U336-000-GBW
U336-000-GBW
    TRIPPLITE
    USB3.0TOETHERNETADAPTER
U336-000-GBW 数据手册
USB 3.0 to Gigabit Ethernet NIC Network Adapter - 10/100/1000 Mbps, White MODEL NUMBER: U336-000-GBW Highlights ● Connects your laptop to a Gigabit Ethernet network when Wi-Fi is unavailable ● Supports true 10/100/1000 Mbps Ethernet network speeds for fast downloads ● USB 3.0 compatibility allows large data transfers with no compromise in signal quality ● Plug-and-play operation allows you to set it up and begin using it immediately ● Small enough to carry in a pocket or purse for fast file transfers anywhere Applications USB 3.0 Gigabit Ethernet adapter connects your laptop to a wired Ethernet network for 10/100/1000 Mbps data transfer speeds. Features USB 3.0 to Gigabit Ethernet Adapter Connects You to a Wired 10/100/1000 Mbps NetworkThis USB 3.0 Gigabit Ethernet NIC network adapter instantly connects your computer, laptop, notebook, MacBook, Ultrabook or Chromebook to a 10/100/1000 Mbps network through a USB port. No internal Ethernet card is required. Just connect the built-in USB plug to your computer, and use a Cat5e/6 cable (sold separately) to connect the RJ45 end to a wired Gigabit Ethernet network. This network adapter is ideal for use in areas where Wi-Fi is unavailable or a wired connection offers faster speeds. Compliant with State-of-the-Art USB 3.0 SpeedsBecause this Gigabit Ethernet adapter complies with USB 3.0 (5 Gbps) specifications, you are ensured true 10/100/1000 Mbps network speed without a compromise in signal quality. Plug-and-Play Operation Lets You Begin Transferring Data Almost ImmediatelyNo external power is required. Just connect the adapter to both your computer and an RJ45 Gigabit Ethernet port for network access without the need to find an AC outlet. The lightweight unit is easy to carry in a pocket, purse, backpack or laptop bag for instant file transfers where needed. It’s compatible with Windows, Mac and Linux. Manufactured to Exacting Standards to Ensure a Full Ethernet ExperienceThis USB 3.0 Gigabit Ethernet adapter complies with IEEE 802.3 (10Base-T), 802.3u (100Base-TX), 802.3ab and 802.3az (Energy Efficient Ethernet) standards. It supports full- and half-duplex operations, suspend mode and remote wakeup via link-up and magic packet. Diagnostic LEDs indicate when you are connected to a network and when data is being transferred. Specifications OVERVIEW 1/3 ● Connect to a wired Gigabit Ethernet network in an office, trade show booth, lecture hall, classroom, hotel lobby or auditorium ● Extend the life of a legacy laptop or notebook computer with a failed internal Ethernet card ● Play network gaming consoles in areas without Wi-Fi capability System Requirements ● IBM-compatible Pentium 233 MHz or faster PC or Mac ● 64 MB RAM or more ● USB-A port (USB 3.0 port required to achieve USB 3.0 speeds) ● Windows (XP through 10), Mac (10.6 through 10.12) or Linux Kernel (2.6.25 and later) operating system Package Includes ● U336-000-GBW USB 3.0 to Gigabit Ethernet NIC Network Adapter, White ● Driver CD ● Quick Start Guide UPC Code 037332183286 Technology Cat5/5e; Cat6 INPUT Bus Powered Yes Product Length (in.) 7.5 POWER Power Consumption (Watts) 0.5 PHYSICAL Material of Construction ABS, PVC Color White Cable Jacket Rating VW-1 Shipping Dimensions (hwd / in.) 0.90 x 5.20 x 5.20 Shipping Weight (lbs.) 0.14 Unit Dimensions (hwd / in.) 0.6 x 2.6 x 0.9 Unit Packaging Type Box Unit Weight (lbs.) 0.06 Unit Weight (kg) 0.03 ENVIRONMENTAL Operating Temperature Range 32 to 158 F (0 to 70 C) Storage Temperature Range 14 to 176 F (-10 to 80 C) Relative Humidity 10% to 90 % RH, Non-Condensing BTUs 1.7 BTU/Hr COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3; 802.3ab; 802.3az; 802.3u; 802.3x CONNECTIONS Side A - Connector 1 USB 3.0 A (MALE) Side B - Connector 1 RJ45 (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) 2/3 Driver Required Yes Recommended Category Cable Cat5/5e/6 Cables Auto MDIX Support Yes Full Duplex Support Yes Suspend Mode Support Yes Remote Wakeup Support Yes STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
U336-000-GBW 价格&库存
很抱歉,暂时无法提供与“U336-000-GBW”相匹配的价格&库存,您可以联系我们找货
