P136-06N-HV-V2
P136-06N-HV-V2
    TRIPPLITE
    DISPLAYPORT1.2TOVGA/HDMIALL-
P136-06N-HV-V2 数据手册
DisplayPort to VGA/HDMI All-in-One Converter Adapter, DP ver 1.2, 4K 30 Hz HDMI MODEL NUMBER: P136-06N-HV-V2 Highlights ● Separate HD15 and HDMI female connectors ● HDMI port supports UHD 4K x 2K video resolutions @ 24/30 Hz ● The P136-06N-HV is a Passive adapter, and requires the connected computer to have a DP++ ( Displayport ++ ) port ● Plug and play—no software, drivers or power supply needed ● Small size for easy carrying in laptop bag or briefcase System Requirements ● The P136-06N-HV is a Passive adapter, and requires the connected computer to have a DP++ ( Displayport ++ ) port Package Includes All-in-one converter/adapter connects your DisplayPort-enabled laptop or tablet to a VGA or HDMI display without the need to carry separate adapters. Ideal for trade shows, classrooms and lecture halls. Description No more carrying around separate adapters for various monitors, projectors and televisions. The P13606N-HV-V2 DisplayPort 1.2 to VGA/HDMI All-in-One Converter Adapter connects your laptop or tablet’s DisplayPort to a VGA or HDMI display. The simple all-in-one solution for displaying content on a larger screen, the P136-06N-HV-V2 is ideal for trade shows, classrooms, lecture halls and other presentations. The all-in-one unit contains separate female HD15 and HDMI ports. It supports video resolutions up to 1920 x 1200, including 1080p @ 60 Hz (HD15), and 4K x 2K Ultra High Definition (UHD) up to 3840 x 2160 @ 24/30 Hz (HDMI). It also supports 36-bit Deep Color (12 bits per channel). The P136-06N-HV-V2 is compatible with laptops, tablets and other devices equipped with a female DisplayPort. It’s completely plug-and-play with no software or drivers to install or external power supply needed. With its small size and built-in cable, the P136-06N-HV-V2 is perfect for stowing in your laptop bag and carrying to school, the office or the latest trade show. Features Connects Your DisplayPort Laptop or Tablet to a VGA or HDMI Display ● Ideal for trade shows, classrooms, lecture halls and other presentations ● HD15 port supports video resolutions up to 1920 x 1200, including 1080p @ 60 Hz ● HDMI port supports UHD video resolutions up to 3840 x 2160 (4K x 2K) @ 24/30 Hz ● Supports 36-bit Deep Color (12 bits per channel) Plug-and-Play Convenience ● No software or drivers to install ● No external power supply required ● Small enough to stow in laptop bag or briefcase ● The P136-06N-HV is a Passive adapter, and requires the connected computer to have a DP++ ( Displayport ++ ) port Specifications 1/2 ● P136-06N-HV-V2 DisplayPort 1.2 to VGA/HDMI All-in-One Converter Adapter, 6 in. ● Owner’s manual OVERVIEW UPC Code 037332193216 Technology HDMI; VGA/SVGA; DisplayPort PHYSICAL Color Black Cable Length (ft.) 0.5 Cable Length (m) 0.15 Cable Length (in.) 6 Cable Length (cm) 15.24 Shipping Dimensions (hwd / in.) 0.50 x 3.90 x 4.80 Shipping Dimensions (hwd / cm) 1.27 x 9.91 x 12.19 Shipping Weight (lbs.) 0.10 Shipping Weight (kg) 0.05 CONNECTIONS Side A - Connector 1 DISPLAYPORT (MALE) Side B - Connector 1 HD15 (FEMALE) Side B - Connector 2 HDMI (FEMALE) WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
P136-06N-HV-V2 价格&库存
很抱歉,暂时无法提供与“P136-06N-HV-V2”相匹配的价格&库存,您可以联系我们找货
