切换器控制多台计算机的场合。 - 封装信息:产品符合RoHS标准,提供全球范围内的终身有限保修。
P758-006 价格&库存
很抱歉,暂时无法提供与“P758-006”相匹配的价格&库存,您可以联系我们找货
