54-99125
54-99125
    INTERLINKELECTRONICS
    DURAPOINT,MF,VP2502MSOFTCOMP
54-99125 数据手册
DuraPoint® Data Sheet DuaPoint® OEM Module Features and Benefits Description • Completely sealed • Totally submersible • No moving parts • Easy to use • Safe & reliable • Meets toughest NEMA DuraPoint® - The World's Toughest "Mouse" Spill on it, smash it, soak it, drop it, whatever! DuraPoint, constructed of stainless steel and heavy rubber, is the world's only fully sealed and submersible mouse. DuraPoint is impervious to liquids and contaminants, earning it the toughest industrial equipment ratings - NEMA 4x, 6P and 13. standards Potted solid, DuraPoint is resistant to vibration, shock, ESD, and EMI. And unlike conventional mice and trackballs, DuraPoint has no moving parts to break, wear out, or be cleaned - it's maintenance free! Best of all, DuraPoint is easy and intuitive to use. A simple touch on the mouse button give simultaneous control of both cursor direction and speed. DuraPoint is the ideal, computer pointing solution for factories, warehouses, service bays, operating rooms, field use, and yes, even dirty desktops. P/N: PDS-94-00054-B Human-Machine Interface Solutions for a Connected World DuraPoint® Data Sheet DuraPoint® OEM Module Device Characteristics Compatibilities Physical Performance Environmental Contact Us Hardware Interface RS-232 serial port, PS/2® mouse port Operating System Compatibilities PS/2 compatible operating systems Serial Data Format Emulates Microsoft two-button mouse Power Consumption Less than 10mA @ 5V DC Physical Size 5.0” x 4.25” x1.0” (12.8 x 10.8 x2.5cm) Weight 2.0lb (900 grams) including cable Primary Materials Stainless steel, silicone rubber buttons, and silicone potting material Cables STANDARD - 6 ft. (1.8m) shielded cable w/ 9-pin D-sub serial connector (PS/2 adapter included) ENCLOSURE MOUNT - Per standard cable, but includes in-line, low-profile disconnect for use with enclosure cord grips Mounting Options Can be mounted horizontally (desktop) or vertically (panel mount). Four 10-32 inserts are provided on underside for mounting security Cursor Directional Control Continuous 360º control Cursor Speed Control Continuously variable - proportional to applied pressure Lifetime Greater than 10 million cycles Temperature OPERATING: 32ºF (0ºC) to 140ºF (60ºC) STORAGE: -40ºF (-40ºC) to 185ºF (85ºC) Liquires/Humidity Resistance Meets NEMA 4X, 6P and 13 standards - completely sealed & submersible Particulate/Dust Resistance Meets NEMA 12 standard - completely sealed against dust & particulates Chemical Resistance Bleach, soap, alcohol, saline, Cidex 7... Vibration OPERATING: 0.5G peak acceleration, 5-500 Hz ESD STORAGE: 5.0G peak acceleration, 5-500Hz 1 year limited warranty IEC 801-2, Level 3 United States Corporate Office Interlink Electronics, Inc. 31248 Oak Crest Drive Suite 110 Westlake Village, CA 91361 USA Phone: +1 (805) 484-8855 Fax: +1 (805) 484-9457 www.interlinkelectronics.com Sales & Support: sales@iefsr.com
54-99125 价格&库存
很抱歉,暂时无法提供与“54-99125”相匹配的价格&库存,您可以联系我们找货
