Ultra Small Surface Mount Coaxial Connectors
1.4mm or 1.65mm Mated Height
W.FL Series
W.FL Series
U.FL Series
Fig.1
■Features
Mated height comparison
Receptacle:
5.6 mg
Right-angle plug: 18.6 mg(040), 28.2mg(062)
4. Frequency range up to 6 GHz
(MAX2.0)
1.9
W.FL-LP(G)-062HF
(MAX2.4)
3. Extremely light weight
U.FL-LP(V)-040HF
U.FL-LP-062HF
2.3
The W.FL Series is about 55% smaller than our
U.FL Series connector and only uses 3.4mm2 of
PCB space. The PCB layout for the W.FL Series is
the same as for W.FL2 and X.FL Series.
Note:This product is not compatible with W.FL2
Series and X.FL Series.(Fig.1)
W.FL-LP-040HF
1.65 (MAX1.85)
2. Small board footprint
1.4 (MAX1.55)
1. Nominal mated height of 1.4mm or 1.65mm
(Max. 1.55 or 1.85mm)(Fig.2)
DC to 3 GHz : V.S.W.R. of 1.3 max.
3 GHz to 6 GHz: V.S.W.R. of 1.4 max.
Fig.2
5. Automatic board placement
The use of ultra-fine coaxial(fluorinated resin
insulated) cables on these connectors offer the
ability to complete connections in small, confined
spaces with a smooth, easy operation.
7. Simple connector mating / unmating
Use of the available mating/un-mating tools
assures correct connection/disconnection of the
plug and receptacle.
W.FL-LP-040HF
Ø0.81
2.85
W.FL-LP(G)-062HF
3.65
Ø1
6. Plugs are terminated with ultra-fine
coaxial (fluorinated resin insulated)
cable
W. FL Plug and Receptacle
1.4 (MAX1.55)
Packaged on tape-and-reel the receptacles can be
placed with vacuum nozzles of the automatic
placement equipment.
1.65 (MAX1.85)
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Occupied Mounting Area
8. Halogen-free*(Receptacle, Plug(HF type))
Fig.3
*As defined by IEC61249-2-21
Br-900ppm maximum, Cl-900 ppm maximum,
Cl+Br combined-1,500 ppm maximum
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2018.6④
1
W.FL Series●Ultra Small Surface Mount Coaxial Connectors 1.4mm or 1.65mm Mated Height
■Specifications
Nominal characteristic impedance
50ø
Operating temperature range
DC to 6 GHz
Storage temperature range
Rating
Frequency range
Item
Specification
-40°C to +90°C
(90% RH max.)
-30°C to +70°C
(90% RH max.)
Conditions
1. Contact resistance
Center contact : 20mø max.
Outer contact : 10mø max.
10mA max.
2. Insulation resistance
500Mø min.
100V DC
3. Withstanding voltage
No flashover or insulation breakdown
200V AC / 1 minute
4. V.S.W.R.*
1.3 Max.
1.4 Max.
Up to 3 GHz
3 to 6 GHz
*V.S.W.R. Measurement System
Measured as shown on the block diagram below.
Network Analyzer
Test Set
Test Port
D.U.T
Test Port Cable
Termination
Note1 : Measurement way of a W.FL Cable assembly (plug)
W.FL Cable assembly (plug) is measured with SMA conversion
adapters mated with W.FL plugs at both ends of a 100cm coaxial
cable harness
Note2 : Measurement way of a W.FL receptacle
W.FL receptacle, which is mounted on a 50ø glass epoxy board,
is measured with a SMA conversion adapter.
■Materials / Finish
●Plug – right angle
Part
Shell
Female center contact
Insulator
Material
Phosphor bronze
Phosphor bronze
PBT
Finish / Remarks
Silver plated
Gold plated
Color : Gray, UL94V HB(040HF, 062HF)
●Receptacle
Part
Shell
Insulator
Male center contact
Material
Phosphor bronze
LCP
Brass
Finish / Remarks
Silver plated
Color : Black, UL94V-0
Gold plated
■Cable Assembly(Plug)
2
W.FL-LP-040HF(06) (Applicable cable : outer diameter 0.81)
1.15
2.85
W.FL-LP-062HF(06) (Applicable cable : outer diameter 0.95)
[Plugs can be ordered only as terminated cable assemblies.]
