100600
100600
    APEM(埃斐)
    VM DESKTOP USB MULTIFUNC CONT
100600 数据手册
CH Products VM Desktop (100-600) USB Video Management Desktop Controller with Tactile Buttons ■ 3 axes joystick for P/T/Z control ■ 27 tactile buttons ■ Jog/shuttle dial ■ 10-bit resolution ■ USB 1.1 HID compliant game controller device ■ Easy to install and operate ■ Functions determined by controlled application CH Products’ VM Desktop provides advanced features such as 3 axes Hall effect Joystick, jog/shuttle dial, 27 user-defined tactile pushbuttons and USB 1.1 interface for powerful control of video surveillance, recording and video management functions. The VM Desktop is designed for critical security installations including airports, casinos, transit stations and stadiums. The VM Desktop’s three axes joystick provides intuitive control for pan, tilt, and zoom camera functions. The noncontacting Hall effect technology is durable and will provide greater than 10 million operations. In supported applications, the 360 degree job knob may be used for editing frame-by-frame and the spring-loaded shuttle ring for variable forward and reverse speed control of captured sequences. CH Products’ Video Management controller features 27 programmable tactile pushbuttons. The numeric keypad module is ideal for camera selection, presets, and touring functions. Button labels and legends may be customized for specific applications. Featuring USB 1.1 interface, the VM Desktop integrates seamlessly with software applications supporting USB joystick inputs via Microsoft DirectX. No device driver or SDK is required, the VM Desktop is recognized as a standard HID “game controller” 4 axes/29 button joystick. The VM Desktop’s axes and buttons are programmable and function assignment is dependant on the controlled application. The VM Desktop features a jog/shuttle dial for total control over digital video monitoring and management. Note: All specifications subject to change. www.chproducts.com CH Products Technical Specifications CH Products Video Management Controller (100-600) Joystick performance: Hall-effect three axes joystick X/Y/Z for positioning control Joystick travel: X/Y axis +/- 18˚, Z axis +/- 40˚ Centering: single spring, omni-directional Joystick shaft: stainless steel Joystick boot: neoprene Joystick handle: glass filled nylon Jog/shuttle performance: Spring loaded shuttle ring travel +/-40˚ Smooth action knob rotates 360˚ Pushbutton performance: 27 programmable pushbuttons Tactile feedback Pushbutton material: silicon Desktop housing: High impact ABS Power: Via USB interface (5V DC) Consumption 1A Operating conditions: -25 to +85˚C (-13 to +185˚F) Interface: USB port Connects directly to workstation PC Uses standard DirectX HID drivers Connectors: USB A Cable Length: 2m; 6ft. 6.8in. Systems integration support: Windows 7, Vista, XP, 2000 Supported protocols: USB HID 1.1 game controller Direct X (Gaming Control) Joystick: Thee HID axes Jog/shuttle: One HID axis, two HID buttons Pushbuttons: 27 HID buttons Dimensions: 9”x 11” x 4 3/8 “ Approvals*: EN 55024:1998, EN 55022, FCC Part 15 Subpart B Class B RoHs compliant * - Approvals are pending 96.77 3.81 58.17 2.29 110.74 4.36 165.10 6.50 279.40 11.00 228.35 8.99 Notes: - Dimensions are in mm/in - Supplied individually boxed with instruction booklet Note: All specifications subject to change. www.chproducts.com
100600 价格&库存
很抱歉,暂时无法提供与“100600”相匹配的价格&库存,您可以联系我们找货
  • 1+15520.492941+2000.89093
  • 5+13532.385555+1744.58554
