M39030/3-04N
M39030/3-04N
    CINCH
M39030/3-04N 数据手册
REV D D1 E ECO 15246 ADD TB 25327 DATE 5/22/1996 7/7/2005 5/6/2015 .85 MAX 5/16 HEX EPOXY SEAL M39030/ 3-04N 34078 #### YYWW SMA MALE PER MIL-STD-348 FIG. 310-1 O .36 MAX 2.00 u.25 BEAD CHAIN (NOT TO SCALE) M39030/3-04N SHOWN O.13 THRU HOLE NOTES: UNLESS OTHERWISE SPECIFIED. 1. MATERIAL & FINISH: 1.1 BODY: PASSIVATED STAINLESS STEEL 1.2 DIELECTRIC: PTFE (TEFLON) 1.3 CENTER CONTACT: GOLD PLATED BERYLLIUM COPPER 1.4 GASKET: SILICONE RUBBER 1.5 BEAD CHAIN: STAINLESS STEEL 2. SPECIFICATIONS: 2.1 FREQUENCY RANGE: DC - 18 GHz 2.2 IMPEDANCE: 50 OHMS 2.3 VSWR (MAX): 1.05+0.01f (GHz) 2.4 POWER HANDLING CAPABLITY: 2.4.1 AVERAGE: 0.5 WATTS MAX AT 25vC DERATED LINEARLY TO 0.125 WATTS AT 125vC 2.4.2 PEAK: 50 WATTS WITH A 1% DUTY CYCLE 2.5 OPERATING TEMPERATURE RANGE: -55vC TO 125vC 2.6 WEIGHT (MAX): .25 oz Model No. M39030/3-04(N OR S) Cage Code RoHS2 34078 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. 2011/65/EU QPL TERMINATION 3RD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED UNITS: INCH .XX u.02 .XXX u.005 ANGLES u2v MIDWEST MICROWAVE Title: Drawing No. Drawn by: C. WALLACE Size Date: 5/7/2015 Rev. M39030/3-04(N OR S)-01 A DO NOT SCALE DRAWING Workmanship Std: NONE E Sheet 1 of 1
M39030/3-04N 价格&库存
很抱歉,暂时无法提供与“M39030/3-04N”相匹配的价格&库存,您可以联系我们找货