2
BHow to Specify Cable Assembly
[Double-ended cable assembly]
[Single-ended cable assembly]
L(mm)
L(mm)
Ordering Information
Standard tolerances for (L)
Used plug : W.FL-LP-040HF(06) (Dia. 0.81)
Double-Ended
W.FL -- 2LP HF6 --04N
q
w
e
r
TV -- A -- L
t
y
u
(L)mm
Standard tolerance(mm)
*L=35 to 200
±4
1L=200 to 500
±8
1L=500 to 1000
±12
L=Longer than 1000
±1.5% of (L)
Note : Minimum available length(L) is 35mm.
Single-Ended
W.FL -- LP HF6 --04N
q
w
e
r
TV -- A -- L
t
y
u
q Series name
w Assembly type
W.FL
LP : Single ended
2LP : Double ended
e Environmental compliant HF6 : Halogen-free
04N : 0.81mm dia. ultra-fine coaxial cable
r Cable type
1
: White
t Cable Color
2
: Black
TV : Tin plated braided wire
y Cable outer conductor
u Total length(mm)
Length(L)
Used plug:W.FL-LP(G)-062HF(06) (Dia. 0.95)
Double-Ended
W.FL -- 2LPG HF6 -- 062N
q
w
e
r
D -- A -- L
t y
u
Single-Ended
W.FL -- LPG HF6 -- 062N
q
w
e
r
D -- A -- L
t y
u
q Series name
w Assembly type
W.FL
LPG : Single ended
2LPG : Double ended
062N : 0.95mm dia. ultra-fine coaxial cable
r Cable type
1
: Gray
2
: Black
t Cable Color
3
: White
D
: Copper tape + Outer tin plated braided wire
u Total length(mm)
Length(L)
3
■Receptacle
BRecommended PCB
mounting pattern
0.85
0.3
0.25
2.6
2
0.5
1.3
1.7
1.3
1.4
1.5
SIG
0.3
GND
SIG
GND
No conductive traces in this area
0.65
2
1.3
1.7
Note : The land pattern is the same as that of the
X.FL, W.FL2 series connectors.
All dimensions : mm
Part No.
HRS No.
Packaging
W.FL-R-SMT-1(60)
331-0482-6 60
Reel (5,000 pcs/reel)
W.FL-R-SMT-1(80)
331-0482-6 80
Reel (10,000 pcs/reel)
Embossed Carrier Tape Dimensions(IEC 60286-3 compliant)
(W.FL-R-SMT-1(60) 8mm pitch)
8
Unreeling direction
Material:PS(Black)
13.5
Ø330
12
5.5
1.75
2
Reel Dimensions
A
(W.FL-R-SMT-1(80) 4mm pitch)
4
Unreeling direction
A(SCALE FREE)
2
Ø13
12
5.5
1.75
2
Ø2
1
4
■Conversion Adapters
SMA Conversion Adapter (W.FL side jack – SMA side plug)
(10.3)
8HEX
W.FL
SMA
Part No.
HRS No.
Packaging
HRMP-W.FLJ(40)
311-0367-3 40
1
SMA Conversion Adapter (W.FL side plug – SMA side jack)
13.8
(4.05)
6
5.6
SMA
Ø6.35
1/4-36UNS-2A
Note : Used for performance measurements only.
The W.FL mating side has lower retention
force than the regular product when mated
to the corresponding part.
W.FL
Part No.
HRS No.
Packaging
HRMJ-W.FLP(40)
311-0368-6 40
1
(18.35)
6
(4)
5.5
Ø6.35
1/4-36UNS-2A
Note : When mating with corresponding part
(W.FL-R-SMT-1) it must be pressed down
and held to make complete connection.
