0DT60002
0DT60002
    TRIPPLITE
    MINICOM PS2 TO USB CONV
0DT60002 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States PS/2 to USB Converter Highlights ● Compatible with PS/2 servers/KVM switches/KVM extenders ● Pure hardware solution - no software/network conflicts ● No need for external power ● Compact size ● Plug & play ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: 0DT60002 System Requirements ● PS/2 Computer / KVM Switch / KVM Extender ● USB and/or PS/2 keyboard and mouse ● Compatible with most keyboards; supports 104 keys only Description Preserve Your IT investments Keep your PS/2 legacy equipment! The PS/2 to USB Converter, a small, plug & play converter, transforms PS/2 equipment from outdated devices to valuable tools for today's data centers. Rather than advocate "rip and replace" IT solutions, this adapter preserves past investments by repurposing and updating existing IT equipment. Once you have gone through the hassle of setting up a KVM switch, for example, it is inconvenient and expensive to throw it out and start from scratch. With the PS/2 to USB Converter, your life at the rack only gets easier: you can now use your KVM switch with a new generation USB keyboard and mouse. With your PS/2 KVM switches, you can still extend the life of the IT equipment that you already bought. Flexible USB Support With the PS/2 to USB Converter, you can use your PS/2 device (KVM switches, KVM extenders, and servers) with a USB keyboard and mouse. Unlike other converters, the PS/2 to USB Converter accommodates multiple permutations of keyboard and mice combinations: ● Supports USB keyboard with USB mouse ● Supports USB keyboard with PS/2 mouse ● Supports USB mouse with PS/2 keyboard Features ● Compatible with PS/2 servers / KVM switches / KVM extenders ● Pure hardware solution - no software/network conflicts ● No need for external power ● Compact size ● Plug & play ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW 1/3 Package Includes ● PS/2 to USB Converter 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 654518212235 Accessory Type Serial Adapter Technology PS/2 Accessory Class KVM Switch Accessories INPUT Product Length (in.) 11.4 PHYSICAL Color Black Material of Construction ABS Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 3.5mm Shipping Dimensions (hwd / in.) 5.50 x 3.90 x 0.50 Shipping Dimensions (hwd / cm) 13.97 x 9.91 x 1.27 Shipping Weight (lbs.) 0.18 Shipping Weight (kg) 0.08 Unit Packaging Type Polybag ENVIRONMENTAL Operating Temperature Range 41 to 104 F (5 to 40 C) Storage Temperature Range -4 to 140 F (-20 to 60 C) Relative Humidity 0% to 80% RH, Non-Condensing CONNECTIONS Side A - Connector 1 (2) MINI DIN-6 (MALE) Side B - Connector 1 (2) USB A (FEMALE) Connector Plating Nickel Contact Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 1.1 (up to 12 Mbps) IP68 Rated No IP20 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
0DT60002 价格&库存
很抱歉,暂时无法提供与“0DT60002”相匹配的价格&库存,您可以联系我们找货
0DT60002
    库存:21
