U438-06N-G2-W
U438-06N-G2-W
    TRIPPLITE
    USB3.1GEN2USBTYPE-CTOSATA
U438-06N-G2-W 数据手册
USB 3.2 Gen 2 (10 Gbps) USB-C to SATA III Adapter Cable with UASP, 2.5 in. SATA Hard Drives, Thunderbolt 3 Compatible, White Highlights ● Supports USB 3.2 Gen 2 data transfer rates up to 10 Gbps ● Works up to 70% faster when connected to UASP host controller ● Compatible with SATA HDDs and SSDs up to 4 TB ● Plug-and-play—no external power supply required ● Compatible with all USBenabled operating systems MODEL NUMBER: U438-06N-G2-W System Requirements Connects a 2.5 in. SATA HDD or SSD to your laptop, tablet, Chromebook or computer’s USB Type-C or Thunderbolt 3 port for extra storage, quick disk formatting and fast data transfer. ● Any USB-enabled operating system ● Available USB-C or Thunderbolt 3 port (USB 3.2 required to achieve USB 3.2 speeds) ● 2.5 in. SATA drive ● UASP-enabled host controller required for UASP performance Package Includes ● Description The U438-06N-G2-W USB 3.2 Gen 2 to SATA III Adapter Cable connects a 2.5-inch SATA hard disk drive (HDD) or solid state drive (SSD) to an available USB-C or Thunderbolt 3 port on your laptop, tablet, Chromebook or computer. This lets you back up important data, retrieve data from an old hard drive, or store information on an external drive that you can take with you to another computer. This adapter cable supports USB 3.2 Gen 2 data transfer rates up to 10 Gbps. Its UASP (USB Attached SCSI Protocol) feature reduces latency and allows the cable to perform up to 70% faster when connected to a UASP-enabled host controller. Perfect for storing and sharing large files, such as music and video files, the U438-06N-G2-W is compatible with SATA drives up to 4 TB. Just insert the drive into the 22-pin SATA connector, and attach the built-in USB 3.2 cable to your computer. The U438-06N-G2-W accepts SATA III (6 Gbps), SATA II (3 Gbps) and SATA I (1.10 Gbps) drives, as well as USB 2.0 (480 Mbps) and USB 1.1 (12 Mbps) transfer speeds. It supports LBA-48 bit (Logical Block Addressing) and USB Mass Storage Class Bulk-Only Transport. No software, drivers or external power supply is required. Compatible with all USB-enabled operating systems. Features Quickly Connects a SATA Drive to Your Computer’s USB-C or Thunderbolt 3 Port ● Recommended for backing up, retrieving and storing large data files ● Supports USB 3.2 Gen 2 data transfer rates up to 10 Gbps ● Features UASP for performance up to 70% faster when connected to UASP-enabled host controller Compatible with 2.5 in. SATA HDDs and SSDs Up to 4 TB ● Accepts SATA III, SATA II and SATA I drives ● Backward compatible with previous USB generations ● Supports LBA-48 bit and USB Mass Storage Class Bulk-Only Transport Easy to Use ● Plug-and-play—no software, drivers or external power supply needed 1/3 U438-06N-G2-W USB 3.2 Gen 2 to SATA III Adapter Cable, White ● Compatible with all USB-enabled operating systems Specifications OVERVIEW UPC Code 037332199423 Technology SATA/eSATA INPUT Bus Powered Yes Product Length (in.) 6 POWER Power Consumption (Watts) 5 USER INTERFACE, ALERTS & CONTROLS LED Indicators Blue (Read, Write, Power) PHYSICAL Material of Construction ABS Color White Cable Jacket Color White Cable Jacket Rating VW-1 Shipping Dimensions (hwd / cm) 1.27 x 10.67 x 17.78 Shipping Dimensions (hwd / in.) 0.50 x 4.20 x 7.00 Shipping Weight (kg) 0.09 Shipping Weight (lbs.) 0.20 Unit Dimensions (hwd / in.) 0.5 x 2.8 x 0.71 Unit Dimensions (hwd / cm) 1.3 x 7.1 x 1.8 Unit Packaging Type Polybag Unit Weight (lbs.) 0.05 Unit Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range 50 to 122 F (10 to 50 C) Storage Temperature Range 32 to 149 F (0 to 65 C) Relative Humidity 10% to 80% RH, Non-Condensing 2/3 BTUs 17.1 BTU/Hr CONNECTIONS Number of Ports 1 Side A - Connector 1 USB C (MALE) Side B - Connector 1 22 PIN SATA + POWER (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 3.1 Gen 2 (up to 10 Gbps) Driver Required No UASP Support Yes IP68 Rated No IP20 Rated No STANDARDS & COMPLIANCE Product Certifications EN 55022; EN 55024 Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
U438-06N-G2-W 价格&库存
很抱歉,暂时无法提供与“U438-06N-G2-W”相匹配的价格&库存,您可以联系我们找货
