2.5-Inch SATA Hard Drive Mounting Kit for 3.5Inch Drive Bay
MODEL NUMBER: P948-BRKT25
Highlights
Easy transfer of data from 2.5
in. drive to your PC
Supports all 2.5 in. SATA HDDs
and SSDs
Includes 22-pin data/power
adapter cable
Durable solid steel construction
Package Includes
Increases your desktop PC’s performance by allowing you to mount a 2.5 in. SATA hard drive into an
available 3.5 in. drive bay.
Description
The P948-BRKT25 2.5-Inch SATA Hard Drive Mounting Kit improves the performance of your desktop
computer and allows you to add significant data storage. It allows you to mount a 2.5-inch SATA hard disk
drive (HDD) or solid state drive (SSD) into an empty 3.5-inch drive bay on your PC. The solid steel bracket
comes with a 22-pin data/power SATA adapter cable that attaches to the 2.5-inch drive’s SATA port, the
computer power supply’s LP4 port and an available SATA data connector on the host motherboard.
Screws for mounting the bracket are also included.
Features
Mounts a 2.5 in. SATA Drive Into a 3.5 in. Drive Bay
● Easy transfer of data from 2.5 in. drive to your PC
Adds significant amount of data storage
Supports all 2.5 in. SATA HDDs and SSDs
22-pin data/power adapter cable and mounting hardware included
Specifications
OVERVIEW
UPC Code
037332200501
Technology
SATA/eSATA
PHYSICAL
Color
Black
1/2
Bracket
adapter cable
(8) Screws
Owner’s manual
Shipping Dimensions (hwd / cm)
2.54 x 10.41 x 15.75
Shipping Dimensions (hwd / in.)
1.00 x 4.10 x 6.20
Shipping Weight (kg)
0.14
Shipping Weight (lbs.)
0.30
Unit Dimensions (hwd / in.)
0.5 x 4 x 2.4
Unit Dimensions (hwd / cm)
1.3 x 10.1 x 6.1
CONNECTIONS
Side A - Connector 1
22 PIN SATA + POWER (FEMALE)
Side B - Connector 1
7 PIN SATA (MALE)
Side B - Connector 2
LP4 (MALE)
FEATURES & SPECIFICATIONS
IP68 Rated
No
IP20 Rated
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“P948-BRKT25”相匹配的价格&库存,您可以联系我们找货
