P120-06N-ACT
P120-06N-ACT
    TRIPPLITE
    CABLECONVERTER
P120-06N-ACT 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DVI-D to VGA Active Adapter Converter Cable, 1920x1200, 6-in. (15.24 cm) MODEL NUMBER: P120-06N-ACT Highlights ● Converts a DVI-D digital signal to a VGA analog signal for greater device compatibility ● Supports computer resolutions up to 1920 x 1200 and HD up to 1080p for high-quality images ● Features plug-and-play installation; does not require software or drivers ● Works with VGA cables up to 100-ft. (30.5 m) for flexibility in monitor placement ● Includes a USB Micro-B cable if power is needed Applications ● Use your current VGA monitor with your newer DVI computer to eliminate the need for a new display ● Use a VGA projector with your DVI computer to give a presentation Convert a DVI digital signal to VGA analog to provide compatibility between a VGA monitor and a computer with DVI-D output. System Requirements Features Active Adapter Makes a DVI Video Source Compatible with Your VGA MonitorThis active DVI-D to VGA converter cable makes it possible to send a DVI-D digital signal from your computer or other source device to a VGA analog monitor. Connect the built-in 6-in. (15.24 cm) cable with DVI-D single-link male connector to the DVI port on your video source device. Then, connect a VGA cable, such as a Tripp Lite P502-series VGA cable, from your monitor to the converter. The converter supports VGA cables up to 100-ft. (30.5 m), providing flexibility in device placement. ● A computer with DVI-D output ● A monitor or projector with VGA input Package Includes ● DVI-D to VGA Active Adapter Converter Cable, 6 in. ● USB to USB Micro-B Cable, 3-ft. (0.91 m) ● Quick Start Guide Save Money without Sacrificing Image Quality This DVI-D to VGA active adapter helps you save money by making your current VGA monitor compatible with a computer or other source device equipped with a DVI output. It supports computer video resolutions up to 1920 x 1200 and HD resolutions up to 1920 x 1080 (1080p). Active digital-to-analog circuitry and quality manufacturing ensure a clean, consistent video signal. Simplify Installation with a Plug-and-Play SolutionCompletely plug and play, this DVI-D to VGA active adapter does not require software or drivers. The DVI-D cable is built-in, so the only cable you need to supply is your device's VGA cable. If your application requires power, use the included USB Micro-B cable to connect the converter to a USB port on your monitor or a USB wall outlet. 3-Year WarrantyThe P120-06N-ACT is backed by a 3-year warranty, ensuring reliability and performance. Specifications OVERVIEW UPC Code 037332184832 Technology DVI; VGA/SVGA 1/2 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color Black Cable Jacket Color Black Cable Length (ft.) 0.5 Cable Length (m) 0.15 Cable Length (in.) 6.0 Cable Length (cm) 15.240 Shipping Dimensions (hwd / in.) 5.30 x 4.80 x 1.60 Shipping Dimensions (hwd / cm) 13.46 x 12.19 x 4.06 Shipping Weight (lbs.) 0.40 Shipping Weight (kg) 0.18 CONNECTIONS Side A - Connector 1 DVI-D SINGLE LINK (MALE) Side A - Connector 2 USB A (MALE) Side B - Connector 1 HD15 (FEMALE) STANDARDS & COMPLIANCE Product Compliance Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P120-06N-ACT 价格&库存
很抱歉,暂时无法提供与“P120-06N-ACT”相匹配的价格&库存,您可以联系我们找货
