H.FL-R-SMT(01)
H.FL-R-SMT(01)
    HRS(广濑)
H.FL-R-SMT(01) 数据手册
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. H.FL Series SMT Low Profile Small Coaxial Connector Sep. 2021 H.FL Series/SMT Low Profile Small Coaxial Connector Features 1. Small Size, Low Profile 6.95 3 Mated height of the receptacle and right angle plug is only 3mm. H.FL-LP-DFS111 H.FL-R-SMT 3 6.45 H.FL-LP-DFS111-A H.FL-R-SMT H. FL- LP- DFS111- A, H. FL- R- SMT 2.9 8.95 4.5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. H. FL- LP- DFS111, H. FL- R- SMT H. FL- LP- DFS11- A and H. FL- R- SMT PCB Mounting Space 2. Ultra- fine Coaxial ( Fluorinated Resin Insulated) Cables Compatible with φ1. 48mm and φ1. 32mm size coaxial cables for smooth and easy installment. 3. RF Performance V. S. W. R. DC to 3GHz : 1. 3 Max. 4. Supports Automatic Mounting Tape and Reel packaging allows for pick- andplace mounting. 2 H.FL Series/SMT Low Profile Small Coaxial Connector 5. Clear, Tactile Lock Compact connector with clear tactile lock enables reliable mating. 6. RoHS2 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Product Specifications Nominal Characteristic Impedance 50 Ω Operating Temperature -40 to +90℃(90% RH Max.) Rated Voltage 60V AC StorageTemperature Range -30 to +70℃(90% RH Max.) Frequency Range DC to 3GHz Item Specification Conditions Contact Resistance Center : 20m Ω Max. Outer : 10m Ω Max. 10mA Max. Insulation Resistance 500M Ω Min 250V DC Withstanding Voltage No flashover or insulation breakdown. 300V AC for 1 min. V.S.W.R.* 1.3 Max. DC to 3GHz Female Contact Retention Force 0.2N Min. Measured with φ 0.475 pin gauge Mating Durability (With Corresponding Plug) Contact Resistance : 25m Ω Max. (Center) 15m Ω Max. (Outer) 50 cycles Vibration No electrical discontinuity of 1μ s min. No damage, cracks or parts dislocation. Frequency : 10 to 100Hz, single amplitude of 1.5mm, acceleration of 59m/s2, for 5 cycles in the direction of each of the 3 axis. Shock No electrical discontinuity of 1μ s min. No damage, cracks or parts dislocation. Acceleration of 735m/s2, 11ms duration, sine half-wave waveform, 3 cycles in each of 3 axes. Humidity (Steady State) No damage, cracks or parts dislocation. Insulation Resistance : 10M Ω Min. (High Temperature) 500M Ω Min. (When Dry) 96 hours at temperature of 40℃ and humidity of 95%. Thermal Shock No damage, cracks or parts dislocation. Contact Resistance : 25m Ω Max. (Center) 15m Ω Max. (Outer) Temperature : -40℃ → +5 to +35℃ → +90℃ → +5 to +35℃ Time : 30min. → 5min. → 30min. → 5min. 5 cycles Salt Spray No significant corrosion 5% salt water solution, 48 hours * V. S. W. R. Measurement System The above V. S. W. R. standard values were measured using the measurement system shown below. Network Analyzer Test Set Test Port Test Port Cable D.U.T Termination Note 1 : Cable type connectors were measured with SMA conversion adapters attached to both ends of the harness product of a suitable 100cm cable. Note 2 : Board type connectors were mounted to a 50φ glass epoxy board and measurements were conducted with SMA conversion adapters attached. 