U244-001-VGA-R
U244-001-VGA-R
    TRIPPLITE
    USBTOVGADISPLAYADAPTER
U244-001-VGA-R 数据手册
A CD is no longer included with the U244-001-VGA-R. In order to install the proper drivers, please visit https://www.displaylink.com/downloads. USB 2.0 to VGA Dual-Monitor Adapter, 128 MB SDRAM, 1920 x 1080 (1080p) @ 60 Hz MODEL NUMBER: U244-001-VGA-R Highlights ● Extend video to a second display or duplicate one video on both ● Add up to 6 adapters to connect a total of 7 displays ● No external power supply needed ● Supports HD video resolutions up to 1920 x 1080 (1080p) @ 60 Hz ● Compatible with Windows and Mac computers ● Compatible with Ubuntu 14.04.2 System Requirements Connect a VGA monitor or projector to the USB 2.0 port of your computer or laptop. Use up to 6 adapters to connect up to 6 additional displays to a source. Ideal for multitasking, presentations and editing documents. Description The U244-001-VGA-R USB 2.0 to VGA Dual-Monitor Adapter displays video on a VGA monitor or projector via your computer or laptop’s USB 2.0 port. You can extend video from your primary display to another, duplicate the same video on both displays or change the second display to your primary display. The adapter is an ideal tool for multitasking, viewing large spreadsheets, editing documents, giving presentations at trade shows or watching movies and playing games on large screens. You can add up to six U244-001-VGA-R adapters, each attached to its own USB 2.0 port, to connect a total of seven displays to the video source. Adding or removing a monitor is easy—no need to reboot the system afterward. No external power supply is necessary. First, install the drivers using the included CD. Then, connect the adapter to the display and the source using a VGA cable and the included USB 2.0 cable, respectively. This USB-to-VGA converter supports high-definition video resolutions up to 1920 x 1080 (1080p) at 60 Hz and features 128 MB DDR SDRAM of memory. Compatible with 32- and 64-bit Windows 7 and later, Windows 10, as well as 32- and 64-bit Intel Mac OS X 10.8.3 and later, Mac 10.11. The adapter also works with Surface tablets running Windows 8 Pro or later. Features Easy to Add Displays ● Extend video to a second monitor, duplicate the same video on both monitors, or make the second monitor your primary display ● Ideal for multitasking, viewing spreadsheet data, editing documents, giving presentations, watching movies and playing video games ● Add up to 6 adapters, each connected to its own USB 2.0 port, for a total of 7 displays ● No external power supply necessary ● No need to reboot system after adding or removing a monitor Vibrant, Superior Video Quality 1/3 ● Computer with USB 2.0 port ● VGA monitor ● Windows 7 or later, Windows 10 (32- or 64-bit), Intel Mac OS X 10.8.3 or later, Mac 10.11 (32or 64-bit) or Surface tablet running non-RT Windows 8 or 8.1 Package Includes ● U244-001-VGA-R USB 2.0 to VGA Dual-Monitor Adapter ● USB cable, 3 ft. ● Quick Start Guide ● Driver CD with Owner’s Manual ● Supports high-definition video resolutions up to 1920 x 1080 (1080p) @ 60 Hz ● Features 128 MB DDR SDRAM of memory ● Uses DisplayLink DL-165 chipset ● Resumes automatically from hibernation and suspend modes PC and Mac Compatible ● Works with 32- and 64-bit Windows 7 and later, Windows 10 ● Works with 32- and 64-bit Intel Mac OS X 10.8.3 and later, Mac 10.11 ● Works with Surface tablets running Windows 8 Pro or late Specifications OVERVIEW UPC Code 037332165107 Technology USB 2.0 (High Speed); VGA/SVGA VIDEO Max Supported Video Resolution 1920 x 1080 (1080p) @60Hz INPUT Bus Powered Yes PHYSICAL Material of Construction ABS Color Black Shipping Dimensions (hwd / cm) 21.59 x 15.24 x 5.72 Shipping Dimensions (hwd / in.) 8.50 x 6.00 x 2.25 Shipping Weight (kg) 0.23 Shipping Weight (lbs.) 0.50 Unit Dimensions (hwd / in.) 0.71 x 3.3 x 2.2 Unit Packaging Type Clamshell Unit Weight (lbs.) 0.12 Unit Weight (kg) 0.05 ENVIRONMENTAL Operating Temperature Range 50 to 104 F (10 to 40 C) Storage Temperature Range -4 to 158 F (-20 to 70 C) Relative Humidity 0% to 85% RH, Non-Condensing 2/3 CONNECTIONS Number of Ports 1 Side A - Connector 1 USB A (MALE) Side B - Connector 1 HD15 (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 2.0 (up to 480 Mbps) Driver Required Yes STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
U244-001-VGA-R 价格&库存
很抱歉,暂时无法提供与“U244-001-VGA-R”相匹配的价格&库存,您可以联系我们找货
U244-001-VGA-R
库存:97
