U344-001-HDDVI
U344-001-HDDVI
    TRIPPLITE
    USB3.0TODISPLAYPORTVIDADAPT
U344-001-HDDVI 数据手册
USB 3.0 SuperSpeed to DVI and HDMI Dual Monitor Video Display Adapter MODEL NUMBER: U344-001-HDDVI Highlights ● Add an HDMI and DVI monitor to your computer or laptop through a single USB 3.0 port ● Supports video resolutions up to 2048x1152 ● Up to 3 adapters can be connected to a single computer, allowing for the addition of up to 6 displays System Requirements Description Tripp Lite's U344-001-HDDVI USB 3.0 Display Adapter enables the simultaneous connection of a DVI and HDMI display to a computer via a USB 3.0 port. (A VGA monitor can be connected to the DVI-I port with an appropriate DVI to VGA adapter). With this convenient design, it can connect up to 6 displays to a computer without installing extra internal video cards. Once the driver has been installed, the attached monitor(s) will be enabled immediately. The U344-001-HDDVI supports video resolutions up to 2048x1152, and video streaming up to 1080p. Up to three adapters can be connected to a single computer, allowing for up to six displays (see manual for minimum computer requirements). It supports USB 3.0 data transfer rates up to 5Gbps, and is also backward compatible to USB 2.0. It is bus-powered from a computer's USB connection...no external power supply is required. Features ● Add an HDMI and DVI monitor to your computer or laptop through a single USB 3.0 port ● DVI-I port allows for the connection of a VGA monitor using a DVI to VGA adapter ● Supports video resolutions up to 2048x1152 ● Supports video streaming up to 1080p ● Up to 3 adapters can be connected to a single computer, allowing for the addition of up to 6 displays ● Display video in either mirror or extended modes ● Bus-powered, no external power supply required ● USB 3.0 supports data transfer rates up to 5 Gbps ● Backward compatible with USB 2.0 ● Automatically resumes from hibernation and suspend modes Specifications OVERVIEW UPC Code 037332186294 1/3 ● Compatible with Windows 7, Windows 10 and later. Supports both 32- and 64-bit. ● Compatible with Intel Mac OS X 10.8.5 / 10.11 and later. Supports both 32- and 64-bit. ● USB 2.0 or 3.0 port; USB 3.0 port required for USB 3.0 speeds ● VGA, DisplayPort, DVI or HDMI monitor ● See manual for minimum requirements for 1-2, 3, 4-6 monitors ● Compatible with Ubuntu 14.04.2 Package Includes ● U344-001-HDDVI ● Driver CD ● USB 3.0 Cable ● Owner's Manual Technology DVI; HDMI VIDEO Max Supported Video Resolution 2048 x 1152 @60Hz Max Supported Color Depth 24-bit True Color 3D Video Supported No INPUT Voltage Compatibility (VAC) 100; 110; 120; 127; 200; 208; 220; 230; 240 Bus Powered Yes POWER External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5V / 2.5A DC Barrel Plug OD: 3.5 x 1.35 x 9.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators Blue (Power, DVI, HDMI) PHYSICAL Material of Construction ABS Color Black Shipping Dimensions (hwd / cm) 5.59 x 13.97 x 22.35 Shipping Dimensions (hwd / in.) 2.20 x 5.50 x 8.80 Shipping Weight (kg) 0.21 Shipping Weight (lbs.) 0.46 Unit Dimensions (hwd / in.) 0.94 x 5 x 2.6 Unit Packaging Type Box Unit Weight (lbs.) 0.46 Unit Weight (kg) 0.21 ENVIRONMENTAL Operating Temperature Range 32° to 104° F (0°C~40°C) Storage Temperature Range 14° to 176° F (-10° to 80° C) Relative Humidity 0% to 85% RH, Non-Condensing CONNECTIONS 2/3 Number of Ports 2 Side A - Connector 1 USB 3.0 A (MALE) Side B - Connector 1 DVI-I (FEMALE) Side B - Connector 2 HDMI (FEMALE) Side B - Connector 3 3.5mm x 1.35mm (5V DC Barrel) Connector Plating Nickel FEATURES & SPECIFICATIONS HDCP Specification 1.3 USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) Driver Required Yes Full Duplex Support Yes STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
U344-001-HDDVI 价格&库存
很抱歉,暂时无法提供与“U344-001-HDDVI”相匹配的价格&库存,您可以联系我们找货
