P139-006-DP-V2B
P139-006-DP-V2B
    TRIPPLITE
    KEYSPANMINIDISPLAYPORT1.2ATO
P139-006-DP-V2B 数据手册
Keyspan Mini DisplayPort to DisplayPort Adapter Cable (M/F), 4K 60 Hz, DP 1.2, HDCP 2.2, 6 ft. (1.8 m) Highlights ● Supports UHD video resolutions up to 3840 x 2160 (4K x 2K) @ 60 Hz ● Nickel-plated connectors with gold-plated contacts ● Integral strain relief ● Compliant with HDCP 2.2 and DisplayPort 1.2a ● Plug and play—no software or drivers required MODEL NUMBER: P139-006-DP-V2B Package Includes ● Connects a computer with a Mini DisplayPort (mDP) output to a high-definition monitor, projector or television with a DisplayPort™ input. Features Sends UHD Mini DisplayPort Audio/Video to a DisplayPort Monitor ● Connects an mDP computer to a DisplayPort monitor, projector or TV ● Recommended for displaying Mini DisplayPort video on a large monitor or digital sign ● Allows you to continue using an existing DisplayPort display, instead of buying a new monitor Vibrant Video Quality ● Supports UHD video resolutions up to 3840 x 2160 (4K x 2K) @ 60 Hz, including 1080p ● Compliant with HDCP 2.2 and DisplayPort 1.2a Superior Materials for Superior Performance ● Nickel-plated connectors with gold-plated contacts for excellent conductivity ● Integral strain relief for long life ● Plug and play—no software or drivers required Specifications OVERVIEW UPC Code 037332201775 Product Type Passive Cable Technology DisplayPort 1/2 P139-006-DP-V2B Keyspan Mini DisplayPort 1.2a to DisplayPort Cable Adapter (M/F), 6 ft. PHYSICAL Color White Cable Jacket Color White Cable Length (ft.) 6 Cable Length (m) 1.83 Cable Length (in.) 72 Cable Length (cm) 182.88 Shipping Dimensions (hwd / in.) 0.50 x 7.00 x 9.00 Shipping Dimensions (hwd / cm) 1.27 x 17.78 x 22.86 Shipping Weight (lbs.) 0.20 Shipping Weight (kg) 0.09 CONNECTIONS Side A - Connector 1 MINI DISPLAYPORT (MALE) Side B - Connector 1 DISPLAYPORT (FEMALE) WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
P139-006-DP-V2B
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换和分配,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗电子等领域。
7. 封装信息:采用QFN封装,尺寸为4mm x 4mm。
P139-006-DP-V2B 价格&库存
很抱歉,暂时无法提供与“P139-006-DP-V2B”相匹配的价格&库存,您可以联系我们找货
