HSCF-2PH2-E1-A(P)(60) 数据手册
SC Type Fiber Optic Connectors
Environment
MU
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC
CO., LTD. All Rights Reserved.
Harsh
FC
SC
HSC Series
■Features
1. IEC, JIS standard compliant and intermateability test certified.
Comply with IEC 61754-4 and JIS C 5973(F04).
SC intermate test by NTT certified connector.
2. Flame resistant
Satisfies flammability rating UL94V-0.
Attenuators
3. Three types of Duplex SC connector
Available in following types;
Flexible F type – Floating mechanism and comply with ANSI standards.
Rigid F type – 12.7mm spacing between the fibers, low profile and compatibility with the flexible F-type.
Rigid H type – 8.5mm spacing between the fibers and for high density applications.
4. Simplified plugs and receptacles
POF / PCF
Terminators
Small size (23.8 mm plug length). SC simplified plug is designed for equipments inside connection.Comply with
IEC 61754-4-1.
6
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
HSC Series●SC Type Fiber Optic Connectors
■Product Specifications
Ratings
Operating temperature range
-25°C to +70°C
Storage temperature range
-25°C to +70°C
SC
Optical
Characteristics
Item
Insertion Loss
Return Loss
Test Method (IEC 61300)
Specifications
(SM)
Wavelength 1310nm (LD)
0.5dB max. (PC, AdPC, APC)
(GI)
Wavelength 1310nm (LED)
0.3dB max. (PC)
22dB min. (PC) 40dB min. (AdPC)
60dB min. (APC)
(SM)
(GI)
22dB min. (PC)
Mechanical Characteristics
Ferrule withdrawal force
Extract zirconia gauge 2.499 ±0.0005 mm dia from split
sleeve.
Copper alloy split sleeve
Zirconia split sleeve
Cable retention
(Straight pull)
89N tensile load for one minute.
1) Insertion loss fluctuation after test: 0.2dB max.
2) No visible damage, dislocation of clamp or cable.
Durability
(cycles, mating/un-mating)
1000 times
Duplex plug
2N to 5.9N
2N to 3.9N
Vibration
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm,
2 hours in each of the 3 axis.
Shock
Acceleration of 981 m/s2, 6 ms duration,
half sine shock pulse, 10 cycles in each of the 3 axis.
Humidity
(Temperature/ humidity- cycles)
-10°C to +65°C, humidity: 90% to 96%
10 cycles
Change of temperature
-40°C to +75°C 42 cycles
(Complies with Telcordia standard GR-326-CORE)
Dry heat
240 hours at 85°C
Cold
240 hours at -25°C
Salt mist
48 hours in a 5% concentration of salt mist
2) No visible damage, cracks or part dislocation.
Harsh
Environment
Environmental
Characteristics
Measured with corresponding connector.
MU
No significant corrosion.
Attenuators
■Materials
Part
Material
Simplex plug housing
Synthetic resin
Spring
Stainless steel
Ferrule
Zirconia
Simplex adapter housing
Synthetic resin or Zinc alloy
4-position adapter housing
Synthetic resin
5-position adapter housing
Synthetic resin
Receptacle housing
Zinc alloy
Split sleeve
Zirconia or Phosphor Bronze
Dust cap
Synthetic resin
Terminators
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Engagement force: 19.6 N max.
Separation force: 19.6 N max.
Engagement force: 39 N max.
Separation force: 39 N max.
FC
Simplex plug
Engagement and
Separation force
POF / PCF
7
■Function diagram
SC
Plugs
Ferrules
Pre-dome
APC
FC
Flat
Manual coupling/
decoupling type
Simplex
MU
Harsh
Plug housings
Duplex F-type
Duplex Flexibility type
Environment
Tool decoupling
type
Simplex
Adapters
Attenuators
Manual coupling/
decoupling type
Simplex
Duplex F-type
Terminators
Tool decoupling
type
4-position
5-position
Conversion adapters
POF / PCF
SC - FC
SC - FC
SC - FC
Note *Please refer to the section HRFC.
