P762-010
P762-010
    TRIPPLITE
    CABLE KIT FOR KVM PS/2 10'
P762-010 数据手册
KVM Switch Cable Kits - 10-ft. AT Cable Kit for KVM Switch B005-008 with Audio Highlights ● Audio compliant ● For use with B005-008 KVM switch when connecting AT style CPU ● Cable has (5) leads: HD15M (video); Din5M (AT style keyboard); DB9M (AT style Mouse); (2) Audio leads MODEL NUMBER: P762-010 System Requirements ● An AT computer ● A KVM switch (model # B005008). Package Includes ● Description Tripp Lite's 10-ft. AT KVM cable kit with audio is designed to connect an AT computer to a B005-008 KVM switch. This premium 5-in-1 cable provides superior performance and cable management. It consists of an AT keyboard cable, a serial mouse cable, an SVGA mini-coax monitor cable and 2 audio cables all bonded into a single unit. This unique cable has a DIN5 male, a DB9 female, an HD15 male and (2) 3.5mm male connectors on one end with a DB25 male connector on the other end (which connects to the KVM switch). All cables are manufactured from superior molded cable with integral strain relief and foil shielding for maximum EMI/RFI protection. Tripp Lite warrants this product to be free from defects in materials and workmanship for life. Features ● Connects an at computer to a KVM switch (# B005-008) ● 10-ft. 5-in-1 cable consists of an AT keyboard cable, a serial mouse cable, an SVGA mini-coax monitor cable and 2 audio cables bonded into a single unit ● Superior molded cable with integral strain relief and double shielding (foil and braid) for maximum EMI/RFI protection ● Provides superior performance and cable management ● DB25 male connector attaches to the KVM switch ● Molded ends with easy-grip textured overmold ● Tripp Lite warrants this product to be free from defects in materials and workmanship for life ● Monitor cable portion constructed of mini-coax (RGB) and paired video wire to support any VGA/SVGA monitor. Connector: HD15 male ● AT Keyboard cable connector: DIN5 male ● Serial mouse cable connector: DB9 female ● Audio cable connectors: 3.5mm male Specifications 1/2 10-ft. AT Cable Kit for KVM Switch B005-008 w/ Audio OVERVIEW UPC Code 037332014504 PHYSICAL Cable Length (ft.) 10 Cable Length (m) 3.05 Shipping Dimensions (hwd / in.) 13.00 x 10.00 x 1.50 Shipping Dimensions (hwd / cm) 33.02 x 25.40 x 3.81 Shipping Weight (lbs.) 1.71 Shipping Weight (kg) 0.78 CONNECTIONS CPU Connector 2 3.5mm (Male) WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
P762-010 价格&库存
很抱歉,暂时无法提供与“P762-010”相匹配的价格&库存,您可以联系我们找货
