HRMJ-N.FLP-ST5
HRMJ-N.FLP-ST5
    HRS(广濑)
HRMJ-N.FLP-ST5 数据手册
N.FL Series Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.4mm Mated Height, Lightweight SMT Miniature Coaxial Connector Dec. 2021 N.FL Series/1.4mm Mated Height, Lightweight SMT Miniature Coaxial Connector 1.4 (1.5 Max.) 1. 1. 4mm Mated Height ( 1. 5mm Max. ) The receptacle and right angle plug produce a mated height of only 1. 5mm Max. from the PCB. Achieve the handling ease of the U. FL Series with a reduced mated height. N.FL U.FL-LP(V) N. FL and U. FL- LP( V) Mated Height Comparison N.FL-LP-040HF 3.4 1.4(1.5 Max.) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.9 (2.0 Max.) Features N.FL-R-SMT-1 N. FL- LP- 040HF and N. FL- R- SMT- 1 2. Occupied PCB Space The receptacle has the same occupied PCB space as the U. FL Series at 7. 7mm2 3. Light Weight Receptacle : 14mg Right Angle Plug : 28mg 4. Supports Up to 6GHz Frequency High frequency performance of DC to 6GHz and V. S. W. R. of 1. 3 Max. in order to support the high frequency needs of various compact devices. 5. Supports Automatic Mounting Tape and Reel packaging allows for pick- andplace mounting. 2 N.FL Series/1.4mm Mated Height, Lightweight SMT Miniature Coaxial Connector 6. Ultra- fine Coaxial ( Fluorinated Resin Insulated) Cables Compatible with ultra- fine φ0. 81mm diameter coaxial cables for smooth and easy installment. 7. Environmental Compatibility Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. RoHS2 Compliant Halogen Free Chlorine and bromine above the standard values are not used for receptacle and plug harnesses. * As defined by IEC61249- 2- 21 Br 900 ppm Max. , Cl 900 ppm Max. , and Br+ Cl 1500 ppm Max. 8. Easy Connector Removal Extraction tool enables easy removal of the connector. 9. Easy Mating Confirmation Compact product with a clear, tactile click for reliable mating confirmation. 3 N.FL Series/1.4mm Mated Height, Lightweight SMT Miniature Coaxial Connector Product Specifications Nominal Characteristic Impedance 50 Ω Operating Temperature -40 to +90℃(90% RH Max.) Frequency Range DC to 6GHz Storage Temperature Range -30 to +70℃(90% RH Max.) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item Specifications Conditions Contact Resistance Center : 25m Ω Max. Outer : 25m Ω Max. Measured with 10mA Max. Insulation Resistance 500M Ω以上 Measured with 100V DC Withstanding Voltage No flashover or insulation breakdown 200V AC for 1 min. V.S.W.R.* 1.3 Max. DC to 6GHz Female Contact Retention Force 0.1N Min. Measured with φ 0.475 pin gauge Mating Durability Contact Resistance : 30m Ω Max. (Center) 30m Ω Max. (Outer) No damage, cracks or parts dislocation. 20 times Vibration Resistance No electrical discontinuity of 1μ s min. No damage, cracks or parts dislocation. Frequency : 10 to 100Hz, single amplitude of 1.5mm, acceleration of 59m/s2, for 5 cycles in the direction of each of the 3 axis. Shock Resistance No electrical discontinuity of 1μ s min. No damage, cracks or parts dislocation. Acceleration of 735m/s2, 11ms duration, sine half-wave waveform, 3 cycles in each of 3 axes. Humidity Resistance (Steady State) Insulation Resistance : 100M Ω Min. (High Humidity) 500M Ω Min. (When Dry) No damage, cracks or parts dislocation. 96 hours at temperature of 40℃ and humidity of 95%. Temperature Cycle No damage, cracks or parts dislocation. Temperature : -40℃ → +5 to +35℃ → +90℃ → +5 to +35℃ Time : 30 minn. → 5 min. Max. → 30 min. → 5 min. Max. 5 cycles Salt Spray No excessive corrosion 5% salt water solution for 48 consecutive hours * V. S. W. R. Measurement System The above V. S. W. R. standard values were measured using the measurement system shown below. Network Analyzer Test Set Test Port D.U.T Termination Test Port Cable Note 1 : Cable type connectors were measured with SMA conversion adapters attached to the cable assembly at both ends of a compatible 100cm cable. Note 2 : Board type connectors were mounted to a 50 Ω glass epoxy board and measurements were conducted with SMA conversion adapters attached. Materials / Finish Item Right Angle Plug Receptacle Part Material Finish Flame Retardancy Shell Phosphor Bronze Silver Plated - Insulator PBT Gray UL94HB Female