Receptacle
8
Duplex H-type
SC
Simplified plugs & receptacles
Plugs
FC
Manual coupling/
decoupling type
Simplex
MU
Duplex H-type
Duplex F-type
4-position
8-position
Duplex F-type
(built-in shutter only one port)
Tool decoupling
type
Harsh
Environment
Split sleeve
Attenuators
Caps
For plug
Terminators
Receptacles
For adapter
POF / PCF
9
1. Ferrules
SC
① It is not possible to connect it with a ferrule alone. Please use it with the plug housing.
Ø1 (Hole diameter)
16
7.95 +00.05 1.8
Part Number
CL No.
A dimension
HSC-F321-A125(10)
704-0070-9-10
0.125
HSC-F321-A1255(10)
704-0200-2-10
0.1255
HSC-F321-A126(10)
704-0071-1-10
0.126
Ø4.6
(Hole diameter)
A dimension
0.125
704-0571-4-00
0.1255
HSC-F3E2-A126
704-0591-1-00
0.126
Terminators
POF / PCF
10
Applicable Fiber cable
SM-9.5/125
GI-50/125
¢6
=daZY^VbZiZg
704-0590-9-00
HSC-F3E2-A1255
HSC-F3E2-A125
●For APC
Attenuators
16
7.95 +00.05 1.8
CL No.
SM-9.5/125
GI-50/125
¢&=daZY^VbZiZg
Part Number
Environment
3
Ø2.499±0.0005
1.5
ØA+0.001
R20
Ø1(Hole diameter)
●For PC, AdPC and UPC(Pre-dome)
MU
Harsh
FC
3
Ø2.499±0.0005
1.5
Ø4.6
●For PC, AdPC and UPC(Flat)
(Hole diameter)
ØA+0.001
② The angle of the fiber entrance (cone) is 60 degrees or 90 degrees.
Part Number
CL No.
A dimension
HSC-F391-A125(40)
704-3101-7-40
0.125
HSC-F391-A1255(40)
704-3130-5-40
0.1255
HSC-F391-A126(40)
704-3102-0-40
0.126
SM-9.5/125
2. Plug Housings
Please use them with the ferrule.
SC
■Manual coupling / decoupling type
33
●Light weight type (For 0.9mm fiber)
9
1.8
25
0.9
Part Number
CL No.
Boot color
HSC-PH0.9-E1(26)
704-0339-2-26
Blue
HSC-PH0.9-E2(51)
704-0354-6-51
Light purple
HSC-PH0.9-E5(51)
704-3104-5-51
Green
●Strain relief type
Slider color
Polishing type
PC
Blue
AdPC
Green
APC
MU
55
9
1.8
25
7.4
0.9
CL No.
HSC-PH2-E1(64)
704-0327-3-64
HSC-PH2-E2(75)
704-0328-6-75
HSC-PH2-E5(62)
704-3108-6-62
HSC-PH3-B1(68)
704-0222-5-68
HSC-PH3-B2(68)
704-0223-8-68
HSC-PH3-B5(62)
704-3020-7-62
Fiber cable type Slider color Boot color Polishing type Outer jacket fixing
Ø2mm
Blue
Blue
PC
Light purple
AdPC
Green
APC
Green
Ø3mm
Blue
Blue
PC
Light purple
AdPC
Green
APC
Green
Crimp
Attenuators
Part Number
Harsh
Environment
Crimp
●Short length type (For 2mm Cable)
36.5
25
9
1.8
Terminators
FC
7.4
7.4
0.9
Slider color
CL No.
704-0464-4-62
HSC-PH2-E2-A(62)
704-0480-0-62
HSC-PH2-E5-A(60)
704-3124-2-60 Green
Blue
Boot color
Polishing type
Blue
PC
Light purple
AdPC
Green
APC
Outer jacket fixing
POF / PCF
Part Number
HSC-PH2-E1-A(62)
Glue
11
22.1
12.7
SC
●Duplex F-type
7.8
25
Part Number
HSCF-2PH2-E1(P)(62)
HSCF-2PH2-E2(P)(62)
HSCF-2PH3-B1(P)(63)
HSCF-2PH3-B2(P)(65)
MU
CL No.
704-2109-3-62
Guide key
Slider color
Ø2mm
704-2120-6-62
Blue
P
704-2032-0-63
Ø3mm
704-2036-1-65
Boot Color
Polishing type
Blue
PC
Light purple
AdPC
Blue
PC
Light purple
AdPC
●Duplex Flexibility type (Comply with ANSI), for single Mode
8.99
1
Environment
23
12.7
1.8
9.9
14.1
36.7
Attenuators
61.5
Slider color
Part Number
CL No.