3 H.FL Series/SMT Low Profile Small Coaxial Connector Materials / Finish Part Material Finish Flame Retardance Shell Phosphor Bronze Silver Plated - Male Center Contact Brass Female Center Contact Phosphor Bronze Insulator - Gold Plated Plug PBT Receptacle LCP Black - UL94V-0 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ● Plug H.FL - LP - DFS111 - A(01) ❶ ● Female ❷ ❸ ❹ ❻ Terminal H.FL - LP Female Terminal ❶ ❷ ❸ ● Receptacle H.FL - R - SMT (C) (10) ❶ ❷ ❸ ❺ ❻ ❶ Series Name H.FL ❹ Plug Type (Note 1) ❷ Connecter Type LP :Right Angle Plug R : Receptacle ❺ Receptacle (C) : With Suction Cap None : Without Suction Cap ❸ Compatible Cable or Board Mounting Method Plug DFS111 : φ 1.48 Cable A32 : φ 1.32 Cable Female Terminal : Female Terminal for Plug ❻ Packing Types (Note 2) (01) : Packing(100pcs per pack) (10) : Reel Packing(2,500pcs per Reel) Receptacle SMT : Printed Circuit Board Surface Mount Type Note 1 : Refer to the "Right Angle Plug" section for plug specifications. Note 2 : Specification (10) is only available for the receptacle. 4 (A): Without Plug Ferrule None : With Plug Ferrule H.FL Series/SMT Low Profile Small Coaxial Connector ● How to Designate Plug Cable Assembly Dimensions The dimension specifications of the H. FL Series harness are as follows. [ Single-ended Cable Assembly ] [ Double-ended Cable Assembly ] L(mm) L(mm) Ordering information Note : Designate the dimensions from the center of the connector for both single-ended and double-ended cable assemblies. (Please write length L in mm.) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● Cable Assembly Product Number Structure H.FL - 2LP (A) - # - A -(L) ❶ ❷ ❸ ❹ ❺ ❶ Series Name H.FL ❸ Plug Type (Note) ❷ Assembly Type LP : Single Ended 2LP : Double Ended ❹ Cable Type ❺ Total Length (mm) Note : Refer to the "Right Angle Plug" section for plug specifications. ● Standard Tolerances for (L) Total Length(mm) Standard Tolerance(mm) 35 ≦ L ≦ 200 ±4 200 < L ≦ 500 ±8 500 < L ≦ 1000 ± 12 1000 < L ± 1.5% Note : The shortest length is L = 35mm. 5 (A): Without Plug Ferrule None : With Plug Ferrule 111, FHSB, 084* : φ 1.48 Cable 066N*, 0733 : φ 1.32 Cable L length (mm) H.FL Series/SMT Low Profile Small Coaxial Connector Right Angle Plug We accept cable assembly orders for the plug as well. Ferrule Attachments A Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Female Terminal Sold Separately H.FL-LP-DFS111(01) φ1.48 Cable A Female Terminal Sold Separately H.FL-LP-DFS111-A(01) φ1.48 Cable Item Right Angle Plug Shell (φ 1.48 Cable) Right Angle Plug Shell (φ 1.32 Cable) Female Terminal Part No. H.FL-LP-DFS111(01) H.FL-LP-DFS111-A(01)(Note) HRS No. Dimension A CL0331-0503-4-01 CL0331-0507-5-01 (6.95) (6.45) H.FL-LP-A32-A(01) (Note) CL0331-0508-8-01 (6.45) H.FL-LP Female Terminal CL0331-0511-2-00 - Note : H.FL-LP-DFS111-A(01) and H.FL-LP-A32-A(01) do not require a ferrule. (Reduces cable assembly time) 6 Purchase Unit 100pcs per pack 10,000pcs per reel H.FL Series/SMT Low Profile Small Coaxial Connector Receptacle GND GND GND SIG φ0.5 3-0.8 1.5 Max. 5 4.5 0.6 4.5 4 Part No. HRS No. Purchase Unit H.FL-R-SMT(01) CL0331-0521-6-01 100pcs per pack H.FL-R-SMT(10) CL0331-0521-6-10 2,500pcs per reel Note : Tolerance value of mold resin applied to center contact. 