Center Contact Phosphor Bronze Gold Plated - Shell Phosphor Bronze Silver Plated - Insulator LCP Black UL94V-0 Male Center Contact Brass Gold Plated - 4 N.FL Series/1.4mm Mated Height, Lightweight SMT Miniature Coaxial Connector Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ● Receptacle N.FL - R - SMT - 1 (10) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❷ ❸ ❹ ❶ Series Name N.FL ❸ Board Mounting Method SMT : Printed Circuit Board Surface Mount Type ❷ Connector Type R : Receptacle ❹ Packing Type (10) : Reel Packing(2,000pcs per reel) Note : Plugs can be ordered only as terminated cable assemblies. ● How to Designate Plug Cable Assembly Dimensions The dimension specifications of the N. FL Series harness are as follows. [Double-ended Cable Assembly] [Single-ended Cable Assembly] L L Please contact a Hirose representative about cable end processing. Note : Designate the dimensions from the center of the connector for both single-ended and double-ended cable assemblies. (Please write length L in mm.) ● Cable Assembly Product Number Structure NFL - 2LP HF6 - 04N 1 TV - A - L ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❶ Series Name NFL ❹ Cable Type 04N : φ 0.81mm Cable ❷ Assembly Type LP : Single Ended 2LP : Double Ended ❺ Cable Color 1 : White 2 : Black ❻ Cable Outer Conductor TV : Tin Plated Braided Wire ❼ Total Length (mm) L length (mm) ❸ ● Environmental Compliance HF6 : Halogen-free Plug Standard Tolerances for (L) Total Length (mm) Standard Tolerance(mm) 35 ≦ L ≦ 200 ±4 200 < L ≦ 500 ±8 500 < L ≦ 1000 ± 12 1000 < L ± 1.5% Note : The shortest length is L=35mm. 5 N.FL Series/1.4mm Mated Height, Lightweight SMT Miniature Coaxial Connector Plug 2.8 Please order the plug in cable assembly specifications. Receptacle Outer Contact (GND) Outer Contact (GND) Outer Contact (GND) 0.8 0.25 Center Contact (SIG) φ2 1.8 2.6 3.1 0.6 0.6 2.6 3 Part No. N.FL-R-SMT-1(10) ● HRS No. CL0331-0332-3-10 GND 2 1.85 No conductive traces in this area Purchase Unit 2,000pcs per reel Recommended PCB Mounting Pattern 2.05 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.12 3.4 SIG 0.8 1.9 3.8 6 N.FL Series/1.4mm Mated Height, Lightweight SMT Miniature Coaxial Connector Conversion Adapter SMA Conversion Adapter (Mated Portion- U.FL/N.FL Side : Jack, SMA Side : Plug) 8HEX Part No. HRS No. HRMP-U.FLJ(40) (Note 1) Purchase Unit CL0311-0300-2-40 20pcs per bag Note 1 : Compatible with both N.FL and U.FL. Note 2 : Since the U.FL/N.FL side mating portion has a weaker lock than standard products, it cannot be used for purposes other than performance measurement. SMA Conversion Adapter (Mated Portion- U.FL/N.FL Side : Plug, SMA Side : Jack) 6 14.05 (4.05) 5.6 φ6.35 1/4-36UNS-2A Part No. HRS No. HRMJ-U.FLP(40) (Note 1) Purchase Unit CL0311-0301-5-40 20pcs per bag Note 1 : Compatible with both N.FL and U.FL. Note 2 : Since the U.FL/N.FL side mating portion has a weaker lock than standard products, it cannot be used for purposes other than performance measurement. SMA Conversion Probe (Mated Portion- N.FL Side : Plug, SMA Side : Jack) 6 18.3 (4) 5.5 (3.8) φ3.2 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (10.7) 1/4-36UNS-2A Part No. HRMJ-N.FLP-ST5 HRS No. CL0311-0423-2-00 Purchase Unit 20pcs per bag Note : This connector is used by pressing the mating portion of the N.FL side with the mating portion of N.FL-R-SMT-1. 7 N.FL Series/1.4mm Mated Height, Lightweight SMT Miniature Coaxial Connector SMA Conversion Adapter (Mated Portion : SMA Jack (Measuring Device Connection Side) - SMA Plug) 20 16 φ10.86 2× φ2 .3 Part No. 4.4 18.84 31.3 HRS No. HRM-PA-PJ(F)-1(40) CL0323-0805-9-40 Purchase Unit 20pcs per bag Note : HRMJ-N.FLP-ST5 aborbs misalignment when it is mated with the plug (coupling side) and the jack is connected to the measuring device. Inspection Probe HRMJ-N.FLP-ST5 and HRM-PA-PJ(F)-1(40) Combination and Usage Shortest Pitch when Adjacent 12mm Min. (A) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 8 11.6 Flange to Board Surface (A) Recommendation for Measurement 32 ± 0.2 Starting Load 32.7 Note : For the inspection probe, be careful not to tilt the tip of the contact due to the tensile load of the connecting cable. 