HSCM-2SPH2-B1(60)
704-2100-9-60
Simplex-2mm dia. cable or dual fiber zip cable
HSCM-2SPH3-B1(60)
704-2102-4-60
Simplex-3mm dia. cable or dual fiber zip cable
HSCM-2SPH2-B2(60)
704-2133-8-60
Black
Boot Color Polishing type
Blue
PC
Light purple
AdPC
The pitch size between plugs is flexible.
It is possible to connect it with duplex F-type adapter.
Terminators
●Duplex Flexibility type (Comply with ANSI), for Multi-mode
8.99
23
12.7
1.8
9.9
1.8
Harsh
FC
55
14.1
36.7
POF / PCF
61.5
Part Number
CL No.
HSCM-2GPH2-B1(60)
704-2104-0-60
HSCM-2GPH3-B1(60)
704-2106-5-60
12
Slider color
Black
Blue
PC
■Tool decoupling type
SC
7.2
33
6
FC
CL No.
Boot Color
Polishing type
HSC2-PH0.9-E1(51)
704-0421-1-51
Blue
PC
HSC2-PH0.9-E2(51)
704-0422-4-51
Light purple
AdPC
●Strain relief type
MU
7.2
55
6
Part Number
CL No.
HSC2-PH2-E1(69)
704-0329-9-69
HSC2-PH2-E2(68)
704-0330-8-68
HSC2-PH3-B1(63)
704-0226-6-63
HSC2-PH3-B2(63)
704-0227-9-63
Harsh
Environment
Fiber cable type Boot color Polishing type Outer jacket fixing
Ø2mm
Ø3mm
Blue
PC
Light purple
AdPC
Blue
PC
Light purple
AdPC
Glue
Crimp
Attenuators
Terminators
Part Number
POF / PCF
13
3.Adapters & Receptacles
BPanel cutout
9.4
1.8
18
22
12.8
27.4
3
18±0.1
●SC/SC Plastic Housing
13 +0.5
-0.5
SC
Ø2.3
Part Number
0.5
0.5
2-M2×0.4
or 2-Ø2.4
Panel thickness: 1.6mm
CL No.
Split sleeve
HSC-A3(51)
704-0092-1-51
Phosphor Bronze
HSC-A3-D1(02)
704-0217-5-02
Zirconia
HSC-A3-D2(06)
704-3007-9-06
Zirconia
+0.2
0.5
Remarks
PC,AdPC(Blue)
APC(Green)
BPanel cutout
●SC/SC Die Cast Metal Housing
9.4
13 +0.5
-0.5
1.8
Environment
18
22
12.8
27.4
3
18±0.1
MU
9.5 0.5
0.5
2-M2×0.4
or 2-Ø2.4
Ø2.3
+0.2
0.5
Part Number
Attenuators
CL No.
Split sleeve
HSC-A2(50)
704-0020-0-50
Phosphor Bronze
HSC-A2-D1(01)
704-0258-2-01
Zirconia
BPanel cutout
●SC/SC Plastic Housing (Short flange)
Terminators
Harsh
FC
9.5
EVcZai]^X`cZhh/+bb
CL No.
Split sleeve
Snap in latch for
panel mount
HSC-AFR-D1(01)
704-0572-7-01
Zirconia
without latch
HSC-AFR-D2(01)
704-0573-0-01
Zirconia
with latch
Part Number
Remarks
PC,AdPC(Blue)
POF / PCF
Note: When applying excessive force to the plug or inserting in an odd angle, the adapter housing
might be damaged.
14
●SC/SC Plastic Housing (With shutter)
SC
H]jiiZg"aZhhh^YZ
CL No.
Split sleeve
Remarks
HSC-AFL1-S1-D1
704-0593-7-00
Zirconia
PC, AdPC(Blue)
HSC-AFL1-S1-D2
704-3141-1-00
Zirconia
APC(Green)
Features
With built-in automatic shutter.
