Keyspan Mini DisplayPort to HDMI Active
Adapter Video Converter (M/F) - 4K, DP1.2, 6 in.
MODEL NUMBER: P137-06N-HD-UHD
Highlights
Connect a UHD HDMI monitor
to a Mac or PC with a Mini
Displayport output
Active adapter for use with any
Mini Displayport (or Thunderbolt
1 & 2) port
Plug-and-play convenience—no
drivers or software needed
Supports Ultra High Definition
(UHD) video resolutions up to
4Kx2K, 3840 x 2160 (24Hz or
30Hz)
HDCP compliant
System Requirements
Computer with a Mini
DisplayPort (or Thunderbolt 1 &
2) port
Monitor with a HDMI port
7.1 Audio Surround Sound is
supported as long as it is
supported by the source. Check
your Mini DisplayPort source
documentation for compatibility.
Requires that the connected
computer has a DP++ (
DisplayPort ++ ) port, which
allows HDMI and DVI signals to
be passed through. Check your
Connect a UHD 4K x 2K HDMI monitor to a Mac or PC with a Mini Displayport output
Features
Connect a UHD HDMI TV to a Mac or PC with a Mini Displayport output
Active adapter for use with any Mini Displayport (or Thunderbolt 1 & 2) port
Converts Single-Mode and Dual-Mode (DP++) Mini DisplayPort output
Perfect for use with graphics cards, such as AMD Eyefinity, that do not output DP++ signals
Plug-and-play operation with no software required for easy, immediate installation
Supports Ultra High Definition (UHD) video resolutions up to 4K x 2K (3840 x 2160) @ 24/30 Hz
HDCP compliant
Transmits an audio signal as long as it is supported by the Mini DisplayPort; check the documentation
for your Mini DisplayPort source for compatibility
Specifications
OVERVIEW
UPC Code
037332183910
Technology
HDMI; DisplayPort
VIDEO
Max Supported Color Depth
36-bit Deep Color
PHYSICAL
Color
Package Includes
White
1/2
P137-06N-HD-UHD Keyspan
Mini DisplayPort 1.2 to UHD 4K
HDMI Active Adapter/Video
Converter (M/F), 6 in.
Cable Length (ft.)
0.5
Cable Length (m)
0.15
Cable Length (in.)
6
Cable Length (cm)
15.24
Shipping Dimensions (hwd / in.)
9.00 x 0.50 x 7.00
Shipping Dimensions (hwd / cm)
22.86 x 1.27 x 17.78
Shipping Weight (lbs.)
0.26
Shipping Weight (kg)
0.12
CONNECTIONS
Side A - Connector 1
MINI DISPLAYPORT (MALE)
Side B - Connector 1
HDMI (FEMALE)
WARRANTY
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“P137-06N-HD-UHD”相匹配的价格&库存,您可以联系我们找货