8 N.FL Series/1.4mm Mated Height, Lightweight SMT Miniature Coaxial Connector Embossed Carrier Tape Dimensions(JIS C 0806/IEC 60286) Embossed Carrier Tape Dimensions φ 1. 5 4 12 5.5 1.75 2 Unreeling Direction Reel Dimensions 13.5 Material : PS(Black) φ330 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 8 A A 2 φ13 φ2 1 9 N.FL Series/1.4mm Mated Height, Lightweight SMT Miniature Coaxial Connector Applicable Tools Extraction Tool Tool for Unmating. 90 φ15 3 50 Part No. HRS No. U.FL-LP(V)-N-2 (Note) Purchase Unit CL0331-0493-2-00 1pc per bag Note : Compatible with the U.FL-LP(V)-040 and U.FL-LP-062. Mating Tool φ10 Tool for Mating. φ2 (Through) Hole for Distinguishing from W.FL-LP-IN 8 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2.1 U. FL/ V 100 Part No. U.FL-LP-IN (Note) HRS No. CL0331-0334-9-00 Note: Compatible with the U.FL connector. 10 Purchase Unit 1pc per bag N.FL Series/1.4mm Mated Height, Lightweight SMT Miniature Coaxial Connector Usage Precautions 1. Plugs ( 1) Mating/ Unmating ① To disconnect the connector, insert the extraction tool ( U. FL- LP( V) - N- 2) under the connector flange. Pull in a perpendicular direction in line with the connector' s mating axis. When removing the connector directly, hold the connector lid and pull out vertically in relation to the connector' s mating axis. ( Be careful not to damage the connector with fingers or nails. ) Be careful not to apply stress to the cable when using the extraction tool from this side. U.FL-LP(V)-N-2 N.FL-LP-040HF N.FL-R-SMT-1 ( 2) Tolerable Load to a Cable After Mating Once the connector has been mated do not apply forces exceeding the values in the diagram below. N.FL-LP-040HF 2.9N Max. N.FL-R-SMT-1 ( 3) Precautions Do not use excessive prying to mate or un- mate the connectors as it may lead to damage. 2. Receptacles (1) Recommended Reflow Temperature Profile (℃) 260 240 220 200 180 160 140 120 100 80 Temperatue of Top of Component Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ② When mating, align the mating axes between the receptacle and cable assembly, and insert the cable assembly downward and perpendicular into the receptacle. Do not insert the cable assembly at a slanted angle. Heating Peak 250℃ 10 Seconds Preheat 130 to 180℃ 120 Seconds or Less 230℃ 60 Seconds or Less Time 1. Temperature refers to the temperature of the PCB surface at the terminal leads. 2. Reflow soldering should be performed at a printed circuit surface temperature of 250℃ Max. 3. The temperature profile may vary depending on board size, solder used and solder thickness. (2) Recommended Manual Soldering Conditions Manual soldering : 350℃ for 5 seconds (3) Recommended Metal Mask Thickness 0.1 to 0.12mm (4) Reflow Cycles 2 times 11 N.FL Series/1.4mm Mated Height, Lightweight SMT Miniature Coaxial Connector 3. Operating Environment and Storage Conditions ( 1) Operation Environment This product was designed for use in a normal environment. Please be advised that using this product in the environments described below may result in discoloration and other   types of degradation.   ・Exposure to excessive amounts of fine particles and dust.   ・Regions/ areas with a high concentration of gases like sulfur dioxide, hydrogen sulfide and nitrogen dioxide.   ・Areas with drastic temperature changes, such as locations near a heater. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ( 2) Storage Conditions Store this product in Hirose' s packaging or similar conditions. Temperature : - 10 to + 40℃ Humidity : 85% or less ( recommended storage conditions) We recommend the product be used within six months from delivery. Products that have been stored beyond the recommended storage period need to be tested for mounting and solderability before use. ( 3) Silver Plating Discoloration Discoloration occurs only on the plating surface. Since the contact portion is wiped, there is no effect on the electrical   contact. While Taking into Consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 12/ 2021. Contents are subject to change without notice for the purpose of improvements. 12
HRMJ-N.FLP-ST5 价格&库存
很抱歉,暂时无法提供与“HRMJ-N.FLP-ST5”相匹配的价格&库存,您可以联系我们找货
