U336-U03-GB
U336-U03-GB
    TRIPPLITE
    USBCABLE
U336-U03-GB 数据手册
USB 3.0 SuperSpeed to Gigabit Ethernet NIC Network Adapter with 3 Port USB 3.0 Hub MODEL NUMBER: U336-U03-GB Highlights ● Combines a USB 3.0 SuperSpeed 3-Port hub with a Gigabit Ethernet adapter ● Backward compatible with USB 2.0 and 1.1 devices (at USB 2.0 and 1.1 speeds) ● Gigabit Ethernet port supports true 10/100/1000 Mbps network speeds System Requirements ● Available USB port ● Windows® XP, Vista®, 7, 8 , 8.1 and 10 ● Mac® OS X 10.6 through 10.12 ● Linux® Kernel 2.6.14 and later Package Includes Add a Gigabit Ethernet port and 3-port USB 3.0 hub to your computer through one USB 3.0 SuperSpeed port. Description The U336-U03-GB USB 3.0 SuperSpeed to Gigabit Ethernet NIC Network Adapter allows you to turn a single SuperSpeed USB 3.0 computer port into an RJ45 Gigabit network port. It also creates three new additional USB 3.0 hub ports with each port supporting data transfer speeds up to 5 Gbps. This USB 3.0-based NIC lets you connect to your home or office network at full Gigabit speeds with support for 10/100/1000 Mbps. It supports features such as Wake-on-LAN (WoL), VLAN tagging and Jumbo Frames. The U336-U03-GB is backward compatible with USB 2.0 and USB 1.x standards and will support older USB devices. It can also be used with older systems that do not have USB 3.0 ports (network speed limited by USB 1.x/2.0 bus), allowing you to utilize USB 3.0/2.0/1.x devices. Features ● Combines a USB 3.0 SuperSpeed 3-Port hub with a Gigabit Ethernet adapter ● Supports data transfer rates up to 5 Gbps ● Backward compatible with USB 2.0 and 1.1 devices (at USB 2.0 and 1.1 speeds) ● Gigabit Ethernet port supports true 10/100/1000 Mbps network speeds ● IEEE 802.3az (Energy Efficient Ethernet) compliant ● Supports IPv4 and IPv6 pack Checksum Offload Engine (COE) to reduce CPU loading ● Both full-duplex and half-duplex operations are supported ● Supports Wake-on-LAN, Jumbo Frames and VLAN tagging ● RealTek RTL8153 chipset Specifications OVERVIEW 1/3 ● U336-U03-GB ● Quick Start Guide UPC Code 037332182579 Product Type Hub Technology Cat5/5e; Cat6 Host Connector USB A (MALE) VIDEO Number of Monitors Supported 0 Extended Mode No Mirror Mode No DATA Data Ports (3) USB A (FEMALE) Data Ports Details (3) USB-A - USB 3.2 Gen 1 (5 Gbps) NETWORK Network Ports RJ45 (FEMALE) INPUT Built-In Cable Length (ft.) 0.98 Built-In Cable Length (m) 0.30 Built-In Cable Length (in.) 11.81 PHYSICAL Color Silver Shipping Dimensions (hwd / cm) 2.84 x 7.37 x 14.48 Shipping Dimensions (hwd / in.) 1.12 x 2.90 x 5.70 Shipping Weight (kg) 0.10 Shipping Weight (lbs.) 0.22 Unit Dimensions (hwd / in.) 0.84 x 1.2 x 3.8 Unit Dimensions (hwd / cm) 2.14 x 3.04 x 9.6 Unit Weight (lbs.) 0.15 Unit Weight (kg) 0.07 COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit) CONNECTIONS Number of Ports 3 2/3 Side A - Connector 1 USB 3.0 A (MALE) Side B - Connector 1 RJ45 (FEMALE) WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
U336-U03-GB 价格&库存
很抱歉,暂时无法提供与“U336-U03-GB”相匹配的价格&库存,您可以联系我们找货
