B090-A9F
B090-A9F
    TRIPPLITE
    DB9FRJ45MODULARSERIALADAPTER
B090-A9F 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Modular Serial Adapter Straight-Through Wiring (DB9 F to RJ45 F) MODEL NUMBER: B090-A9F Highlights ● DB9F - RJ45 Modular Serial Adapter ● Straight Wiring for DB9 Serial Ethernet Switch/Router Connections ● Access your network hardware via DB9 serial port System Requirements Use with Tripp Lite Console Server models: B096-048 Package Includes 1 x DB9F - RJ45 Modular Adapter Description Use Tripp Lite B090-A9F to connect Ethernet hardware to Tripp Lite B096-016, and B096-048 Console Servers. Requires inexpensive Cat5/Cat6 patch cables between adapter and console server RJ45 ports. Features ● DB9F - RJ45 Modular Serial Adapter ● Slotted Thumbscrews for secure connections ● Straight-through wiring for DB9 Serial Ethernet hardware connections Specifications OVERVIEW UPC Code 037332149886 Accessory Type Serial Adapter Accessory Class Console Server Accessories PHYSICAL Color Beige Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.05 Shipping Weight (kg) 0.02 1/2 1000 Eaton Boulevard Cleveland, OH 44122 United States CONNECTIONS Side A - Connector 1 RJ45 (FEMALE) Side B - Connector 1 DB9 (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
B090-A9F 价格&库存
很抱歉,暂时无法提供与“B090-A9F”相匹配的价格&库存,您可以联系我们找货
