USB 3.1 Gen 1 (5 Gbps) USB-C to SATA III
Adapter Cable with UASP, 2.5 in. SATA Hard
Drives, Thunderbolt 3 Compatible, White
Highlights
Supports USB 3.1 data transfer
rates up to 5 Gbps
Works up to 70% faster when
connected to UASP host
controller
Compatible with SATA HDDs
and SSDs up to 4 TB
Plug-and-play—no external
power supply required
Compatible with all USBenabled operating systems
MODEL NUMBER: U438-06N-G1-W
System Requirements
Connects a 2.5 in. SATA HDD or SSD to your laptop, tablet, Chromebook or computer’s USB Type-C or
Thunderbolt™ 3 port for extra storage, quick disk formatting and fast data transfer.
The U438-06N-G1-W USB 3.1 Gen 1 to SATA III Adapter Cable connects a 2.5-inch SATA hard disk drive
(HDD) or solid state drive (SSD) to an available USB-C or Thunderbolt™ 3 port on your laptop, tablet,
Chromebook or computer. This lets you back up important data, retrieve data from an old hard drive, or
store information on an external drive that you can take with you to another computer.
This adapter cable supports USB 3.1 data transfer rates up to 5 Gbps. Its UASP (USB Attached SCSI
Protocol) feature reduces latency and allows the cable to perform up to 70% faster when connected to a
UASP-enabled host controller.
Perfect for storing and sharing large files, such as music and video files, the U438-06N-G1-W is
compatible with SATA drives up to 4 TB. Just insert the drive into the 22-pin SATA connector, and attach
the built-in USB 3.1 cable to your computer.
The U438-06N-G1-W accepts SATA III (6 Gbps), SATA II (3 Gbps) and SATA I (1.5 Gbps) drives, as well
as USB 2.0 (480 Mbps) and USB 1.1 (12 Mbps) transfer speeds. It supports LBA-48 bit (Logical Block
Addressing) and USB Mass Storage Class Bulk-Only Transport. No software, drivers or external power
supply is required. Compatible with all USB-enabled operating systems.
Features
Quickly Connects a SATA Drive to Your Computer’s USB-C or Thunderbolt™ 3Port
● Recommended for backing up, retrieving and storing large data files
Supports USB 3.1 Gen 1 data transfer rates up to 5 Gbps
Features UASP for performance up to 70% faster when connected to UASP-enabled host controller
Compatible with 2.5 in. SATA HDDs and SSDs Up to 4 TB
● Accepts SATA III, SATA II and SATA I drives
Backward compatible with previous USB generations
Supports LBA-48 bit and USB Mass Storage Class Bulk-Only Transport
Any USB-enabled operating
system
Available USB-C or
Thunderbolt™ 3 port (USB 3.1
required to achieve USB 3.1
speeds)
2.5 in. SATA drive
required for UASP performance
Package Includes
Description
Easy to Use
1/3
1 to SATA III Adapter Cable,
White
Plug-and-play—no software, drivers or external power supply needed
Specifications
OVERVIEW
UPC Code
037332199430
Technology
SATA/eSATA
INPUT
Bus Powered
Yes
Product Length (in.)
6
POWER
Power Consumption (Watts)
5
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Blue (Read, Write, Power)
PHYSICAL
Material of Construction
ABS
Color
White
Cable Jacket Color
White
Cable Jacket Rating
VW-1
Shipping Dimensions (hwd / cm)
1.27 x 10.80 x 17.78
Shipping Dimensions (hwd / in.)
0.50 x 4.25 x 7.00
Shipping Weight (kg)
0.03
Shipping Weight (lbs.)
0.06
Unit Dimensions (hwd / in.)
0.5 x 2.8 x 0.71
Unit Dimensions (hwd / cm)
1.3 x 7.1 x 1.8
Unit Packaging Type
Polybag
Unit Weight (lbs.)
0.05
Unit Weight (kg)
0.02
ENVIRONMENTAL
Operating Temperature Range
50 to 122 F (10 to 50 C)
Storage Temperature Range
32 to 149 F (0 to 65 C)
2/3
Relative Humidity
10% to 80% RH, Non-Condensing
BTUs
17.1 BTU/Hr
CONNECTIONS
Number of Ports
1
Side A - Connector 1
USB C (MALE)
Side B - Connector 1
22 PIN SATA + POWER (FEMALE)
Connector Plating
Nickel
FEATURES & SPECIFICATIONS
USB Specification
USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps)
Driver Required
No
UASP Support
Yes
IP68 Rated
No
IP20 Rated
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA)
WARRANTY
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
3/3
很抱歉,暂时无法提供与“U438-06N-G1-W”相匹配的价格&库存,您可以联系我们找货
