P136-06N-HDV-4K
P136-06N-HDV-4K
    TRIPPLITE
    DISPLAYPORT
P136-06N-HDV-4K 数据手册
DisplayPort to VGA/DVI/HDMI All-in-One Converter Adapter, DP ver 1.2, 4K 30 Hz HDMI MODEL NUMBER: P136-06N-HDV-4K Highlights ● Separate DVI, HD15 and HDMI female connectors ● HDMI port supports UHD 4K x 2K @ 24/30 Hz video resolutions ● Passive adapter requires connected computer to have DP++ port ● Plug and play—no software, drivers or power supply needed ● Small size for easy carrying in laptop bag or briefcase System Requirements ● The P136-06N-HDV-4K is a Passive adapter, and requires the connected computer to have a DP++ ( Displayport ++ ) port Package Includes ● P136-06N-HDV-4K DisplayPort 1.2 to VGA/DVI/HDMI All-in-One Converter Adapter, 6 in. ● Owner’s manual All-in-one converter/adapter connects your DisplayPort-enabled laptop or tablet to a VGA, DVI or HDMI display without the need to carry separate adapters. Ideal for trade shows, classrooms and lecture halls. Description No more carrying around separate adapters for various monitors, projectors and televisions. The P13606N-HDV-4K DisplayPort 1.2 to VGA/DVI/HDMI All-in-One Converter Adapter connects your laptop or tablet’s DisplayPort to a VGA, DVI or HDMI display. The simple all-in-one solution for displaying content on a larger screen, the P136-06N-HDV-4K is ideal for trade shows, classrooms, lecture halls and other presentations. The all-in-one unit contains separate female DVI, HD15 and HDMI ports. It supports video resolutions up to 1920 x 1080 (DVI); 1920 x 1200, including 1080p (HD15); and 3840 x 2160 (HDMI). It also supports 36bit Deep Color (12 bits per channel). The passive adapter requires the connected computer to have a DP++ (DisplayPort++) port. The P136-06N-HDV-4K is compatible with laptops, tablets and other devices equipped with a female DisplayPort. It’s completely plug-and-play with no software, drivers or external power supply needed. With its small size and built-in cable, the P136-06N-HDV-4K is perfect for stowing in your laptop bag and carrying to school, the office or the latest trade show. Features Connects Your DisplayPort Laptop or Tablet to a VGA, DVI or HDMI Display ● Recommended for trade shows, classrooms, lecture halls and other presentations ● DVI port supports video resolutions up to 1920 x 1080 (1080p) ● HD15 port supports video resolutions up to 1920 x 1200, including 1080p ● HDMI port supports UHD video resolutions up to 3840 x 2160 (4K x 2K) @ 24/30 Hz ● Supports 36-bit Deep Color (12 bits per channel) ● 7.1 Audio Surround Sound only supported by HDMI Plug-and-Play Convenience ● No software, drivers or external power supply required ● Small enough to stow in laptop bag or briefcase ● Passive adapter requires connected computer to have DP++ port 1/2 Specifications OVERVIEW UPC Code 037332190840 Technology DVI; HDMI; VGA/SVGA; DisplayPort PHYSICAL Color Black Shipping Dimensions (hwd / in.) 3.94 x 5.51 x 0.91 Shipping Dimensions (hwd / cm) 10.01 x 14.00 x 2.31 Shipping Weight (lbs.) 0.16 Shipping Weight (kg) 0.07 CONNECTIONS Side A - Connector 1 DISPLAYPORT (MALE) Side B - Connector 1 DVI-D DUAL-LINK (FEMALE) (WIRED TO DVI-D SINGLE-LINK) Side B - Connector 2 HD15 (FEMALE) Side B - Connector 3 HDMI (FEMALE) WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
P136-06N-HDV-4K 价格&库存
很抱歉,暂时无法提供与“P136-06N-HDV-4K”相匹配的价格&库存,您可以联系我们找货