Part No.
HRS No.
HRMJ-W.FLP-ST1(40) 311-0386-8 40
Packaging
1
5
■Receptacle Inspection Adapter
Used for inspecting the performance parameters of the cable assembly.
12.1
(7.9)
4.2
(4.4) 1
7HEX
M5∞0.5
Part No.
HRS No.
Packaging
W.FL-R-1
331-0483-9
1
Plug-Mating Tool
This tool is used for mating a plug.
8
Ø10
(100)
Part No.
HRS No.
Packaging
W.FL-LP-IN
331-0323-2
1
Plug-Extraction Tool
(100)
40
6
5)
(Ø1
Part No.
HRS No.
Packaging
W.FL-LP-N
331-0492-0
1
BPrecautions
1. Plug
(1) Mating / unmating
• Unmating
Insert both ends of the extraction tool under the plug (from the direction opposite to the
Cable termination), as shown and pull-up in the direction perpendicular to the mounting
surface of the receptacle.
W.FL-LP-N plug extraction tool
●Recomended the use of the extraction tool for unmating.
W.FL Cable
Assembly
Any attempt of unmating by pulling on the cable may result in
damage and affect the mechanical / electrical performance.
W.FL-R-SMT-1
• Mating
qAlign the mating tool W.FL-LP-IN or the mating end
of the tool over the plug end of the cable assembly.
wFirmly place the tool over the plug until it is secured
in the tool.
ePlace the plug cable assembly (held in the tool)over
the corresponding receptacle.
rAssuring that the plug and receptacle are aligned
press-down perpendicular to the mounting surface
until both connectors are fully mated.
tRemove the mating tool by carefully pulling it
up.Removal of the tool.
q
w
e
Plug pickup
(2) Pull forces on the
cable after connectors
are mated
t
Insertion to a receptacle Removal of the tool
W.FL-LP※
Cable Assembly
After the connectors are mating, do not apply a load to
the cable in excess of the values indicated in the
diagram.
r
W.FL-R-SMT-1
Receptacle
2N max
(3) Precautions
Do not twist connectors excessively during mating / unmating.
2. Receptacle
(1) Recommended reflow
temperature profile
250 ç max. for
10 seconds
[ç]
260
240
220
200
180
160
140
120
100
80
Preheat
(130 to 180ç)
120 seconds max.
230ç
220ç
50 seconds max.
60 seconds max.
Time
qThe temperature of the printed circuit board surface temperature at the points of contact with the terminals.
wReflow soldering should be performed at a printed circuit surface temperature of 250°C max.
eIn individual applications the actual temperature may vary, depending on the solder paste type, volume /
thickness and board size / thickness. Consuly your solder paste and equipment manufacturer for specific
recommendations.
(2) Recommended metal
mask thickness
0.1mm to 0.12mm
(3) Reflow cycles
2 times
3. Operating environment and storage conditions
(1) Operating
environment
(2) Storage conditions Receptacle
The connectors are not designed to operate in the following environments:
• Exposed to a excessive amounts of fine particles and dust
• Regions and places having a high density of sulfur dioxide, hydrogen sulfide, nitrogen dioxide or other corrosive gasses.
• Environments having large rapid variations in temperature.
Store in the Hirose Electric packaging.
Temperature : -10 to +40ç, Humidity : 85% max.
Use within 6 months of delivery.
Receptacles for which the storage period has elapsed must be tested for solderability to the PC board
mounting surface.
7
USA:
HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE
2300 Warrenville Road, Suite 150,
Downers Grove, IL 60515
Phone : +1-630-282-6700
http://www.hirose.com/us/
USA:
HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE
2841 Junction Ave, Suite 200
San Jose, CA. 95134
Phone : +1-408-253-9640
Fax : +1-408-253-9641
USA:
HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE)
17197 N. Laurel Park Drive, Suite 253,
Livonia, MI 48152
Phone : +1-734-542-9963
Fax : +1-734-542-9964
USA:
HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE
300 Brickstone Square Suite 201,
Andover, MA 01810
Phone : +1-978-662-5255
THE NETHERLANDS:
HIROSE ELECTRIC EUROPE B.V.
