BJ78HS
BJ78HS
    CINCH
BJ78HS 数据手册
DWG NO. CUSTOMER SH 305-0063 1 7 .562 HEX NUT .730 REVISIONS DESCRIPTIONS DATE APPROVED 2/7/11 T. KOHLER PY DATA CONTAINED IN THIS DOCUMENT IS PROPRIETARY TO EMERSON CONNECTIVITY SOLUTIONS AND SHALL NOT REV BE DISCLOSED, COPIED OR USED FOR PROCUMENT OR MANUFACTURE WITHOUT EXPRESS WRITTEN PERMISSION H ECO 53006 CUST. REV CUSTOMER P/N LL ED C O .500-28 UNEF-2A O .775 TR 1.290 .010 .221 .218 N BJ78HS SHOWN FOR BJ78HSS, 5/8 HEX NUT. 6. FOR BJ78HSS, REPLACE 8-1520-17 WITH 805-1304-3 5. MATERIAL & CONSTRUCTION: MEET THE REQUIREMENTS OF MIL-C-49142 WHERE APPLICABLE. 4. DEILECTRIC WITHSTANDING VOLTAGE: 500 V COMMON MADE VOLTAGE BETWEEN CIRCIUTS. 3. LEAK RATE: 1 X 10 -8 CC/SEC MAX OF TRACER GAS AT ATMOSPHERIC PRESURE. 1. C INTERPRET DRAWING PER TOL: UNLESS SPECIFIED. MIL-STD-100. .XX DIMENSIONS ARE IN INCHES .XXX .005 AND INCLUDE FINISH .XXXX THICKNESS UNLESS OTHERWISE SPECIFIED.ANGLE N U 2. .510 .505 O 7. HERMETICALLY SEALED TWINAX/TRIAX FEED THRU ADAPTER FOR MOUNTING IN BULKHEAD .187 THK MAX. PASSIVATED STAINLESS STEEL. NOTES: UNLESS OTHERWISE SPECIFIED. Connectivity Solutions EMERSON DRN C. WALLAC4 E/7/11 N/A MATERIAL: CHK BLANK LENGTH (REF. ONLY) N/A SURFACE AREA TM Network Power 299 Johnson Ave. Ste. 100 Waseca, MN 56093 1-800-247-8256 TITLE: 1 T. KOHLER4/8/11 QUALITY RECOMMENDED PANEL CUTOUT SCALE 1.500 BJ78HS, BJ78HSS FINISH: MANUF APPROVED PRO/E FILE NO. 305-0063 1 SIZE CAGE CODE DRAWING NO. REV. A 14949 305-0063 SCALE DO NOT SCALE DWG 2/1 DATE 5/5/71 H SHEET 1 OF 2
BJ78HS 价格&库存
很抱歉,暂时无法提供与“BJ78HS”相匹配的价格&库存,您可以联系我们找货
