DuraPoint® Data Sheet
DuaPoint® OEM Module
Features and Benefits
Description
• Completely sealed
• Totally submersible
• No moving parts
• Easy to use
• Safe & reliable
• Meets toughest NEMA
DuraPoint® - The World's Toughest "Mouse"
Spill on it, smash it, soak it, drop it, whatever! DuraPoint, constructed of stainless steel and
heavy rubber, is the world's only fully sealed and submersible mouse. DuraPoint is
impervious to liquids and contaminants, earning it the toughest industrial equipment ratings
- NEMA 4x, 6P and 13.
standards
Potted solid, DuraPoint is resistant to vibration, shock, ESD, and EMI. And unlike
conventional mice and trackballs, DuraPoint has no moving parts to break, wear out, or be
cleaned - it's maintenance free! Best of all, DuraPoint is easy and intuitive to use. A simple
touch on the mouse button give simultaneous control of both cursor direction and speed.
DuraPoint is the ideal, computer pointing solution for factories, warehouses, service bays,
operating rooms, field use, and yes, even dirty desktops.
P/N: PDS-94-00054-B
Human-Machine Interface Solutions for a Connected World
DuraPoint® OEM Module
Device Characteristics
Compatibilities
Physical
Performance
Environmental
Contact Us
Hardware Interface
RS-232 serial port, PS/2® mouse port
Operating System Compatibilities
PS/2 compatible operating systems
Serial Data Format
Emulates Microsoft two-button mouse
Power Consumption
Less than 10mA @ 5V DC
Physical Size
5.0” x 4.25” x1.0” (12.8 x 10.8 x2.5cm)
Weight
2.0lb (900 grams) including cable
Primary Materials
Stainless steel, silicone rubber buttons, and silicone potting material
Cables
STANDARD - 6 ft. (1.8m) shielded cable w/ 9-pin D-sub serial connector
(PS/2 adapter included)
ENCLOSURE MOUNT - Per standard cable, but includes in-line, low-profile
disconnect for use with enclosure cord grips
Mounting Options
Can be mounted horizontally (desktop) or vertically (panel mount).
Four 10-32 inserts are provided on underside for mounting security
Cursor Directional Control
Continuous 360º control
Cursor Speed Control
Continuously variable - proportional to applied pressure
Lifetime
Greater than 10 million cycles
Temperature
OPERATING: 32ºF (0ºC) to 140ºF (60ºC)
STORAGE: -40ºF (-40ºC) to 185ºF (85ºC)
Liquires/Humidity Resistance
Meets NEMA 4X, 6P and 13 standards - completely sealed & submersible
Particulate/Dust Resistance
Meets NEMA 12 standard - completely sealed against dust & particulates
Chemical Resistance
Bleach, soap, alcohol, saline, Cidex 7...
Vibration
OPERATING: 0.5G peak acceleration, 5-500 Hz
ESD
STORAGE: 5.0G peak acceleration, 5-500Hz
1 year limited warranty
IEC 801-2, Level 3
United States Corporate Office
Interlink Electronics, Inc.
31248 Oak Crest Drive
Suite 110
Westlake Village, CA 91361 USA
Phone: +1 (805) 484-8855
Fax: +1 (805) 484-9457
www.interlinkelectronics.com
Sales & Support: sales@iefsr.com
很抱歉,暂时无法提供与“54-65591”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3926.705021+507.97924
