NOTES: UNLESS OTHERWISE SPECIFIED.
-3538-IO-SMA
SMA FEMALE CONN.
PER MIL-PRF-39012
EST MICRO
O .85
21.6
SMA MALE CONN.
PER MIL-PRF-39012
2.31 [58.7] MAX
1.0 ELECTRICAL SPECIFICATIONS:
1.1 FREQUENCY RANGE: 0.1 TO 18.0 GHz
1.2 IMPEDANCE: 50 OHM, NOM.
1.3 VSWR (MAX):
0.1 TO 8.0 GHZ: 1.20:1
8.0 TO 12.4 GHz: 1.25:1
12.4 TO 18.0 GHz: 1.35:1
1.4 INSERTION LOSS: 0.54dB MAX.
OVER FREQ. RANGE AT 1KHz > 65dB
1.5 OPERATING TEMPERATURE:
-20vC TO +100vC
1.6 DC WORKING VOLTAGE: 200 VOLTS
1.7 TYPE: INSIDE/OUTSIDE
2.0 MARKING:
MARK UNIT AS SHOWN.
(REF: INK-02597-27-04)
3.0 MATERIAL & FINISH:
3.1 HOUSING (MALE & FEMALE), COUPLING NUT:
STAINLESS STEEL PASSIVATED.
3.2 HOUSING: ACETAL (DuPont)
3.3 CENTER CONTACT (MALE & FEMALE): GOLD PLATED BRASS
3.4 INSULATOR: PTFE (TEFLON)
3.5 GASKET: SILICONE RUBBER
4.0 DIMENSIONS IN BRACKETS ARE MILLIMETERS.
3RD ANGLE PROJECTION
RoHS2
This PROPRIETARY Document
is property of Emerson Network
Power Connectivity Solutions.
It is confidential in nature,
non-transferable, and issued with
the clear understanding that it is
not traced or copied without
permission and is returnable
upon demand.
INTERPRET DRAWING IN
ACCORDANCE WITH ASME
Y14.5-2009.
Midwest Microwave
Title:
DC BLOCK
2011/65/EU
UNITS: INCH
.XX u.02
.XXX u.005
ANGLES u2v
Model No.
DCB-3538-IO-SMA-02
Size
A
DO NOT SCALE Date:
5/30/2014
DRAWING
Sheet 1 of 1
很抱歉,暂时无法提供与“DCB-3538-IO-SMA-02”相匹配的价格&库存,您可以联系我们找货
