1.24
3.5MM MALE
O .90 MAX.
7MM CONNECTOR
NOTES: UNLESS OTHERWISE SPECIFIED.
1. MATERIALS & FINISH:
1.1 COUPLING NUTS, OUTER 7MM HOUSINGS & 3.5MM HOUSING:
PASSIVATED STAINLESS STEEL.
1.2 INNER 7MM HOUSING & CENTER CONTACT: GOLD PLATED
BERYLLIUM COPPER.
1.3 SUPPORT BEADS: NORYL
1.4 GASKET: SILICONE RUBBER.
2. ELECTRICAL SPECIFICATIONS:
2.1 FREQUENCY RANGE: DC TO 18.0 GHz
2.2 VSWR (MAXIMUM) 1.025 + 0.0025f(GHz)
2.3 IMPEDANCE: 50 OHMS NOMINAL
3RD ANGLE PROJECTION
RoHS2
This PROPRIETARY Document
is property of Cinch Connectivity
Solutions. It is confidential in
nature, non-transferable, and
issued with the clear
understanding that it is not
traced or copied without
permission and is returnable
upon demand.
INTERPRET DRAWING IN
ACCORDANCE W ITH ASME
Y14.5-2009.
MIDWEST MICROWAVE
Title:
ADAPTER - 7MM TO 3.5MM MALE
2011/65/EU
UNITS: INCH
.XX u.02
.XXX u.005
ANGLES u2v
Model No.
ADT-2701-7M-3MM-02
Size
A
DO NOT SCALE Date:
10/20/2014
DRAWING
Sheet 1 of 1
很抱歉,暂时无法提供与“ADT-2701-7M-3MM-02”相匹配的价格&库存,您可以联系我们找货
