U352-000-MD
U352-000-MD
    TRIPPLITE
    USB3.0MULTI-DRIVESDCFMS
U352-000-MD 数据手册
USB 3.0 SuperSpeed Multi Drive Smart Card Flash Memory Media Reader/Writer MODEL NUMBER: U352-000-MD Highlights ● USB 3.0 to SD/MS/CF MultiCard Reader ● 5 Gbps transfer rate with USB 3.0 enabled computers ● Plug-n-Play System Requirements ● Allows for the simultaneous connection of multiple memory cards Package Includes ● Transfer photos from your SD / CF / MS card to your computer at up to 5 Gbps speeds. Description Tripp Lite's U352-000-MD USB 3.0 Multi-Drive Card Reader transfers your photos from your cameras SD, MS, and CF memory card at fast USB 3.0 5 Gbps speeds when attached to USB 3.0 enabled computers. Backward compatible to earlier USB versions...will plug into non-USB 3.0 computers as well. Plug and Play....no software or drivers to load; no external power adapter required. Compatible with all USBenabled operating systems. Supports the following memory cards: CF SLOT: CompactFlash Type i / ii, CF Elite Pro, CF PRO I, CF PRO II, CF Turbo, CF Ultima I, CF Ultima II, Extreme CF, Extreme III CF, HS CF, Ultra II CF MS SLOT: MS, MS DUO, MS PRO, MS PRO DUO, MS MagicGate, MS MagicGate Pro, MS MagicGate Duo, MS MAgicGate PRO DUO, Extreme MS Pro, Extreme III MS PRO, Ultra II MS PRO, HS MS MagicGate PRO, HS MS MagicGate PRO DUO, MS ROM, MS Select SD SLOT: SecureDigital (SD), Elite Pro SD, Extreme III SD, Gaming Edition SD, Platinum II SD, SD Pro, SDHC, SDXC, SD-Max, SD-Pleomax, SD-Pro C, Super SD, Turbo SD, Ultima I SD, Ultima II SD, Ultimate SD, Ultra High Speed SD, Ultra II SD, Ultra II SD Plus, Ultra SD, Ultra-X SD, DV-RS MMC, High Speed MMC / RS-MMC, MCCmobile, MMC Pro, MMCplus, MMCplus Turbo, RS-MMC Micro SD / M2 SLOT: MicroSD ( TransFlash ), microSDHC / M2, microSDXC Features ● USB 3.0 to SD/CF/MS card reader ● Allows for the simultaneous connection of multiple memory cards ● Up to 5 Gbps data transfer rates ● Backward compatible to USB 2.0 and USB 1.1 ● Plug and Play - no software / drivers needed ● Compatible with all USB enabled operating systems ● USB Bus powered - no external power required Specifications 1/2 USB 3.0 Multi-Drive SD / CF/ MS Card Reader OVERVIEW UPC Code 037332173478 PHYSICAL Color Black Shipping Dimensions (hwd / in.) 1.00 x 5.70 x 5.50 Shipping Dimensions (hwd / cm) 2.54 x 14.48 x 13.97 Shipping Weight (lbs.) 0.20 Shipping Weight (kg) 0.09 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 1.22 x 6.1 x 6.1 Unit Weight (lbs.) 0.0815 Unit Weight (kg) 0.04 CONNECTIONS Side A - Connector 1 USB 3.0 A (MALE) Side B - Connector 1 SD (FEMALE) Side B - Connector 2 MICRO SD (FEMALE) Side B - Connector 3 CF (FEMALE) WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
U352-000-MD 价格&库存
很抱歉,暂时无法提供与“U352-000-MD”相匹配的价格&库存,您可以联系我们找货
