P130-000-DP
P130-000-DP
    TRIPPLITE
    HDMI/DVITODISPLAYPORTACTIVE
P130-000-DP 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States HDMI/DVI to DisplayPort Active Converter, HDMI to DisplayPort (F/F), 1920 x 1200 (1080p) MODEL NUMBER: P130-000-DP Highlights ● Active converter works with all HDMI sources ● Supports video resolutions up to 1920 x 1200, including 1080p ● Supports HDMI uncompressed 2-channel audio, including LPCM ● Stores EDID info to ensure optimal display compatibility ● Compliant with HDCP System Requirements Converts an HDMI audio/video signal for display on a DisplayPort monitor. Also converts DVI and miniDVI video signals using adapter cables (sold separately). Ideal for video game consoles and home ● Computer or Blu-ray player with HDMI port ● Monitor with DisplayPort ● DisplayPort cable being used must not exceed 3m (10ft) ● HDMI cable being used must not exceed 5m (16ft) Package Includes ● P130-000-DP HDMI/DVI to DisplayPort Active Converter ● External power supply with NEMA 1-15P plug and 3.5 ft. cord (Input: 100–240V, 50/60 Hz, 0.5A; Output: 5V, 2A) ● Owner’s manual theaters. Description The P130-000-DP HDMI/DVI to DisplayPort Active Converter connects an HDMI source, such as a computer or Blu-ray™ player, to a DisplayPort or Mini DisplayPort monitor. With a female HDMI input port and a female DisplayPort output port, this converter lets you use your existing DisplayPort display instead of buying a new HDMI monitor or television. It also connects DVI or mini-DVI sources to a DisplayPort monitor using adapter cables (sold separately), such as Tripp Lite’s P566-Series DVI to HDMI cables. Ideal for video graphics cards, video game consoles or home theater receivers, the P130-000-DP supports video resolutions up to 1920 x 1200, including 1080p. It also supports HDMI uncompressed twochannel audio, such as LPCM, and it’s compliant with HDCP (High-Definition Content Protection). Stores EDID information to ensure top display compatibility. Installation is quick and simple, with no software or drivers to install. Locate your HDMI source up to 5m (16ft) from the Active Converter and the Active Converter up to 3m (10ft) from a display. Fits easily in a briefcase, backpack or laptop bag for connecting on the go. HDMI and DisplayPort cables sold separately. Features Sends HDMI Audio/Video Signals to a DisplayPort Monitor ● Ideal for video graphics cards, video game consoles or home theater receivers ● Connects HDMI source to DisplayPort display ● Connects DVI or mini-DVI source using adapter cables, such as Tripp Lite’s P566-Series (sold separately) ● Female HDMI and DisplayPort connectors ● Fits easily into briefcase, backpack or laptop bag ● Plug-and-play—no software or drivers necessary Vibrant Audio/Video Quality ● Supports video resolutions up to 1920 x 1200, including 1080p 1/2 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Supports HDMI uncompressed 2-channel audio, including LPCM ● Complies with HDCP ● Stores EDID information to ensure optimal display compatibility Specifications OVERVIEW UPC Code 037332192721 Technology DVI; HDMI; DisplayPort PHYSICAL Color Black Shipping Dimensions (hwd / in.) 3.00 x 5.20 x 7.10 Shipping Dimensions (hwd / cm) 7.62 x 13.21 x 18.03 Shipping Weight (lbs.) 0.80 Shipping Weight (kg) 0.36 CONNECTIONS Side A - Connector 1 DISPLAYPORT (FEMALE) Side B - Connector 1 HDMI (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P130-000-DP 价格&库存
很抱歉,暂时无法提供与“P130-000-DP”相匹配的价格&库存,您可以联系我们找货
