Intova Sport HD Camera
Page 1 of 2
Small and compact, SP1 offers full 1080p High Definition Video with a 140
degree wide angle lens. This design allows the maximum view angle without
the significant distortion found in wider lens angles. SP1 supports Micro SD
card up to 32 GB (Class 6 or 10 recommended). Intova’s unique and patented
Unibody design builds the electronics directly into the compact housing. The
housing floats and is constructed of rugged polycarbonate injected with UV.
The lens port receives a proprietary UV treatment to increase scratch resistance
and reduce reflection. Its flat design allows seamless operation above or below
water. Waterproof to 200 feet, the housing includes buttons for full camera
control in any environment. (Important: to maintain waterproof seal, be sure to
clean and remove debris from O-rings and lightly apply silicone grease before
use.
Item code 30025
SP1’s high quality LCD screen acts as both a viewfinder and playback monitor.
To save battery life, the LCD can be turned off when not in active use. SP1
utilizes a standard ¼” tripod thread to fit a wide range of Intova mount
accessories. Boxed set includes Sport HD camera (model# SP1), USB cable,
TV cable, 8 inch lanyard, and user manual on mini CD.
Features:
All inclusive unit means no more buying back packs to be able to have an
LCD to view your videos
Waterproof to 200 feet means water hazards are a thing of the past (at
least for the camera!)
The use of a Micro SD card enables you to record video and then swap
the card to your smart phone for instant uploading to the web!
Application Ideas:
Aerial video and photographs from the ELEV-8 quadcopter
RC Boats/Submarines photography
Sport photography
Specifications:
Video Resolution: 1080p HD (30fps), 720p HD (30fps), WVGA1
(60fps), WVGA (30fps), VGA (30fps)
Video Codec: H.264
Video File Type: MOV (Quick Time Movie)
Photo Resolution: 12MP, 8MP, 5MP, 3MP
Photo File Type: JPEG
Digital Zoom: All modes except 1080p
Lens: 140 degree wide angle, aperture f2.4
Depth Rating: Waterproof to 200 ft / 60 m
Monitor: 1.5" TFT LCD
Power: Built in 1400mAh Li-ion rechargeable battery
Battery Life: Recording time 2.5 hrs @ 1080p with LCD off
Video/Still image flip: Flips image over when camera is held upside
down
Burst Mode: 3,5 or 10 photos
Effects: Art, Sepia, Negative, Monochrome, Vivid
Memory: Supports micro SD Card up to 32 GB, Class 6 or 10
recommended
Ports: TV Mini out, Mini USB
Flotation: Camera Floats
Housing: Polycarbonate with UV injection, Patented Unibody design
Page 2 of 2
Dimensions: 2.8 x 3.3 x 2.4 inches (7 x 8.4 x 6 cm)
Weight: 6.0 oz / 170 g
Note: To maintain waterproof seal, be sure to clean and remove debris from Orings and lightly apply silicone grease before use.
Alternate View:
Click through for a close-up.
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/30025/List/0/SortField/4/ProductID/866/Defaul... 4/10/2013
很抱歉,暂时无法提供与“30025”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2373.532381+307.01649
