Keyspan by Tripp Lite Presentation Pro Wireless
Remote Control, Black, 65-ft. Range
MODEL NUMBER: PR-PRO4
Highlights
65-ft. RF range
Gyroscopic technology
2-button mouse
Laser pointer
Audio controls
Multi-switch modes (On/Off,
Presentation & Gamer)
System Requirements
Windows:An available USB port,
Windows
98SE/Me/2000/XP/Vista/Windo
ws 7
MAC: An available USB port,
MAC OS 10.6.6 or later (F5
function key limited to
presentation exit only)
Presentation Software: This
remote control is designed for
use with PowerPoint. It will also
work with other presentation
programs that use the same
keystrokes as PowerPoint. The
remote supports both Slide
Show view and Presenter view
within PowerPoint.
Volume Control: Volume control
buttons adjust system volume
on a PC.
Projectors: This remote is
compatible with all brands of
projectors.
Description
The Presentation Pro Remote Gyro allows you to control your mouse movement with a sweep of your
hand. Its micro receiver has a storage place in the remote for easy transport. With RF, laser, mouse and
audio controls in one sleek remote, it is an ideal tool for presenters and lecturers. Offering a range of 65
feet, the Presentation Remote Pro Gyro covers meeting rooms and lecture halls - and the gamer mode
will allow the remote to be used in Window based flight simulator and similar games. There is no software
to install - just plug the receiver into the USB port on your PC and it works within seconds.
Features
Package Includes
RF Connectivity: Works up to 65-ft. - even through walls and furniture.
Gyroscopic Mouse Control: Provides complete two-button mouse capabilities.
Remote with USB receiver
Owner's manual
Two AAA batteries for remote
Travel pouch
Laser Pointer: Highlights details of your presentation with ease!
Audio Controls: Adjust system volume on the PC or Mac.
Advanced Functions: Start and End presentations, or hide the slide (darken the screen) with a push of a
button.
Plug and Play: No software to install, just plug the receiver into the USB port and the remote begins to
work within seconds.
Pop In/Out Receiver: The RF receiver stores in the top of the remote when not in use.
On-Off Switch: Prevents the battery from accidentally draining when the remote is being carried in your
pocket or laptop bag.
Gamer Mode: Easy to use gamer remote for many Microsoft Windows based simulator games.
AAA Batteries: Easy to buy when you need to replace the batteries.
Travel Pouch: Convenient drawstring carry pouch with small inner pocket.
Windows Compatible: Designed for use on Windows 98SE, XP, Vista and Win 7.
MAC: An available USB Port MAC OS 10.6.6 or later (F5 function key limited to presentation exit only)
Controls PowerPoint and similar presentation software.
1/2
Specifications
OVERVIEW
UPC Code
037332160805
Model Frequency
2.4 to 2.483 GHz ISM Band
Laser Pointer
Class 2; Maximum output = 1 mW, wavelength = 650 nm
PRODUCT OVERVIEW
Product Overview
Keyspan-by-Tripp Lite Presentation Pro Remote Control
PHYSICAL
Color
Black
Shipping Dimensions (hwd / cm)
7.62 x 16.51 x 30.48
Shipping Dimensions (hwd / in.)
3.00 x 6.50 x 12.00
Shipping Weight (kg)
0.18
Shipping Weight (lbs.)
0.40
Unit Dimensions (hwd / in.)
.89 x 1.5 x 4.27
Unit Dimensions (hwd / cm)
2.26 x 3.81 x 10.85
Unit Weight (lbs.)
.132
Unit Weight (kg)
0.06
COMMUNICATIONS
Signal Range (ft.)
65
Signal Range (m)
WARRANTY
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“PR-PRO4”相匹配的价格&库存,您可以联系我们找货