1±0.05 2.8±0.05 ●Recommended PCB Mounting Pattern 2±0.05 GND 3±0.05 3×1.2±0.05 GND GND SIG 1.5±0.05 1.2±0.05 3.1±0.05 3.1±0.05 Receptacle With Suction Cape Final Product Overview Diagram φ0.5 Cap 5 4.5 0.6 3×0.8 (Note 1) 1.5 Max. 1.7 φ2.4 4.5 4 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Note) 1.7 φ2.4 Part No. H.FL-R-SMT(C)(10) HRS No. Purchase Unit CL0331-0522-9-10 2,500pcs per reel Note 1 : Tolerance value of mold resin applied to center contact. Note 2 : This product comes with a suction cap compatible with any automated mouting machine. The receptacle cannot be mated with the cap on, so please remove before use. 7 H.FL Series/SMT Low Profile Small Coaxial Connector Conversion Adapter SMA Conversion Adapter (Mated Portion- H.FL Side : Jack, SMA Side : Plug) (11.7) 8HEX Part No. HRMP-H.FLJ(40) HRS No. Purchase Unit CL0311-0232-4-40 20pcs per pack Note : The mating portion on the H.FL side does not have a locking mechanism, so it cannot be used for anything other than performance measurement. SMA Conversion Adapter (Mated Portion - H.FL Side : Plug, SMA Side : Jack) 6 14.2 (4.05) 5.6 φ6.35 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. φ2.3 2.4 1/4-36UNS-2A Part No. HRMJ-H.FLP-3(40) HRS No. Purchase Unit CL0311-0264-0-40 20pcs per pack Note : The mating portion on the H.FL side does not have a locking mechanism, so it cannot be used for anything other than performance measurement. 8 H.FL Series/SMT Low Profile Small Coaxial Connector Inspection Receptacle Receptacle for testing the conduction, withstanding voltage, etc. of the cable assembly. 13.1 (8.1) 5 1 φ2.3 7HEX Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. M5×0.5 Part No. H.FL-R-1 HRS No. Purchase Unit CL0331-0516-6-00 20pcs per pack Note : Product cannot be used for purposes other than conduction or withstanding voltage inspection because there is no lock on the mating portion. 9 H.FL Series/SMT Low Profile Small Coaxial Connector Embossed Carrier Tape Dimensions 1.75 Dimensions of the Embossed Carrier Tape for H. FL- R- SMT( 10) are shown below. φ1.5 Central Contact 4 8 (2.4) Unreeling Direction Reel Dimensions φ330 13.5 A A 2 3 φ1 φ2 1 Contact Extraction Tool 5 φ1 3.3 6 Tool for Unmating. 100 40 3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 12 5.5 2 Part No. H.FL-LP-N HRS No. Purchase Unit CL0331-0551-7-00 1pc per pack 10 H.FL Series/SMT Low Profile Small Coaxial Connector Usage Precautions 1. Plugs 1. Mating/ Unmating ( 1)To disconnect the connector, insert the extraction tool ( H. FL- LP- N) under the connector flange.   Pull in a perpendicular direction in line with the connector' s mating axis.   Do not unmate the plug by pulling on the cable, this can damage the connector performance. ( 2)When mating, align the mating axes between the receptacle and cable assembly, and insert the cable assembly   downward and perpendicular into the receptacle.   Do not insert the cable assembly at a slanted angle. 3N Max. 5N Max. H.FL-LP* H.FL-R-SMT 3N Max. 3. Precautions Do not use excessive prying to mate or un- mate the connectors as it may lead to damage. 2. Receptacles [℃] Heating Peak 250℃ 10 Seconds 260 (1) Recommended Reflow Temperature Profile Temperatue of Top of Component Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2. Tolerable load to a cable after mating Once the connector has been mated do not apply forces exceeding the values in the diagram below. 240 230℃ 220℃ 220 200 180 160 140 120 100 80 50 Seconds or Less 120 Seconds or Less 60 Seconds or Less Time 1. Temperature refers to the temperature of the PCB surface at the terminal leads. 