MU
6[iZgbVi^c\
7Z[dgZbVi^c\
Harsh
Environment
BdkZbZcid[i]Zh]jiiZg
Attenuators
Terminators
H]jiiZgh^YZ
FC
Part Number
POF / PCF
15
●F type Snap-in and/or Screw Mounting
BPanel cutout
SC
'"B'%#)dg
CL No.
Split sleeve
HSCF-2A(P)(51)
704-2008-6-51
Phosphor Bronze
HSCF-2A-D(P)(06)
704-2040-9-06
HSCF-2A-D2(P)(06)
704-2112-8-06
APC(Green)
27.4
15.5
12.8
18 +00.5
+0.3
Part Number
CL No.
Split sleeve
HSCH-2A1(P)(51)
704-2066-2-51
HSCH-2A1-D2(P)
704-2137-9-00
Remarks
Phosphor Bronze PC, AdPC(Blue)
Zirconia
●H type Snap-in and/or Screw Mounting
APC(Green)
BPanel cutout
2-M2∞0.4 or 2-Ø2.4 +00.2
17.9
(8.5)
3
1.8
18
12.8
18 +0.5
Ø2.3
23
13
1.8
3
(8.5)
Environment
PC, AdPC(Blue)
BPanel cutout
20.5
17.9
Attenuators
Remarks
Zirconia
●H type Snap-in
MU
Harsh
FC
Part Number
13
+0.3
18±0.1
27.4
Terminators
POF / PCF
Part Number
16
CL No.
Split sleeve
HSCH-2A(P)(51)
704-2020-1-51
Phosphor Bronze
HSCH-2A-D(P)(02)
704-2062-1-02
HSCH-2A-D2(P)(03)
704-2108-0-03
Zirconia
Remarks
PC, AdPC(Blue)
APC(Green)
+0.2
28.5 -0.5
1.8
28.2
15
12.8
24
3
SC
BPanel cutout
●SC2/SC2 4-way adapter
13
+0.5
0.5
Split sleeve
704-0024-1-51
Phosphor Bronze
Remarks
HSC2-4A-D1(01)
704-0290-5-01
Zirconia
PC,AdPC(Blue)
Note: When applying excessive force to the plug or inserting in an odd angle, the zirconia sleeve
within the adapter might be damaged.
BPanel cutout
●SC2/SC2 5-way adapter(for Multi-mode fiber)
35
15
MU
35.3 +0.5
+0.5
1.8
12.8
24
3
+0.5
13 +0.5
HSC2-5A(51)
CL No.
Split sleeve
Remarks
704-0025-4-51
Phosphor Bronze
PC,AdPC(Blue)
Harsh
Environment
Part Number
■Conversion adapters
●FC / SC Screw Mounting
BPanel cutout
Ø9
+0.5
0.5
2-M2×0.4
or 2-Ø2.4
Attenuators
13.4
9
21.2
5.5 3.5
12.2
+0.2
+0.5
Ø19
12.8
M8 × 0.75
13.4±0.1
15
Part Number
HSCJ-HRFCJ-B(43)
CL No.
Split sleeve
704-0021-3-43
Phosphor Bronze
Terminators
Note: The type of SC plug that can be mated is manual coupling/decoupling type.
BPanel cutout
●FC / SC Snap-in and/or Screw Mounting
9.4
Part Number
HSCJ-HRFCJ-C(43)
2-M2×0.4
+0.2
or 2-Ø2.4 +0.5
POF / PCF
M8 × 0.75
+0.5
0.5
18
22
Ø9
12.8
Part Number
FC
CL No.
HSC2-4A(51)
18±0.1
1.8
21.2
Ø2.3
CL No.
Split sleeve
704-0206-9-43
Phosphor Bronze
17
SC
■Receptacles
15
12.8
13.4
9
Ø19
Ø7
Ø3
15.2
12.2
2-Ø2.3
CL No.
Remarks
HSC-R1-B(41)
704-0022-6-41
For MM
HSC-R2-B(41)
704-0023-9-41
For SM
POF / PCF
Terminators
Attenuators
Environment
MU
Harsh
FC
Note: Designed for power meter sensors
Part Number
18
4. Simplified plugs & receptacles
SC
■Features
1.This product greatly reduced the number of parts compared with the SC connector, and achieved cost-saving.
