P139-010-DP-V2B
P139-010-DP-V2B
    TRIPPLITE
    KEYSPANMINIDISPLAYPORT1.2ATO
P139-010-DP-V2B 数据手册
Keyspan Mini DisplayPort to DisplayPort Adapter Cable (M/F), 4K 60 Hz, DP 1.2, HDCP 2.2, 10 ft. (3.1 m) Highlights ● Supports UHD video resolutions up to 3840 x 2160 (4K x 2K) @ 60 Hz ● Nickel-plated connectors with gold-plated contacts ● Integral strain relief ● Compliant with HDCP 2.2 and DisplayPort 1.2a ● Plug and play—no software or drivers required MODEL NUMBER: P139-010-DP-V2B Package Includes ● Connects a computer with a Mini DisplayPort (mDP) output to a high-definition monitor, projector or television with a DisplayPort™ input. Description The P139-010-DP-V2B Keyspan® Mini DisplayPort 1.2a to DisplayPort Cable Adapter and Video Converter connects an mDP computer to a high-definition DisplayPort monitor, projector or television. It allows you to continue using your existing DisplayPort display instead of buying a new Mini DisplayPort monitor. Ideal for displaying crystal-clear video on a large monitor or digital sign, this 10-ft. (3.05 m) cable supports Ultra High Definition (UHD) video resolutions up to 3840 x 2160 (4K x 2K) at 60 Hz, including 1080p. Nickel-plated connectors with gold-plated contacts ensure excellent conductivity. Integral strain relief ensures the cable and molded connectors last a long time. Just plug and play with no software or drivers required. Features Sends UHD Mini DisplayPort Audio/Video to a DisplayPort Monitor ● Connects an mDP computer to a DisplayPort monitor, projector or TV ● Recommended for displaying Mini DisplayPort video on a large monitor or digital sign ● Allows you to continue using an existing DisplayPort display, instead of buying a new monitor Vibrant Video Quality ● Supports UHD video resolutions up to 3840 x 2160 (4K x 2K) @ 60 Hz, including 1080p ● Compliant with HDCP 2.2 and DisplayPort 1.2a Superior Materials for Superior Performance ● Nickel-plated connectors with gold-plated contacts for excellent conductivity ● Integral strain relief for long life ● Plug and play—no software or drivers required 1/2 P139-010-DP-V2B Keyspan Mini DisplayPort 1.2a to DisplayPort Cable Adapter (M/F), 10-ft. (3.05 m) Specifications OVERVIEW UPC Code 037332201782 Product Type Passive Cable Technology DisplayPort PHYSICAL Color White Cable Jacket Color White Cable Length (ft.) 10 Cable Length (m) 3.05 Cable Length (in.) 120 Cable Length (cm) 304.80 Shipping Dimensions (hwd / in.) 0.50 x 7.00 x 9.00 Shipping Dimensions (hwd / cm) 1.27 x 17.78 x 22.86 Shipping Weight (lbs.) 0.30 Shipping Weight (kg) 0.14 CONNECTIONS Side A - Connector 1 MINI DISPLAYPORT (MALE) Side B - Connector 1 DISPLAYPORT (FEMALE) WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
P139-010-DP-V2B 价格&库存
很抱歉,暂时无法提供与“P139-010-DP-V2B”相匹配的价格&库存,您可以联系我们找货
