U236-000-R
U236-000-R
    TRIPPLITE
    USB 2.0 1.1 TO ETHERNET ADAPTER
U236-000-R 数据手册
USB 2.0 Ethernet NIC Adapter - 10/100 Mbps, RJ45, Black MODEL NUMBER: U236-000-R Highlights ● Connects you to a wired Ethernet network when Wi-Fi is weak or unavailable ● Supports USB 2.0 speeds to ensure efficient data transfers ● Sustains full 10/100 Mbps network speeds for fast Ethernet browsing ● Works with most laptops and PCs running Windows, Mac or Linux ● USB 2.0 Ethernet adapter powered via USB, so no external power supply is required Applications Connects your USB-enabled computer or laptop to a 10/100 Mbps Ethernet network without installing an internal Ethernet card. Features ● Upload data from your notebook or download data from the Ethernet at true 10/100 Mbps speeds ● Replace a malfunctioning RJ45 port or Ethernet card on your laptop or PC System Requirements Connects Your USB Device to a Wired Ethernet Network without an Internet Card InstalledThis USB to Ethernet adapter allows you to instantly connect your computer, laptop, tablet or other USBcompatible device to a wired 10/100 Mbps Ethernet network, even if your device has no NIC (Network Interface Controller) installed. The adapter is a more convenient, less expensive way to go online than opening your device and installing an internal Ethernet card. Plug and Play with No Power Supply NeededThis USB 2.0 Ethernet adapter offers access to an Ethernet network when Wi-Fi is unavailable or when a wired connection offers faster speeds. Just connect the built-in USB cable to your device’s USB port (which also powers the adapter), and wait for the installation process to finish (you may have to reboot your computer). Then, connect the RJ45 port to a LAN port using a Cat5e/6 network cable (such as Tripp Lite’s N201-Series Cat6 UTP patch cable, sold separately). The adapter works with Windows, Mac and Linux operating systems. It is backward compatible with USB 1.1 devices. Delivers Full Ethernet PerformanceThe compact USB to Ethernet adapter supports full 10/100 Mbps network speeds and USB 2.0 speeds, allowing you to transfer data quickly and stream audio and video. It’s compliant with IEEE 802.3, 802.3u, 802.3ab and 802.3az standards. It supports full duplex with IEEE 802.3x flow control and half duplex with backpressure flow control. LEDs indicate successful data transfers. Specifications OVERVIEW UPC Code 037332163127 Technology Cat5/5e; Cat6; USB 2.0 (High Speed) INPUT 1/3 ● IBM-compatible Pentium PC or Mac with 233 MHz or faster ● 64 MB RAM or more ● Computer or laptop with USB port ● Windows (through 10), Mac (through 10.10/10.11) or Linux Kernel (2.6.14 and later) OS Package Includes ● U236-000-R USB 2.0 Ethernet NIC Adapter ● Driver CD ● Quick Start Guide Bus Powered Yes Product Length (in.) 7.5 POWER Power Consumption (Watts) 0.75 PHYSICAL Material of Construction ABS, PVC Color Black Cable Jacket Rating VW-1 Shipping Dimensions (hwd / in.) 0.50 x 5.20 x 5.30 Shipping Weight (lbs.) 0.10 Unit Dimensions (hwd / in.) 0.6 x 2.6 x 0.9 Unit Packaging Type Box Unit Weight (lbs.) 0.05 Unit Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range 32 to 158 F (0 to 70 C) Storage Temperature Range 14 to 176 F (-10 to 80 C) Relative Humidity 10% to 90 % RH, Non-Condensing BTUs 2.6 BTU/Hr COMMUNICATIONS Network Compatibility 100 Mbps (Fast Ethernet) IEEE Standards Supported 802.3; 802.3ab; 802.3az; 802.3u; 802.3x CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 RJ45 (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 2.0 (up to 480 Mbps) Driver Required Yes Recommended Category Cable Cat5/5e/6 Cables Auto MDIX Support Yes 2/3 Full Duplex Support Yes Suspend Mode Support Yes Remote Wakeup Support Yes STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
U236-000-R 价格&库存
很抱歉,暂时无法提供与“U236-000-R”相匹配的价格&库存,您可以联系我们找货
