B078-101-USB
B078-101-USB
    TRIPPLITE
    MODULE INTERFACE USB CAT5E
B078-101-USB 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Designed to be used with B070-008-19, B070-016-19, B072-008-1, B072-008-1A, B072-016-1 or B072016-1A NetCommander Cat5 KVM switches. Not for use with B070-008-19-IP, B070-016-19-IP, B072- Highlights ● Needed to connect a USB Server to a B070-008-19, B070016-19, B072-008-1, B072-0081A, B072-016-1 or B072-016-1A NetCommander KVM switch via Cat5e cable ● Easy to install; no software needed ● No power supply required ● Allows a recommended maximum distance of 100-ft. (30.5 m) from KVM to computer/server via Cat5e cable ● Compact and lightweight design 008-1-IP or B072-016-1-IP NetCommander IP Cat5 KVM Switches KVM Switch Accessories - NetCommander USB Server Interface Unit (SIU) MODEL NUMBER: B078-101-USB System Requirements ● Server or CPU with a HD15 port and a USB port ● A B070-008-19, B070-016-19, B072-008-1, B072-008-1A, B072-016-1 or B072-016-1A NetCommander Cat5 KVM Switch ● Not for use with B070-008-19IP, B070-016-19-IP, B072-0081-IP or B072-016-1-IP NetCommander IP Cat5 KVM Switches ● Cat5e/6 cable; up to 100ft Features ● Needed to connect a USB Server to a B070-008-19, B070-016-19, B072-008-1, B072-008-1A, B072016-1 or B072-016-1A NetCommander KVM switch via Cat5e cable ● Eliminates the need for thicker, heavier KVM cables ● Compact, lightweight design ● Plug and Play; no software required ● No power supply required ● Allows a Server/CPU to be located up to 100-ft. (30.5 m) away from the KVM switch Package Includes ● Specifications OVERVIEW UPC Code 037332148421 Accessory Type Server Interface Unit Accessory Class KVM Switch Accessories PHYSICAL Shipping Dimensions (hwd / in.) 3.60 x 1.60 x 0.90 Shipping Dimensions (hwd / cm) 9.14 x 4.06 x 2.29 Shipping Weight (lbs.) 0.40 1/2 (x1) B078-101-USB USB Server Interface Unit (SIU) 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (kg) 0.18 WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
B078-101-USB 价格&库存
很抱歉,暂时无法提供与“B078-101-USB”相匹配的价格&库存,您可以联系我们找货
