USB 2.0 to Gigabit Ethernet NIC Network
Adapter, 10/100/1000 Mbps, White
MODEL NUMBER: U236-000-GBW
Highlights
Windows, Mac, and Linux
compatible
Compliant with USB 2.0 and
USB 1.1 specifications
System Requirements
IBM compatible Pentium233MHz or faster PC or Mac
64 MB RAM or more
One available USB port
Windows XP, Vista, 7, 8, and
8.1 compatible
Mac OSX 10.6 through 10.10
compatible
Linux Kernel 2.6.14 and later
compatible
Package Includes
Create a Gigabit network port on a computer via USB
Description
Tripp Lite's U236-000-GBW, USB 2.0 Gigabit Ethernet Adapter, allows your computer to instantly connect
to a Gigabit network through a USB port - no need to open up your computer case to add an internal
Ethernet card. The adapter's compliance with USB 2.0 (480Mbps) ensures true Gigabit network speed
without any compromise. Furthermore, the adapter is compact and is USB bus-powered; requires no
external power adapter.
Features
Allows your computer to instantly connect to a Gigabit network through a USB port - no need to open up
your computer case to add an internal Ethernet card
Compliant with USB 2.0 and USB 1.1 specifications
Compliant with IEEE 802.3 (10Base-T) and 802.3u (100Base-TX) standards
Supports both full-duplex and half-duplex operations
Supports suspend mode and remote wakeup via link-up and magic packet
Powered by USB port - no external power adapter required
Equipped with diagnostic LEDs
Windows XP, Vista, 7, 8, and 8.1 compatible
Mac OSX 10.6 through 10.10 compatible
Linux Kernel 2.6.25 and later compatible
Specifications
OVERVIEW
UPC Code
037332183279
Technology
Cat5/5e; Cat6; USB 2.0 (High Speed)
1/3
USB Ethernet Adapter
Quick Start Guide
Driver CD
INPUT
Bus Powered
Yes
Product Length (in.)
7.5
POWER
Power Consumption (Watts)
0.95
PHYSICAL
Material of Construction
ABS, PVC
Color
White
Cable Jacket Rating
VW-1
Shipping Dimensions (hwd / in.)
0.90 x 5.20 x 5.20
Shipping Weight (lbs.)
0.14
Unit Dimensions (hwd / in.)
0.6 x 2.6 x 0.9
Unit Packaging Type
Box
Unit Weight (lbs.)
0.05
Unit Weight (kg)
0.02
ENVIRONMENTAL
Operating Temperature Range
32 to 158 F (0 to 70 C)
Storage Temperature Range
14 to 176 F (-10 to 80 C)
Relative Humidity
10% to 90 % RH, Non-Condensing
BTUs
3.2 BTU/Hr
COMMUNICATIONS
Network Compatibility
1 Gbps (Gigabit)
IEEE Standards Supported
802.3; 802.3ab; 802.3az; 802.3u; 802.3x
CONNECTIONS
Side A - Connector 1
USB A (MALE)
Side B - Connector 1
RJ45 (FEMALE)
Connector Plating
Nickel
FEATURES & SPECIFICATIONS
USB Specification
USB 2.0 (up to 480 Mbps)
Driver Required
Yes
Recommended Category Cable
Cat5/5e/6 Cables
2/3
Auto MDIX Support
Yes
Full Duplex Support
Yes
Suspend Mode Support
Yes
Remote Wakeup Support
Yes
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA)
WARRANTY
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
3/3
很抱歉,暂时无法提供与“U236-000-GBW”相匹配的价格&库存,您可以联系我们找货
