0SU51079/8
0SU51079/8
    TRIPPLITE
    MINICOM 8PK ROC USB SERVER INTER
0SU51079/8 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States ROC USB (8 Pack) - Server Interface Unit for Smart KVMs MODEL NUMBER: 0SU51079/8 Highlights ● Needed to connect a USB Server to a Smart KVM switch via Cat5e cable ● Easy to install; no software needed ● No power supply needed ● Allows a recommended maximum distance of 100ft from KVM to Server via Cat5e cable ● Compact and lightweight design System Requirements ● Smart KVM Switch ● Computer with a VGA video port ● Computer with a USB port Package Includes ● Description The ROC USB Server Interface Module connects to the HD15 and USB ports on a computer/server, and converts them to a single RJ45 connector. Ordinary Cat5e patch cables can then be used to connect the computer/server to the switch ports on a Smart KVM switch. Use of Cat5e cables frees up space in the installation that would be filled by traditional, thicker KVM cables. Features ● Needed to connect a USB Server to a Smart KVM switch via Cat5e cable ● Easy to install; no software needed ● No power supply needed ● Allows a recommended maximum distance of 100ft from KVM to Server via Cat5e cable ● Compact and lightweight design Specifications OVERVIEW UPC Code 654518210637 PHYSICAL Shipping Dimensions (hwd / in.) 1.00 x 5.00 x 5.75 Shipping Dimensions (hwd / cm) 2.54 x 12.70 x 14.60 Shipping Weight (lbs.) 0.35 Shipping Weight (kg) 0.16 1/2 (x8) ROC USB 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
0SU51079/8 价格&库存
很抱歉,暂时无法提供与“0SU51079/8”相匹配的价格&库存,您可以联系我们找货
