70001876
70001876
    DIGIINTERNATIONAL
    120X102X23MM
    MODEM W/DB-9 DIN RAIL MOUNTED
70001876 数据手册
Digi One® IA Modem Industrial Serial Modem Serial modem connectivity for industrial automation applications. Overview The Digi One IA Modem provides reliable, cost-effective remote access to industrial equipment. Users can quickly and easily access, control or collect event data from RS-232 serial devices using standard telephone lines. This compact, rugged v.92 56K external modem is designed specifically to connect Programmable Logic Controllers (PLCs), Remote Terminal Units (RTUs), flow meters and other remote, industrial-grade serial devices. Used in tandem with other Digi serial servers, the Digi One IA Modem is ideal as a failsafe dial line backup for serial-to-Ethernet connections. Application Highlight Remote Site Access POTS HMI System Telephone Lines Installing the Digi One IA Modem is quick and easy. Simply attach the modem to the DIN rail and connect the power supply, phone line and serial cable. Then install the hardware, configure the device and begin communicating. DIG IO NE IA Digi One® IA Modem RS-232 PLC Features/Benefits Target Applications Industrial Automation • V.92 56K serial modem with advanced features • Industrial DIN rail mounting for use in spaceprohibitive control cabinets • RS-232 9-pin serial port for universal connectivity • 9-30VDC power with screw terminals for flexible power input • Use in tandem with other Digi serial servers for backup network connectivity • Monitor, control or send alarms and events from a remote industrial device • LEDs for all modem signals • Modbus/RTU and Rockwell compatible www.digi.com Specifications Digi One® IA Modem Features Advanced Modem Features Extension pick-up detected, Remote hang-up detection, Line in-use detection Data Modem ITU-T V.92/K56flex (SC56), V.34 (SC56 and SC336), V.32bis, V.32, V.22bis, V.22, V.23, and V.21; Bell 212A and Bell 103; V.42 LAPM and MNp 2-4 error correction; V.42bis and MNP 5 data compression; Configurable auto-answer Fax Modem ITU-T V.17, V.29. V.27ter, and V.21 ch.2, EIA/TIA 578 Class 1 and T.31 Class 1.0 commands, EIA/TIA 578 Class 2 commands Interfaces RS-232 serial connection Cable Ships with straight-through DB-9F to DB-9M cable Status LEDs All modem signals Mounting DIN rail form factor Dimensions (L x W x D) 4.70 in x 0.90 in x 4.0 in (12.00 cm x 2.30 cm x 10.10 cm) Weight 2.25 oz (64.00 g) Power Requirements Power Input 9-30VDC @ .5 Amps max Power Connector Screw terminal block power jack Environmental Operating Temperature 0º C to 60º C (32º F to 140º F) Relative Humidity 5% to 90% (non-condensing) Regulatory Approvals Safety UL 1950, CSA 22.2 No 950, CE and EN 60950 Emissions/Immunity FCC Part 15 (Class B), FCC Part 68, EN55024 and EN55022 Digi One IA Modem - Top 0.9" 4.7" Power RJ-11 Input Modem (Screw Terminals) Reset Button Digi One IA Modem - Bottom 4.0" DB-9M Visit www.digi.com for part numbers. DIGI SERVICE AND SUPPORT - You can purchase with confidence knowing that Digi is here to support you with expert technical support and a strong five-year warranty. www.digi.com/support Digi International 877-912-3444 952-912-3444 info@digi.com Digi International France Digi International KK Digi International (HK) Limited +33-1-55-61-98-98 www.digi.fr +81-3-5428-0261 www.digi-intl.co.jp +852-2833-1008 www.digi.cn © 1999-2009 Digi International Inc. Digi, Digi International, the Digi logo and Digi One are trademarks or registered trademarks of Digi International Inc. in the United States and other countries worldwide. All other trademarks are the property of their respective owners. 91001185 D1/809 BUY ONLINE • www.digi.com
70001876 价格&库存
很抱歉,暂时无法提供与“70001876”相匹配的价格&库存,您可以联系我们找货
