USA-49WG
USA-49WG
    TRIPPLITE
    4-PORT SERIAL TO USB ADAPTER
USA-49WG 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States A new hardware version (V2) was released in 2015 that requires a different Windows driver. Click the above Support tab to find old and new drivers and a file with instructions on how to determine which Highlights ● Connects up to four DB9 serial devices to a computer USB-A port ● Supports data transfer speeds up to 460 Kbps ● Detachable 6-foot USB cable included ● No external power source required ● Works with Windows (XP and later) and Mac OS X (10.6 through 10.13) version you need. USB-A to Serial Adapter Hub (DB9) - Keyspan, High-Speed (M/M), 4-Port MODEL NUMBER: USA-49WG System Requirements ● USB port ● Compatible with Windows 2000, XP, Vista, 7, 8, 8.1, 10, Server 2008 R2, Server 2012, Server 2012 R2, Server 2016 ● Compatible with Mac OS X 10.6, 10.7, 10.8, 10.9, 10.10, 10.11, 10.12, 10.13 Package Includes Connect as many as four devices with a 9-pin serial port, such as modems, cellphones and scanners, to the USB Type-A port on your computer or laptop. Description The USA-49WG Keyspan® High-Speed 4-Port USB-to-DB9-Serial Adapter Hub allows you to connect as many as four 9-pin serial devices to a computer or laptop with a USB Type-A port. An easy and inexpensive way to add serial ports to your computer without hassle, the USA-49WG works with any DB9 serial device. Configuring and sharing data among multiple modems, GPS devices, cellphones, hand-held scanners, point-of-sale systems, touch screens, medical and scientific instruments, industrial process control devices and UPS systems is a breeze. The included 6-ft. (1.83 m) cable supports data transfer speeds up to 460 Kbps—four times as fast as a built-in serial port. Five LEDs display port status at a glance. The USA-49WG requires no external power. Windows line monitor and data trace software included. Works with Windows (XP and later) and Mac OS X (10.6 through 10.13). Features Operate 4 DB9 Serial Devices Simultaneously ● Connects to networking equipment, modems, GPS devices, cellphones, hand-held scanners, point-ofsale systems, touch screens, medical and scientific instruments, industrial process control devices, UPS systems and other devices with a 9-pin serial port ● Supports data transfer speeds up to 460 Kbps—4 times as fast as a built-in serial port Easy to Set Up and Use ● No external power supply needed ● Includes detachable 6-ft. (1.83 m) USB cable ● Can use with USB cable up to 16-ft. (4.88 m) long ● 5 LEDs display port status at a glance 1/2 ● USA-49WG USB-A to Serial Adapter Hub (DB9) - Keyspan, High-Speed (M/M), 4-Port ● USB cable, 6-ft. (1.83 m)length ● CD with driver software and Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Compatible with Most Systems ● Works with Windows (XP and later) and Mac OS X (10.6 through 10.13) ● Includes Windows line monitor and data trace software Specifications OVERVIEW UPC Code 672603001441 PRODUCT OVERVIEW Product Overview Keyspan-by-Tripp Lite 4-Port USB Serial Adapter PHYSICAL Color Black Shipping Dimensions (hwd / in.) 2.40 x 6.30 x 7.80 Shipping Dimensions (hwd / cm) 6.10 x 16.00 x 19.81 Shipping Weight (lbs.) 0.80 Shipping Weight (kg) 0.36 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 4.57 x 15.24 x 7.62 Unit Weight (lbs.) 0.35 Unit Weight (kg) 0.16 CONNECTIONS Side A - Connector 1 (4) DB9 (MALE) STANDARDS & COMPLIANCE Product Compliance Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
USA-49WG 价格&库存
很抱歉,暂时无法提供与“USA-49WG”相匹配的价格&库存,您可以联系我们找货
