Push-on Lock Coaxial Connectors for Digital Broadcasting
Applications
PL71 Series
75Ω Up to 3 GHz
■Features
1. 20% downsized compared with
conventional 75 ohm BNC connectors.
2. Superior locking mechanism
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Our exclusive locking method keeps the
mating part in constant contact with the
electr ic reference plane (Top Touch),
ensuring high contact stability and reliability.
The construction is protected by the outer
shell.
3. Stable, stationary center contact structure
The stationary design protects the extremely
thin center conductor of this 75 ohm coaxial
cable from potential damage. Damage can
be caused by rotational forces during mating
and unmating.
4. Reliable at high frequencies
The high-frequency performance of the PL71
S e r i e s i s ve r y r e l i a bl e, w i t h V. S. W. R .
characteristics of a maximum of 1.3 at DC,
and up to 3 GHz, which is suitable for
3G-SDI broadcasting equipment.
■Applications
The PL71 Series is well suited for use in the digital cable television broadcasting industry. This 75 ohm
coaxial series can work together with BNC(75)Series and PO82M Series to configure a wide range of
functions, including interface connections, plug-in mounting, and wiring within devices.
Inner Wiring¤PL71 Series
Plug-in mounting¤PO82M Series
Interface→BNC(75)Series
Housing is compliant with IEC61076-4-101
¤PO21M Series
■Mating Chart
Plugs
Straight
PL71-P-πππ
Right-angle
PL71-LP-πππ
Receptacles
Straight
PL71-R-PC
Right-angle
PL71-LR-PC
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2014.11w
1
PL71 Series●Push-on Lock Coaxial Connectors for Digital Broadcasting Applications
Specifications
Nominal characteristic impedance
Frequency range : DC to 3 GHz
Ratings
Item
1. Contact resistance
2. Insulation resistance
3. Withstanding voltage
4. V.S.W.R.
5. Center contact
6. Insertion and
withdrawal forces
7. Durability(mating/
unmating with
corresponding plug)
: 75ø
Operating temperature range :-30°C to +85°C
Operating humidity
: RH 95% max.
Specification
6 mø max.
1,000 Mø min.
No flashover of insulation breakdown
1.3max.
0.5N min.
Conditions
100 mA max.
500 V DC
500 V AC / 1 minute
DC to 3 GHz
Measured with 0.49mm diameter pin gauge
9.8 N min.
Measured with the applicable mating pair
Contact resistance 6 mø max.
500 mating cycles
Frequency: 10 to 500 Hz, single amplitude of
2
0.75 mm, acceleration of 98m/s , 10 cycles in
each of the 3 axial directions
2
Acceleration of 490m/s , for a duration of 11
ms, sine half-wave waveform, 3cycles in each
8. Vibration
No electrical discontinuity of 1μs or longer
No damage, cracks, or parts dislocation
9. Shock resistance
10. Moisture resistance
Insulation resistance: 100 Mø min. (high humidity)
Insulation resistance: 1,000 Mø min. (dry)
240 hours at +25ç to +65ç and humidity of
80% to 96%
11. Temperature cycle
No damage, crack, or part dislocation
Temperature:-55ç ➝ +5ç to +35ç ➝ +85ç ➝ +5ç to +35ç
Time: 30 min. ➝ 5 min.max. ➝ 30 min.➝ 5 min.max.
5 cycles
12. Salt spray
No corrosion
5% salt water solution, 48 hours
Note: Some products may have different specifications from those shown above. Please confirm requirements before ordering.
Materials
Part
Materials
Finish
Remarks
Shell
Brass
Nickel plated
Male center contact
Brass
Gold plated
Female center contact Beryllium copper Gold plated
Insulator
PTFE
Flame retardant
Ordering information
PL71 q
2
w
e
: PL71
q Series name
Connector
type
w
P
: Straight plug
LP
: Right-angle plug
R
: Straight receptacle
LR
: Right-angle receptacle
Applicable
cable(plug)
or board
e
1.5C
: 1.5C-QEV.CW
1.5CW
: 1.5C-QEW.CW
PC
: DIP mounting
Plugs
Ø7
Ø6.5
Straight
20.7
All dimensions:mm
HRS No.
Applicable cable
PL71-P-1.5CW(40)
334-0001-5 40
1.5C-QEW.CW
PL71-P-1.5CV-1(40)
334-0069-9 40
1.5C-QEV.CW
RoHS
Yes
Right angle
14.4
Ø6.5
6.7
14
All dimensions:mm
Part No.
HRS No.
Applicable cable
PL71-LP-1.5CW(40)
334-0006-9 40
1.5C-QEW.CW
PL71-LP-1.5C(40)
334-0007-1 40
1.5C-QEV.CW
RoHS
Yes
Receptacles
Straight
PCB mounting pattern
5.08±0.05
2.54±0.05
4∞Ø
1.2±
0.1
Ø0.8 +0
.1
2.54±0.05
5.08±0.05
Ø3.95
8.5
5.08
5.7
Ø0.7
2.9
All dimensions:mm
Part No.
HRS No.
RoHS
PL71-R-PC(40)
334-0011-9 40
Yes
Right angle
5.7
10.2
5.08±0.05
4∞Ø
1.2±
Ø0.8 +0
.1
2.54±0.05
Ø0.7
5.08
5.08±0.05
Ø3.95
4.65
7.65
2.54±0.05
2.5
Part No.
All dimensions:mm
Part No.
HRS No.
RoHS
PL71-LR-PC(40)
334-0016-2 40
Yes
3
High Frequency Characteristics of 75Ω Hirose product series
BNC(75) Series
2
1.9
100
1.8
V.S.W.R.
1.7
1.6
1.5
1.4
1.3
BNC(75)-BPJ-1.5CV-π
BNC(75)-BPJ-1.5CV-π
1.2
1.1
1
1
1.5
2
2.5
3
2
2.5
3
2
2.5
3
2
2.5
3
Frequency[GHz]
PL71 Series
2
1.9
100
1.8
V.S.W.R.
1.7
1.6
1.5
1.4
1.3
BNC(75)-BPJ-1.5CV-π
PL71-LP-1.5C(40)
1.2
1.1
1
1
1.5
Frequency[GHz]
PL75 Series
2
1.9
100
1.8
V.S.W.R.
1.7
1.6
1.5
1.4
1.3
BNC(75)-BPJ-1.5CV-π
PL75-LP-1.5CV
1.2
1.1
1
1
1.5
Frequency[GHz]
H.FL75 Series
2
1.9
1.8
H.FL75-2LPG-084Nπ-L
V.S.W.R.
1.7
100
1.6
1.5
1.4
1.3
1.2
1.1
BNC(75)J-H.FLJ-BPA(40)
1
1
1.5
Frequency[GHz]
4
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 11/2014. Contents are subject to change without notice for the purpose of improvements.
很抱歉,暂时无法提供与“PL71-LR-PC(40)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+244.618821+30.59142
- 20+214.1766820+26.78441
- 40+198.3105640+24.80023
- 100+191.69975100+23.97350
- 260+181.12344260+22.65085
