1000 Eaton Boulevard
Cleveland, OH 44122
United States
The P130-000-COMP is intended for applications such as viewing video content with audio. For standard
computer usage, desktop icons and other text may appear less sharp than if a direct cable connection is
Highlights
Allows an HDMI video source to
work with RCA A/V ports
Converts high-quality HDMI
video up to 1080p
Supports both NTSC (up to
480i) and PAL (up to 576i) video
standards
100-240V power supply and
plug adapters offer wide
compatibility
Plug and play; does not require
software or drivers
used.
HDMI to RCA Composite Video Adapter with
Audio (F/3xF)
MODEL NUMBER: P130-000-COMP
Applications
View video from a laptop or Bluray player on a display equipped
with RCA composite video and
audio ports
Continue to use a composite
video display instead of
purchasing a new HDMIenabled display
System Requirements
Convert an HDMI audio/video signal for use with an analog TV or monitor equipped with RCA composite
video and audio ports.
Features
Video source with HDMI output
Display with RCA composite
video and stereo audio inputs
Package Includes
Convert HDMI to Composite Video and Audio for Compatibility with Analog DisplaysTripp Lite’s
P130-000-COMP converter enables connection of an HDMI source, such as a laptop or Blu-ray player, to
a television, monitor or projector equipped with RCA composite audio/video connectors. A switch allows
you to select either the NTSC or PAL video standard for compatibility with a wide range of devices. The
converter has a female HDMI input and female RCA composite video (yellow) and stereo audio (red and
white) outputs; cables are sold separately.
Save Money without Sacrificing Image and Sound Quality
This HDMI to composite video and audio converter helps you save money by making your current
composite video television or monitor compatible with an HDMI-equipped video source, eliminating the
need to purchase a new HDMI display. It is HDCP compliant and supports HDMI input video resolutions of
480i, 480p, 576i, 576p, 720p, 1080i and 1080p (50/60 Hz). The converter supports output video
resolutions up to 480i (NTSC) and 576i (PAL). It also supports uncompressed two-channel (right/left)
stereo audio.
Simplify Installation with a Versatile Plug-and-Play SolutionEntirely plug and play, this converter does
not require software or drivers. Just connect your devices and plug in the included 100-240V power
supply. Suitable for use in many countries, the power supply comes with four plug adapters: NEMA 1-15P
(North America), CEE 7/16 Schuko (Europe), BS1363 (United Kingdom) and AS/NZS 3112 (Australia).
2-Year WarrantyThe P130-000-COMP is backed by a 2-year warranty, ensuring reliability and
performance.
Specifications
1/2
P130-000-COMP HDMI to
Composite Video with Audio
Converter (F/3xF)
External power supply (Input:
100-240V, 50/60 Hz, 0.3A;
Output: 5V, 1A) with 5 ft. cord
Plug adapters (North America,
Europe, United Kingdom and
Australia)
Mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
OVERVIEW
UPC Code
037332192738
Product Type
Video Adapter
Technology
Composite; HDMI; Stereo Audio
PHYSICAL
Color
Black
Shipping Dimensions (hwd / in.)
2.00 x 7.40 x 8.50
Shipping Dimensions (hwd / cm)
5.08 x 18.80 x 21.59
Shipping Weight (lbs.)
1.20
Shipping Weight (kg)
0.54
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
Unit Weight (lbs.)
1.36
Unit Weight (kg)
0.62
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“P130-000-COMP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1422.511311+178.45441
- 10+1261.9587510+158.31305
- 25+1224.4189325+153.60367