2. Reflow soldering should be performed at a printed circuit surface temperature of 250℃ Max. 3. The temperature profile may vary depending on board size, solder used and solder thickness. (2) Recommended Manual Soldering Conditions Manual soldering : 350℃ for 5 seconds (3) Recommended Metal Mask Thickness 0.1mm to 0.15mm (4) Reflow Cycles 2 times 11 H.FL Series/SMT Low Profile Small Coaxial Connector 3. Operating Environment and Storage Conditions Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1. Operation Environment This product was designed for use in a normal environment. Please be advised that using this product in the environments described below may result in discoloration and other types of degradation. ・Exposure to excessive amounts of fine particles and dust. ・Regions/ areas with a high concentration of gases like sulfur dioxide, hydrogen sulfide and nitrogen dioxide. ・Areas with drastic temperature changes, such as locations near a heater. 2. Storage conditions Store this product in Hirose' s packaging or similar conditions. Temperature : - 10 to + 40℃ Humidity : 85% or less ( recommended storage conditions) We recommend the product be used within six months from delivery. Products that have been stored beyond the recommended storage period need to be tested for mounting and solderability before use. 3. Silver Plating Discoloration Discoloration occurs only on the plating surface. Since the contact portion is wiped, there is no effect on the electrical contact. 12 H.FL Series/SMT Low Profile Small Coaxial Connector Standard Connectors the Connect with H.FL SMA Cable Type Straight Plug 15 1/4-36UNS-2B Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● 8HEX Part No. HRS No. Applicable Cable HRM-200-066PBN(40) CL0323-0791-6-40 φ 1.32 Cable HRM-200-088PBN(40) CL0323-0800-5-40 φ 1.48 Cable HRS No. Applicable Cable HRM-200-066JBN(40) CL0323-0793-1-40 φ 1.32 Cable HRM-200-088JBN(40) CL0323-0801-8-40 φ 1.48 Cable ● Straight Jack 17 4.5 8 1/4-36UNS-2A 8HEX Part No. 13 H.FL Series/SMT Low Profile Small Coaxial Connector Panel Jack (4 Screw Type) 9.55 1.7 12.7 8.64 1/4-36UNS-2A 4-φ2.6 φ6.4 17 Part No. HRS No. Applicable Cable HRM-200-066PJ4BN(40) CL0323-0796-0-40 φ 1.32 Cable HRM-200-088PJ4BN(40) CL0323-0803-3-40 φ 1.48 Cable HRS No. Applicable Cable HRM-200-066PJ2BN(40) CL0323-0788-1-40 φ 1.32 Cable HRM-200-088PJ2BN(40) CL0323-0802-0-40 φ 1.48 Cable ● Panel Jack (2 Screw Type) 17 9.55 1.7 1/4-36UNS-2A 8 2×φ2.6 φ6.4 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● Part No. 14 H.FL Series/SMT Low Profile Small Coaxial Connector Panel Jack (Nut Type) 1.5 17 11 1/4-36UNS-2A 8HEX 5.85 φ10 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● Part No. HRS No. Applicable Cable HRM-200-066BPJBN(40) CL0323-0798-5-40 φ 1.32 Cable HRM-200-088BPJBN(40) CL0323-0804-6-40 φ 1.48 Cable Mounting Hole Dimensions 5.9 +0.1 0 φ6.4 +0.1 0 15 H.FL Series/SMT Low Profile Small Coaxial Connector Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. RP-SMA Cable Type ● Straight Jack 17 4.5 8 8 HEX 1/4-36UNS-2A Part No. HRS No. Applicable Cable SMA(R)-200-066JBN CL0323-0931-3-00 φ 1.32 Cable SMA(R)-200-088JBN CL0323-0904-0-00 φ 1.48 Cable ● Panel Jack (4 Screw Type) 17 12.7 9.55 1.7 8.64 1/4-36UNS-2A .6 φ2 4× Part No. HRS No. Applicable Cable SMA(R)-200-066PJ4BN CL0323-0932-6-00 φ 1.32 Cable SMA(R)-200-088PJ4BN CL0323-0934-1-00 φ 1.48 Cable 16 H.FL Series/SMT Low Profile Small Coaxial Connector ● Panel Jack (2 Screw Type) 17 8 9.55 12.2 1/4-36UNS-2A .6 φ2 2× Part No. HRS No. Applicable Cable SMA(R)-200-066PJ2BN CL0323-0933-9-00 φ 1.32 Cable SMA(R)-200-088PJ2BN CL0323-0935-4-00 φ 1.48 Cable HRS No. Applicable Cable SMA(R)-200-066BPJBN CL0323-0902-5-00 φ 1.32 Cable SMA(R)-200-088BPJBN CL0323-0901-2-00 φ 1.48 Cable ● Panel Jack (Nut Type) 17 1.5 8 HEX 11 5.85 φ10 1/4-36UNS-2A Part No. Mounting Hole Dimensions 4+ 0 0 .1 5.9 +0.1 0 φ 6. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.7 17 H.FL Series/SMT Low Profile Small Coaxial Connector ■Applicable Tools for SMA and RP-SMA Cable Type Connectors Part No. HRM-200-066PBN(40) HRM-200-088PBN(40) HRM-200-066JBN(40) HRM-200-088JBN(40) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HRM-200-066PJ4BN(40) HRM-200-088PJ4BN(40) HRM-200-066PJ2BN(40) HRM-200-088PJ2BN(40) HRM-200-066BPJBN(40) HRM-200-088BPJBN(40) SMA(R)-200-066JBN SMA(R)-200-088JBN SMA(R)-200-066J4BN SMA(R)-200-088J4BN SMA(R)-200-066PJ2BN SMA(R)-200-088PJ2BN SMA(R)-200-066BPJBN SMA(R)-200-088BPJBN Wiring Tool HRS No. Overview HRM-200/SO-MD CL0902-3192-6-00 Cord Soldering Cradle HRM-200/SO-MD2 CL0902-3199-5-00 Terminal Soldering Cradle HRM-200-PBN/CV-MD CL0902-3198-2-00 Cord Press-fit Tool HRM-200/SO-MD CL0902-3192-6-00 Cord Soldering Cradle HRM-200/SO-MD2 CL0902-3199-5-00 Terminal Soldering Cradle HRM-200-JBN/CV-MD CL0902-3195-4-00 Cord Press-fit Tool HRM-200/SO-MD CL0902-3192-6-00 Cord Soldering Cradle HRM-200/SO-MD2 CL0902-3199-5-00 Terminal Soldering Cradle HRM-200-PJ4BN/CV-MD CL0902-3197-0-00 Cord Press-fit Tool HRM-200/SO-MD CL0902-3192-6-00 Cord Soldering Cradle HRM-200/SO-MD2 CL0902-3199-5-00 Terminal Soldering Cradle HRM-200-PJ2BN/CV-MD CL0902-3196-7-00 Cord Press-fit Tool HRM-200/SO-MD CL0902-3192-6-00 Cord Soldering Cradle HRM-200/SO-MD2 CL0902-3199-5-00 Terminal Soldering Cradle HRM-200-BPJBN/CV-MD CL0902-3194-1-00 Cord Press-fit Tool HRM-200/SO-MD CL0902-3192-6-00 Cord Soldering Cradle HRM-200/SO-MD2 CL0902-3199-5-00 Terminal Soldering Cradle HRM-200-JBN/CV-MD CL0902-3195-4-00 Cord Press-fit Tool HRM-200/SO-MD CL0902-3192-6-00 Cord Soldering Cradle HRM-200/SO-MD2 CL0902-3199-5-00 Terminal Soldering Cradle HRM-200-PJ4BN/CV-MD CL0902-3197-0-00 Cord Press-fit Tool HRM-200/SO-MD CL0902-3192-6-00 Cord Soldering Cradle HRM-200/SO-MD2 CL0902-3199-5-00 Terminal Soldering Cradle HRM-200-PJ2BN/CV-MD CL0902-3196-7-00 Cord Press-fit Tool HRM-200/SO-MD CL0902-3192-6-00 Cord Soldering Cradle HRM-200/SO-MD2 CL0902-3199-5-00 Terminal Soldering Cradle HRM-200-BPJBN/CV-MD CL0902-3194-1-00 Cord Press-fit Tool 18 H.FL Series/SMT Low Profile Small Coaxial Connector ■ Cable Assembly Specifications Designate and order the length specification of the H. FL Series and SMA or RP- SMA double- ended assembly based on the below length specification diagram. Lmm 15 A Lmm Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 17 12.5 A 9.55 Lmm 1.7 7.45 9.55 1.7 7.45 11 A Lmm 6 A Lmm 1.5 A Note : The shortest length is L = 50mm Cable φ 1.48 φ 1.32 Plug A H.FL-LP-DFS111(01) 6.95 H.FL-LP-DFS111-A(01) 6.45 H.FL-LP-A32-A(01) 6.45 19 H.FL Series/SMT Low Profile Small Coaxial Connector While Taking into Consideration Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 9/ 2021. Contents are subject to change without notice for the purpose of improvements. 20
H.FL-R-SMT(01) 价格&库存
很抱歉,暂时无法提供与“H.FL-R-SMT(01)”相匹配的价格&库存,您可以联系我们找货
