HDMI to RCA Audio and NTSC or PAL
Video Adapter
PRODUCT ID: 3365
Description
Do you have a display, television, projector or some other older device that isn't
compatible with your HDMI devices? Here's an adapter that will allow you to convert
HDMI from your modern computer or game system to NTSC/PAL, for older screens and
devices that might not have an HDMI input.
This mini HDMI to AV signal converter will convert HDMI video signal or audio signal
to CVBS (either NTSC or PAL selectable) composite video signal and left/right stereo
audio signals. A switch on the side will select between standard 480i NTSC or 576i PAL.
Note that you will get some degradation of signal just by the fact that you'll be converting
HD video down to a low-rez display. That said, for many older devices, such as TVs,
CRTs, VCRs, projectors, DVD recorders, game console, etc. you may not have a choice.
Just be aware that it won't turn your 1990 TV into an HDMI-quality display!
Features
o
o
o
o
o
Compatible HDMI1.3, Supports HDMI input from 480i to 1080P. 3D and HDCP not
supported (so turn off HDCP on your device)
Selectable NTSC or PAL standard TV format outputs
Also separates out the HDMI audio signal into left and right line level output.
No need to install drivers! The adapter is portable, flexible, plug and play
Package includes: Converter, USB Power Cable and User Manual
Technical Details
o
o
o
Adapter body dimensions: 68mm x 55mm x 21mm
Cable length: 28" / 760mm
Powered via mini USB cable, plug into any USB hub, computer, or USB wall adapter (not
included)
Product Weight: 36.0g / 1.3oz
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3365”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+131.043461+17.03523
