P764-006
P764-006
    TRIPPLITE
    CABLE KIT FOR KVM PS/2 6'
P764-006 数据手册
KVM Switch Cable Kits - 6-ft. Cable Kit for KVM Switch B005-008 with Audio Highlights ● Audio compliant ● For use with B005-008 KVM switch when connecting PS/2 style CPU ● Cable has (5) leads: HD15M (video); MiniDin6M (PS/2 style keyboard); MiniDin6M (PS/2 style Mouse); (2) Audio leads MODEL NUMBER: P764-006 System Requirements ● A PS/2 computer or a console converter (# B010-000 and B011-000) ● KVM switch (# B005-008). Package Includes ● Description Tripp Lite's 6-ft. PS/2 KVM cable kit with audio is designed to connect a PS/2 computer to a B005-008 KVM switch. This premium 5-in-1 cable provides superior performance and cable management. It consists of 2 PS/2 keyboard/mouse cables, an SVGA mini-coax monitor cable and 2 audio cables all bonded into a single unit. This unique cable has 2 MiniDIN6 male, an HD15 male and (2) 3.5mm male connectors on one end with a DB25 male connector on the other end (which connects to the KVM switch). All cables are manufactured from superior molded cable with integral strain relief and foil shielding for maximum EMI/RFI protection. Tripp Lite warrants this product to be free from defects in materials and workmanship for life. Features ● Connects a PS/2 computer to a KVM switch (# B005-008) ● 6-ft. 5-in-1 cable consists of an PS/2 keyboard cable, a PS/2 mouse cable, an SVGA mini-coax monitor cable and 2 audio cables bonded into a single unit ● Superior molded cable with integral strain relief and double shielding (foil and braid) for maximum EMI/RFI protection ● Provides superior performance and cable management ● DB25 male connector attaches to the KVM switch ● Molded ends with easy-grip textured overmold ● Tripp Lite warrants this product to be free from defects in materials and workmanship for life ● Monitor cable portion constructed of mini-coax (RGB) and paired video wire to support any VGA/SVGA monitor. Connector: HD15 male ● PS/2 keyboard cable connector: MiniDIN6 male ● PS/2 mouse cable connector: MiniDIN6 male ● Audio cable connectors: 3.5mm male Specifications 1/2 6-ft. Cable Kit for KVM Switch B005-008 w/ Audio OVERVIEW UPC Code 037332014511 PHYSICAL Cable Length (ft.) 6 Cable Length (m) 1.83 Shipping Dimensions (hwd / in.) 12.50 x 9.50 x 1.50 Shipping Dimensions (hwd / cm) 31.75 x 24.13 x 3.81 Shipping Weight (lbs.) 1.04 Shipping Weight (kg) 0.47 CONNECTIONS CPU Connector 2 3.5mm (Male) WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
P764-006
物料型号:P764-006
器件简介: - Tripp Lite的6英尺PS/2 KVM电缆套件带有音频,设计用于将PS/2计算机连接到B005-008 KVM切换器。 - 该高级5合1电缆提供卓越的性能和电缆管理。 - 包括2个PS/2键盘/鼠标电缆、一个SVGA迷你同轴监视器电缆和2个音频电缆,全部绑定在一个单元内。
引脚分配: - 一端有2个MiniDIN6公头、一个HD15公头和2个3.5mm公头连接器。 - 另一端有一个DB25公连接器(连接到KVM切换器)。
参数特性: - 音频兼容 - 适用于连接PS/2风格的CPU时使用的B005-008 KVM切换器 - 电缆有5根线:HD15M(视频);MiniDin6M(PS/2风格键盘);MiniDin6M(PS/2风格鼠标);2个音频线
功能详解: - 连接PS/2计算机到KVM切换器(# B005-008) - 6英尺5合1电缆包括PS/2键盘电缆、PS/2鼠标电缆、SVGA迷你同轴监视器电缆和2个音频电缆绑定在一个单元内 - 卓越的模制电缆,内置应力消除和双层屏蔽(箔和编织)以提供最大的EMI/RFI保护 - DB25公连接器连接到KVM切换器 - 模制端部,带有易于握持的纹理覆盖成型 - Tripp Lite保证此产品在材料和工艺上无缺陷,提供终身保修
应用信息: - 系统要求:PS/2计算机或控制台转换器(# B010-000和B011-000) - KVM切换器(# B005-008)
封装信息: - 包装包括:6英尺KVM切换器B005-008带音频的电缆套件
P764-006 价格&库存
很抱歉,暂时无法提供与“P764-006”相匹配的价格&库存,您可以联系我们找货
