USB 3.0 SuperSpeed to Serial ATA (SATA) and
IDE Adapter for 2.5 in. or 3.5 in. Hard Drives
MODEL NUMBER: U338-000
Highlights
SuperSpeed (5 Gbps)/Hi-Speed
(480 Mbps)/Full-Speed (12
Mbps) compliant
SATA III (6 Gbps)/SATA II (3
Gbps)/SATA I (1.5 Gbps)
compliant
Compatible with 2.5/3.5/5.25"
SATA and IDE drives up to 4TB
Includes AI-OTB One Touch
Backup software and button for
one-touch backup
Compatible with Windows and
Mac
System Requirements
Ideal for home or business applications that require a fast, convenient way to transfer files, add external
storage and format hard drives without having to install them.
2.5/3.5/5.25" SATA and/or IDE
drive up to 4TB
Computer with an available USB
port (USB 3.0 port required to
reach maximum speeds)
AI-OTB software compatible
with Windows OS up to 8.1
U338-000 compatible with
Windows and Mac
Description
Tripp Lite's U338-000 USB 3.0 to SATA/IDE Adapter provides individual or simultaneous connection to
either a Serial ATA or IDE drive (2.5/3.5/5.25") to allow you to configure hard drives without having to
install them first. With transfer speeds up to 6 Gbps (w/SATA III), the U338-000 provides a fast,
convenient way to format hard drives or transfer files. You can also transfer data between a SATA and
IDE drive over the adapter. The unit features both 2.5" IDE (44-pin) and 3.5" (40-pin) connections and a
22-Pin SATA Data + Power connector. It works with any SATA and certain IDE drives (see compatibility
list). Windows-compatible AI-OTB One Touch Backup software is included to allow you to quickly backup
and restore files. The U338-000 is compatible with Windows and Mac. Manufactured using top-quality
materials to ensure error-free data transmission and hard drive formatting.
Features
Product Versions and Backup
Software
Package Includes
USB 3.0 A to Micro-B cable, 2.5
ft.
USB 3.0 and below compliant
4-pin Molex power cable, 4 in.
SATA III (6 Gbps) and below compliant
Supports plug-and-play
USB Mass Storage Class Bulk-Only Transport specification
External power supply with
NEMA 1-15P plug and 5 ft. cord
(Input: 100-240V, 50/60Hz,
0.8A; Output: 12V, 2A)
40-pin and 44-pin IDE connectors and a 22-Pin SATA Data + Power connector
Backup software CD
Compatible with 2.5/3.5/5.25" SATA and IDE drives up to 4TB
Owner's manual
Includes AI-OTB One Touch Backup software and button for one-touch backup
Compatible with Windows and Mac
Specifications
OVERVIEW
UPC Code
037332174932
Technology
SATA/eSATA
1/2
POWER
AC Adapter
Input: 100-240V, 50/60Hz, 0.8A; Output: 12V, 2A; 5 ft.
PHYSICAL
Color
Black
Shipping Dimensions (hwd / cm)
7.37 x 13.72 x 11.94
Shipping Dimensions (hwd / in.)
2.90 x 5.40 x 4.70
Shipping Weight (kg)
0.45
Shipping Weight (lbs.)
1.00
CONNECTIONS
Side A - Connector 1
USB 3.0 A (MALE)
Side B - Connector 1
22 PIN SATA + POWER (FEMALE)
Side B - Connector 2
40 POS. SOCKET (FEMALE)
WARRANTY
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“U338-000”相匹配的价格&库存,您可以联系我们找货
