U339-000
U339-000
    TRIPPLITE
    USB3.0TOSATAPLUG&PLAY
U339-000 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB 3.0 SuperSpeed to SATA External Hard Drive Docking Station for 2.5in or 3.5in HDD MODEL NUMBER: U339-000 Highlights ● Plug in 2.5" or 3.5" SATA drives for instant external storage ● Plug and Play - no tools, software or configuration required ● Connect via USB 3.0 computer port ● Super Speed USB 3.0 - Up to 5 Gbps transfer speeds ● Compatible with Windows (up to 10) and Mac System Requirements ● 2.5" or 3.5" SATA hard drive ● Computer with an available USB port. USB 3.0 port is required to achieve maximum speeds. ● Compatible with Windows (up to 10) and Mac Package Includes Description Tripp Lite's USB 3.0 SATA Hard Drive Dock gives you a quick and easy way to set up an external hard drive storage system. Plug the docking station into an available USB 3.0 port on your computer, then insert a 2.5" or 3.5" SATA drive for an instant external storage device. Transfer data at SuperSpeed USB 3.0 rates up to 5 Gbps ( provided computer is USB3.0 capable ). Far easier than installing the hard drive internally or in a caddy, the USB3.0/SATA Dock is easy to use, convenient and practical. Backward compatible to older USB 2.0 and 1.1 computers ( 480mbps and 12mbps transfer speeds respectively ). Includes 100-240V AC Adapter, and 4-ft. (1.22 m) USB 3.0 cable. ( No disk drives are included with this unit ) Compatible with Windows (up to 10) and Mac. Features ● Instant SATA external storage for 2.5" and 3.5" SATA drives ● Plug-n-Play (no software or configuring needed) ● USB 3.0 SuperSpeed transfer rates up to 5 Gbps ● Heavy-weighted base for stability ● Compatible with Windows (up to 10) and Mac Specifications OVERVIEW UPC Code 037332175588 Technology SATA/eSATA INPUT Voltage Compatibility (VAC) 100; 110; 120; 127; 200; 208; 220; 230; 240 Bus Powered No 1/3 ● U339-000 USB 3.0 SATA Hard Drive Dock ● USB 3.0 Device Cable ● External Power Supply with NEMA 1-15P Plug (100-240 VAC, 50/60Hz, 0.6A; Output: 12V, 2A) 1000 Eaton Boulevard Cleveland, OH 44122 United States POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.6A External Power Supply Output Specs (V / A) 12V / 2A External Power Supply Cord Length (ft.) 4.9 External Power Supply Cord Length (m.) 1.5 AC Adapter Input: 100-240V, 50/60Hz, 0.6A; Output: 12V, 2A DC Barrel Plug OD: 5.5 x 2.1 x 10mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 24 USER INTERFACE, ALERTS & CONTROLS LED Indicators Red (Power); Blue (Read, Write) PHYSICAL Color Black Material of Construction ABS Shipping Dimensions (hwd / in.) 3.10 x 5.20 x 6.70 Shipping Dimensions (hwd / cm) 7.87 x 13.21 x 17.02 Shipping Weight (lbs.) 1.20 Shipping Weight (kg) 0.54 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 5.8 x 13 x 7.6 Unit Packaging Type Box Unit Weight (lbs.) 0.55 Unit Weight (kg) 0.25 ENVIRONMENTAL Operating Temperature Range 50 to 122 F (10 to 50 C) Storage Temperature Range 32 to 149 F (0 to 65 C) Relative Humidity 10% to 80% RH, Non-Condensing BTUs 81.9 BTU/Hr CONNECTIONS 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Number of Ports 1 Side A - Connector 1 USB 3.0 A (MALE) Side B - Connector 1 22 PIN SATA + POWER (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) Driver Required No UASP Support Yes IP68 Rated No IP20 Rated No STANDARDS & COMPLIANCE External Power Supply Certifications FCC; UL; cUL; RoHS Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U339-000 价格&库存
很抱歉,暂时无法提供与“U339-000”相匹配的价格&库存,您可以联系我们找货