SC plug
Simplified receptacle
SC adapter
MU
Harsh
Environment
Attenuators
Terminators
FC
Simplified plug
2.It achieved space-saving by using this product inside of the system.
POF / PCF
3.Please use a special tool when you decouple the plug.
19
■Simplified plug
●Simplified plug(Flat)
¢6=daZY^VbZiZg
SC
Please use the special decoupling tool when you unmate the simplified plug.
l^i]Wddih
Part Number
CL No.
704-0267-3-56
0.125
HSC2-FK-A1255(56)
704-0269-9-56
0.1255
HSC2-FK-A126(56)
704-0268-6-56
0.126
HSC2-FK-A125(51)
704-0267-3-51
0.125
HSC2-FK-A1255(51)
704-0269-9-51
0.1255
HSC2-FK-A126(51)
704-0268-6-51
0.126
Remarks
without boots
with boots
●Simplified plug(Pre-dome)
Environment
A dimension
HSC2-FK-A125(56)
¢6=daZY^VbZiZg
MU
(l^i]djiWddih)
Attenuators
G'%
¢6=daZY^VbZiZg
Harsh
¢6=daZY^VbZiZg
FC
l^i]djiWddih
G'%
POF / PCF
Terminators
Part Number
(l^i]Wddih)
CL No.
A dimension
HSC2-FK2-A125(56)
704-0407-0-56
0.125
HSC2-FK2-A1255(56)
704-0408-3-56
0.1255
HSC2-FK2-A126(56)
704-0409-6-56
0.126
HSC2-FK2-A125(51)
704-0407-0-51
0.125
HSC2-FK2-A1255(51)
704-0408-3-51
0.1255
HSC2-FK2-A126(51)
704-0409-6-51
0.126
Remarks
without boots
with boots
■Simplified receptacle to SC
●Simplex / Shrouded
SC
BPanel cutout
'"B'×%#)dg'"¢'#) %%#'
H8
HG
?6E6C
CL No.
Split sleeve
HSC-SR-1(51)
704-0320-4-51
Phosphor Bronze
HSC-SR-D1(02)
704-0321-7-02
Zirconia
HSC-SR-1(03)
704-0320-4-03
None
Note. The type of SC plug that can be mated is manual coupling/decoupling type.
MU
BPanel cutout
SC
●Simplex / Unshrouded
SR
JAPAN
Part Number
Harsh
Environment
CL No.
Split sleeve
HSC-SR-2(51)
704-0291-8-51
Phosphor Bronze
HSC-SR-D2(06)
704-0292-0-06
Zirconia
HSC-SR-2(03)
704-0291-8-03
None
BPanel cutout
Part Number
Terminators
●Duplex H type / Shrouded
Attenuators
Part Number
FC
CL No.
Split sleeve
HSCH-2SR-1(R)(51)
704-0293-3-51
Phosphor Bronze
HSCH-2SR-D1(R)(01)
704-0294-6-01
Zirconia
POF / PCF
21
'"B'%#)dg'" ¢'#)
SC
'HG
BPanel cutout
H8G
●Duplex F type / Unshrouded
Part Number
CL No.
Split sleeve
HSCF-2SR-2(P)(51)
704-0295-9-51
Phosphor Bronze
HSCF-2SR-2(P)(03)
704-0295-9-03
None
●Duplex F type / Shrouded, built-in shutter type
Environment
BPanel cutout
37
26
34.7
.1
+0 0
13±0.05
13
12.7
25.5
2.5
9
30.7
MU
2-
.4
Ø2
30.7±0.1
2-Ø
6
2.3
Part Number
HSCF-2SR-S2
CL No.
Split sleeve
704-0516-6-00
None
●4-Position / Shrouded
BPanel cutout
#) or
4SR
JAPAN
JAPAN
4SR
'"B'
Terminators
Attenuators
π The type of SC plug that can be mated is manual coupling/decoupling type.
Note. The shutter is built into only one of ports.
Harsh
FC
Part Number
CL No.
Split sleeve
HSC2-4SR-1(51)
704-0311-3-51
Phosphor Bronze
HSC2-4SR-D1(01)
704-0312-6-01
Zirconia
HSC2-4SR-1(03)
704-0311-3-03
None
POF / PCF
zirconia sleeve within the adapter might be damaged.
π The type of SC plug that can be mated is tool decoupling type.
