B078-101-PS2
B078-101-PS2
    TRIPPLITE
    MODULE INTERFACE PS2 CAT5E
B078-101-PS2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States NetCommander PS2 Server Interface Unit (SIU) Highlights ● Needed to connect a PS/2 Server to a B070 / B072-Series NetCommander KVM switch via Cat5e cable ● Easy to install; no software needed ● No power supply needed ● Allows a recommended maximum distance of 100-ft. (30.5 m) from KVM to Server via Cat5e cable ● Compact and lightweight design MODEL NUMBER: B078-101-PS2 System Requirements ● Server or CPU with a HD15 port and (2) PS/2 type connections ● A B070 / B072-Series NetCommander Cat5 KVM Switch ● Cat5e/6 cable; up to 100-ft. (30.5 m) ● To convert DisplayPort or HDMI computers to VGA, use Tripp Lite adapters P134-06N-VGAV2 or P131-06N Features ● Needed to connect a PS/2 Server to a B070 / B072-Series NetCommander KVM switch via Cat5e cable ● Eliminates the need for thicker, heavier KVM cables ● Compact, lightweight design ● Plug and Play; no software required ● No power supply required ● Allows a Server/CPU to be located up to 100-ft. (30.5 m) away from the KVM switch ● To convert DisplayPort or HDMI computers to VGA, use Tripp Lite adapters P134-06N-VGA-V2 or P131-06N Package Includes ● Specifications OVERVIEW UPC Code 037332148438 Accessory Type Server Interface Unit Technology Cat5/5e; PS/2; VGA/SVGA Accessory Class KVM Switch Accessories INPUT Bus Powered Yes Product Length (ft.) 1.2 USER INTERFACE, ALERTS & CONTROLS LED Indicators GREEN (RECEIVING POWER); ORANGE (SELECTED AS ACTIVE PORT) 1/3 (x1) B078-101-PS2 PS/2 Server Interface Unit (SIU) 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color Gray Material of Construction ABS Shipping Dimensions (hwd / in.) 1.10 x 5.12 x 5.90 Shipping Dimensions (hwd / cm) 2.79 x 13.00 x 14.99 Shipping Weight (lbs.) 0.24 Shipping Weight (kg) 0.11 Unit Weight (lbs.) 0.22 Unit Weight (kg) 0.10 ENVIRONMENTAL Operating Temperature Range -4 to 158 F (-20 to 70 C) Storage Temperature Range -4 to 158 F (-20 to 70 C) CONNECTIONS Side A - Connector 1 HD15 (MALE) Side A - Connector 2 (2) MINI DIN-6 (FEMALE) Side B - Connector 1 RJ45 (FEMALE) Computer Keyboard and Mouse Interface PS/2 Computer Monitor Interface VGA FEATURES & SPECIFICATIONS Driver Required No Recommended Category Cable N105 - SERIES CAT5E SHIELDED CABLES IP68 Rated No IP20 Rated No STANDARDS & COMPLIANCE Product Certifications EN 55022; EN 55024 Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
B078-101-PS2 价格&库存
很抱歉,暂时无法提供与“B078-101-PS2”相匹配的价格&库存,您可以联系我们找货
B078-101-PS2
    库存:5
