P137-06N-HV-V2W
P137-06N-HV-V2W
    TRIPPLITE
    KEYSPAN MINI DISPLAYPORT 1.2 TO
P137-06N-HV-V2W 数据手册
Keyspan Mini DisplayPort to VGA/HDMI All-inOne Video Converter Adapter, 4K 30Hz HDMI, DP1.2, White, 6-in. (15.24 cm) Highlights ● Separate HD15 and HDMI female connectors ● HDMI port supports UHD 4K x 2K @ 24/30 Hz video resolutions ● The P137-06N-HV-V2W is a Passive adapter, and requires the connected computer to have a DP++ ( Displayport ++ ) port ● Plug and play—no software, drivers or power supply needed ● Small size for easy carrying in laptop bag or briefcase MODEL NUMBER: P137-06N-HV-V2W System Requirements ● The P137-06N-HV-V2W is a Passive adapter, and requires the connected computer to have a DP++ ( Displayport ++ ) port Package Includes ● P137-06N-HV-V2W Keyspan Mini DisplayPort 1.2 to VGA/HDMI All-in-One Converter Adapter, 6 in. ● Owner’s manual All-in-one converter/adapter connects your Mini DisplayPort or Thunderbolt-enabled laptop or tablet to a VGA or HDMI display without the need to carry separate adapters. Ideal for trade shows, classrooms and lecture halls. Features Connects Your Mini DisplayPort Laptop or Tablet to a VGA or HDMI Display ● Ideal for trade shows, classrooms, lecture halls and other presentations ● HD15 port supports video resolutions up to 1920 x 1200, including 1080p ● HDMI port supports UHD video resolutions up to 3840 x 2160 (4K x 2K) @ 24/30 Hz ● Supports 36-bit Deep Color (12 bits per channel) Plug-and-Play Convenience ● No software or drivers to install ● No external power supply required ● Small enough to stow in laptop bag or briefcase ● The P137-06N-HV-V2W is a Passive adapter, and requires the connected computer to have a DP++ ( Displayport ++ ) port Specifications OVERVIEW UPC Code 037332193223 Technology HDMI; VGA/SVGA; DisplayPort PHYSICAL 1/2 Color White Cable Length (ft.) 0.5 Cable Length (m) 0.15 Cable Length (in.) 6 Cable Length (cm) 15.24 Shipping Dimensions (hwd / in.) 3.90 x 4.70 x 0.50 Shipping Dimensions (hwd / cm) 9.91 x 11.94 x 1.27 Shipping Weight (lbs.) 0.15 Shipping Weight (kg) 0.07 CONNECTIONS Side A - Connector 1 MINI DISPLAYPORT (MALE) Side B - Connector 1 HD15 (FEMALE) Side B - Connector 2 HDMI (FEMALE) WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
P137-06N-HV-V2W 价格&库存
很抱歉,暂时无法提供与“P137-06N-HV-V2W”相匹配的价格&库存,您可以联系我们找货