22
●8-Position / Shrouded
'"B'
-HG
8SR
)dg
SC
BPanel cutout
FC
CL No.
Split sleeve
HSC2-8SR-D1(01)
704-0270-8-01
Zirconia
HSC2-8SR-1(03)
704-0266-0-03
None
the zirconia sleeve within the adapter might be damaged.
MU
BPanel cutout
●8-Position / Unshrouded
g'"
%#)d
'"B'
Harsh
Environment
8SR
Part Number
CL No.
Split sleeve
HSC2-8SR-2(51)
704-0318-2-51
Phosphor Bronze
HSC2-8SR-D2(01)
704-0403-0-01
Zirconia
HSC2-8SR-2(03)
704-0318-2-03
None
Attenuators
Terminators
Part Number
■Split sleeve
Zirconia
Copper alloy
CL No.
Split sleeve
HSC-SLIT-SLEEVE(51)
704-0275-1-51
Phosphor Bronze
HSC-D
704-0264-5-00
Zirconia
POF / PCF
Part Number
23
5. Caps
SC
■For plug
●Ferrule cap
Part Number
FC
704-0420-9-20
●Press fit to plug frame inner type cap
4-0.15
π HRS standard cap for plugs.
π Press fit to ferrule outer.
.6
Ø4
Ø6.5
10
MU
Harsh
CL No.
HSC-C7(20)
Part Number
CL No.
HSC-C1
704-0484-1-00
π Press fit to plug frame inner.The cap will not touch the outiside ferrule.
Environment
●Cap for SC plug housing
15
9.6
Part Number
CL No.
Attenuators
HSC-C8
704-0542-6-00
π Press fit to outside of SC slider.
■For adapter
7.4
●Simplex plastic cap
HSC-C5
CL No.
12.5
Part Number
8.3
9
Terminators
16
12.7
704-0363-7-00
POF / PCF
7.6
π HRS standard cap for SC adapters.
π The cap is inserted in the lock part of the adapter.
8.8
HSC-C9
CL No.
704-0588-7-00
π Press fit to adapter innner.
24
12.7
Part Number
9
5.8
12
Ø5.5
SC
25
Part Number
CL No.
HSC2-C2
704-0487-0-00
FC
8.3
22.1
MU
(75)
12.7
Part Number
CL No.
Remarks
HSCF-C2(40)
704-2126-2-40
without cahin
HSCF-C3(40)
704-2135-3-40
with cahin
Harsh
Environment
●Duplex H-type plastic cap
12.7
16.8
19.8
Attenuators
(75)
Part Number
HSCH-C1(40)
CL No.
Remarks
704-2122-1-40
with cahin
Terminators
●Duplex F-type plastic cap
POF / PCF
25
6. Tools
SC
●HSC2 Insertion/Extraction Tool
FC
Part Number
704-0286-8-00
HSC2 Series
Note. Handle with care because slim tips breaks easily.
1.Open the tip of tool by compressing levers as shown below.
MU
Harsh
HSC-T1-L
Applicable Products
CL No.
Environment
②
2.Insert the tool (with opening the tips) into adapter.
①
3.Release the levers (then the tool catch HSC2 plug) and you can release the connector.
● Extraction tool for Simplified plug (without boots)
7
Attenuators
6
30
6
Terminators
5
POF / PCF
Part Number
26
CL No.
Shape
HSC-T13
704-0449-0-00
Straight
HSC-T8
704-0447-5-00
L type
● Extraction tool for Simplified plug (with boots)
SC
Part Number
CL No.
Shape
HSC-T10
704-0350-5-00
Straight
HSC-T12
704-0448-8-00
L type
MU
●Crimp Tool
Harsh
Environment
This is used in crimping of Kevlar or jacket at time of the plug (for cable diameter 2mm & 3mm) termination.
18
12
228
Attenuators
Part Number
CL No.
HT501/HSC-T20
CL902-6064-2
(1) 2mm Jacket crimping: Please select section"2mm".
3mm Jacket crimping: Please select section"3mm".
(2) KevlarTM crimping: Please select section center round
groove.
Terminators
FC
●Plug assemble tool
POF / PCF
Part Number
HSC2-PH2/CVMD
CL No.
902-6029-1
27
