P450-000
P450-000
    TRIPPLITE
    DB9FTORJ45NULLMODEMADAPT
P450-000 数据手册
Null Modem Serial DB9 Serial Modular Adapter Kit, 2x (DB9F to RJ45F) MODEL NUMBER: P450-000 Highlights ● 2pc DB9F to RJ45 Null Modem Adapter Kit ● Uses readily available Cat5 Patch Cables ● Null Modem Serial Connections up to 100ft System Requirements ● Typically two PC's with DB9 Male Serial ports Package Includes ● Description With Tripp Lite's P450-000 Null Modem Adapter Kit, you can set up PC-PC Serial connections up to 100ft. (30.5 m) apart using readily available Cat5/Cat6 patch cables. The finished connection results in a Null wiring configuration: 1+6 - 4, 2-3, 3-2, 4 - 1+6, 5-5, 7-8, 8-7, with Full Handshake capability. Slotted, knurled thumbscrews provide easy and secure attachment to your computers. Features ● 2pc DB9F to RJ45 Null Modem Adapter Kit ● Uses readily available Cat5 Patch Cables ● Null Modem Serial Connections up to 100-ft. (30.5 m) Specifications OVERVIEW UPC Code 037332149572 PHYSICAL Color Gray Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.09 Shipping Weight (kg) 0.04 CONNECTIONS 1/2 2 x DB9F / RJ45 Modular Adapters Side A - Connector 1 DB9 (FEMALE) Side B - Connector 1 RJ45 (FEMALE) WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
P450-000 价格&库存
很抱歉,暂时无法提供与“P450-000”相匹配的价格&库存,您可以联系我们找货
P450-000
    库存:85
