P137-000-VGA
P137-000-VGA
    TRIPPLITE
    DISPLAYPORT
P137-000-VGA 数据手册
Keyspan Mini DisplayPort 1.2 to Active VGA Adapter, Video Converter for Mac/PC, Thunderbolt 1 & 2 Compatible, 1920x1200 1080p (M/F) MODEL NUMBER: P137-000-VGA Highlights ● Compact 1-piece design ● Connect a VGA monitor to a Mac or PC/Windows with a Mini DisplayPort or Thunderbolt 1/2 output ● Supports computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p ● Ideal for use with graphics cards, such as AMD Eyefinity, that do not output Dual Mode (DP++) signals ● Converts both Single-Mode and Dual Mode (DP++) Displayport output System Requirements ● Mac (up to OSX 10.12) or PC/Windows (up to 10) with a Mini Displayport port; Compatible with Thunderbolt 1 and 2 ports on Mac computers ● Monitor with a VGA port Package Includes Connect a VGA monitor to a Mac or PC with a Mini Displayport output ● Description Tripp Lite's P137-000-VGA Mini-DisplayPort 1.2 to VGA Adapter allows you to connect a Mac or PC with a Mini-DisplayPort or Thunderbolt™ TM output to a VGA monitor. Ideal for Thunderbolt™ /Mini DisplayPort equipped laptops, Chromebooks, MacBooks, and Microsoft Surface. Mac (up to OSX 10.12) and Windows (up to 10) Compatible. Supports computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p. Fully-molded compact one piece design ensures long life enjoyment. Features a simple plug and play design with an integrated chip that converts the digital Mini-DisplayPort signal to analog VGA; no drivers or setup needed. Simply plug the adapter into your Mini-DisplayPort /Thunderbolt™ TM source and connect your VGA cable between it and your monitor. Unlike passive adapters, Active adapters convert both Single-Mode and Dual Mode (DP++) DisplayPort output. Ideal for use with graphics cards, such as AMD Eyefinity, that do not output Dual Mode (DP++) signals. Features ● Compact 1-piece design ● Connect a VGA monitor to a Mac or PC/Windows with a Mini DisplayPort or Thunderbolt 1/2 output ● Displayport 1.2 compliant ● Plug-and-play convenience—no drivers or software needed ● Supports computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p ● Ideal for use with graphics cards, such as AMD Eyefinity, that do not output Dual Mode (DP++) signals ● Converts both Single-Mode and Dual Mode (DP++) Displayport output Specifications OVERVIEW 1/2 Mini-Displayport 1.2 to Active VGA Adapter UPC Code 037332184825 Technology VGA/SVGA; DisplayPort PHYSICAL Color Black Shipping Dimensions (hwd / in.) 1.80 x 3.60 x 5.40 Shipping Dimensions (hwd / cm) 4.57 x 9.14 x 13.72 Shipping Weight (lbs.) 0.20 Shipping Weight (kg) 0.09 CONNECTIONS Side A - Connector 1 MINI DISPLAYPORT (MALE) Side B - Connector 1 HD15 (FEMALE) STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
P137-000-VGA
- 物料型号:P137-000-VGA - 器件简介:该适配器允许将Mac或PC与Mini DisplayPort或Thunderbolt™输出连接到VGA显示器。适用于Thunderbolt™/Mini DisplayPort笔记本电脑、Chromebooks、MacBooks和Microsoft Surface。 - 引脚分配:适配器的一侧为MINI DISPLAYPORT(MALE),另一侧为HD15(FEMALE)。 - 参数特性:支持最高1920 x 1200的计算机视频分辨率和1080p的高清分辨率。采用全模制紧凑的一体式设计,确保了长久的使用寿命。 - 功能详解:即插即用,无需驱动程序或设置。内置芯片将数字Mini DisplayPort信号转换为模拟VGA信号。主动适配器可以转换单模和双模(DP++) DisplayPort输出。 - 应用信息:适用于不输出双模(DP++)信号的显卡,例如AMD Eyefinity。 - 封装信息:黑色,尺寸为1.80x3.60x5.40英寸,重量为0.20磅或0.09公斤。
P137-000-VGA 价格&库存
很抱歉,暂时无法提供与“P137-000-VGA”相匹配的价格&库存,您可以联系我们找货