Hogehillweg #8 1101 CC Amsterdam Z-O
Phone : +31-20-6557460
Fax : +31-20-6557469
http://www.hirose.com/eu/
GERMANY:
HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH
Schoenbergstr. 20, 73760 ostfildern
Phone : +49-711-456002-1
Fax : +49-711-456002-299
GERMANY:
HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE
Neumeyerstrasse 22-26, 90411 Nurnberg
Phone : +49-911 32 68 89 63
Fax : +49-911 32 68 89 69
GERMANY:
HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE
Bayernstr. 3, Haus C 30855 Langenhagen, Germany
Phone : +49-511 97 82 61 30
Fax : +49-511 97 82 61 35
FRANCE:
HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE
130 Avenue Joseph Kessel, Bat E, 78960
Voisins le Bretonneux, France
Phone : +33-1-85764886
Fax : +33-1-85764823
UNITED KINGDOM:
HIROSE ELECTRIC EUROPE BV (UK BRANCH)
4 Newton Court, Kelvin Drive, Knowlhill,
Milton Keynes, MK5 8NH
Phone : +44-1908 202050
Fax : +44-1908 202058
CHINA:
HIROSE ELECTRIC (CHINA) CO., LTD. (SHANGHAI, HEADQUARTERS)
18, Enterprise Center Tower 2, 209# Gong He
Road, Jing’an District, Shanghai, CHINA 200070
Phone : +86-21-6391-3355
Fax : +86-21-6391-3335
http://www.hirose.com/cn/
CHINA:
HIROSE ELECTRIC (CHINA) CO.,LTD. BEIJING BRANCH
A1001, Ocean International Center, Building 56# East 4th
Ring Middle Road, ChaoYang District, Beijing, 100025
Phone : +86-10-5165-9332
Fax : +86-10-5908-1381
CHINA:
HIROSE ELECTRIC (CHINA) CO., LTD. SHENZHEN BRANCH
Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre,
5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008
Phone : +86-755-8207-0851
Fax : +86-755-8207-0873
HONG KONG:
HIROSE ELECTRIC HONGKONG TRADING CO., LTD.
Room 1001, West Wing, Tsim Sha Tsui Centre, 66
Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong
Phone : +852-2803-5338
Fax : +852-2591-6560
http://www.hirose.com/hk/
TAIWAN:
HIROSE ELECTRIC TAIWAN CO., LTD.
103 8F, No.87, Zhengzhou Rd., Taipei
Phone : +886-2-2555-7377
Fax : +886-2-2555-7355
http://www.hirose.com/tw/
KOREA:
HIROSE KOREA CO.,LTD.
143, Gongdan 1-daero, Siheung-si,
Gyeonggi-do, 15084, Korea
Phone : +82-31-496-7000
Fax : +82-31-496-7100
http://www.hirose.co.kr/
SINGAPORE:
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE
03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C,
Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India
Singapore 079909
Phone : +91-12-660-8018
Phone : +65-6324-6113
Fax : +91-120-4804949
Fax : +65-6324-6123
http://www.hirose.com/sg/
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE
Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma
Gandhi (MG) Road, Bangalore 560 001, Karnataka, India
Phone : +91-80-4120 1907
Fax : +91-80-4120 9908
MALAYSIA:
THAILAND:
PENANG REPRESENTATIVE OFFICE
BANGKOK OFFICE (REPRESENTATIVE OFFICE)
73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn
Road, Yannawa, Sathorn, Bangkok 10120 Thailand
Lepas Penang, 11950, Malaysia
Phone : +66-2-686-1255
Phone : +604-648-5536
Fax : +66-2-686-3433
8
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 06/2018. Contents are subject to change without notice for the purpose of improvements.
