U244-001-VGA
U244-001-VGA
    TRIPPLITE
    USB2.0TOVGADUAL/MULTI-MONITO
U244-001-VGA 数据手册
USB 2.0 to VGA Dual/Multi-Monitor External Video Graphics Card Adapter with Built-In USB Cable, 128 MB SDRAM, 1080p @ 60 Hz Highlights ● Supports HD video resolutions up to 1920 x 1080 (1080p) @ 60 Hz ● Extend video to a second display or duplicate one video on both ● Add up to 6 adapters to connect a total of 7 displays (Windows) ● Plug and play—no external power supply needed ● Compatible with Windows®, Mac® and Ubuntu MODEL NUMBER: U244-001-VGA System Requirements Connect a VGA monitor or projector to the USB 2.0 port of your computer or laptop. Use up to 6 adapters to connect up to 6 additional displays to a source. Ideal for multitasking, presentations and editing documents. ● Computer with USB 2.0 port ● VGA monitor ● Windows 2000 or later (32- or 64-bit), Intel Mac OS X 10.4 or later (32- or 64-bit), Ubuntu 14.04.2 or Surface tablet running non-RT Windows 8 or 8.1 ● Power PC-based Macs not supported Package Includes Description The U244-001-VGA USB 2.0 to VGA External Video Graphics Card Adapter displays video on a VGA monitor or projector via your computer or laptop’s USB 2.0 port. You can extend video from your primary display to another, duplicate the same video on both displays or change the second display to your primary display. This adapter is an ideal tool for multitasking, viewing large spreadsheets, editing documents, giving presentations at trade shows or watching movies and playing games on large screens. You can add up to six U244-001-VGA adapters—each attached to its own USB 2.0 port—to a Windows computer or up to four on a Mac. Adding or removing a monitor is easy—no need to reboot the system afterward. No external power supply is necessary. First, install the drivers using the included CD. Then, connect the adapter to the display and the source using a VGA cable and the built-in USB 2.0 cable, respectively. The U244-001-VGA supports high-definition video resolutions up to 1920 x 1080 (1080p) @ 60 Hz and features 128 MB DDR SDRAM of memory. Compatible with 32- and 64-bit Windows 2000 and later, 32and 64-bit Intel Mac OS X 10.4 and later, and Ubuntu 14.04.2. This adapter also works with Surface™ tablets running Windows 8 Pro or later. Features Easy to Add Displays ● Extend video to a second monitor, duplicate the same video on both monitors or make the second monitor your primary display ● Ideal for multitasking, viewing spreadsheet data, editing documents, giving presentations, watching movies and playing video games ● Add up to 6 adapters for a total of 7 displays (Windows) ● Add up to 4 adapters for a total of 5 displays (Mac) ● No need to reboot system after adding or removing a monitor ● Plug and play—no external power supply needed Vibrant, Superior Video Quality 1/3 ● U244-001-VGA USB 2.0 to VGA External Video Graphics Card Adapter ● Driver CD ● Owner’s manual ● Supports high-definition video resolutions up to 1920 x 1080 (1080p) @ 60 Hz ● Features 128 MB DDR SDRAM of memory ● Resumes automatically from hibernation and suspend modes Broad Compatibility ● Works with 32- and 64-bit Windows 2000 and later ● Works with 32- and 64-bit Intel Mac OS X 10.4 and later ● Works with Surface tablets running Windows 8 Pro or later ● Works with Ubuntu 14.04.2 Specifications OVERVIEW UPC Code 037332196514 Technology USB 2.0 (High Speed); VGA/SVGA VIDEO Max Supported Video Resolution 1920 x 1080 (1080p) @ 60 Hz INPUT Bus Powered Yes Product Length (in.) 7 POWER Power Consumption (Watts) 1.3 PHYSICAL Material of Construction ABS, PVC Color Black Cable Jacket Color Black Cable Jacket Rating VW-1 Shipping Dimensions (hwd / in.) 0.90 x 5.10 x 5.50 Shipping Weight (lbs.) 0.40 Unit Dimensions (hwd / in.) 0.6 x 1.7 x 1.8 Unit Packaging Type Box Unit Weight (lbs.) 0.3 Unit Weight (kg) 0.14 ENVIRONMENTAL 2/3 Operating Temperature Range 32 to 104 F (0 to 40 C) Storage Temperature Range -4 to 140 F (-20 to 60 C) Relative Humidity 10% to 90 % RH, Non-Condensing BTUs 4.4 BTU/Hr CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 HD15 (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 2.0 (up to 480 Mbps) Driver Required Yes STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
U244-001-VGA
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为4x4mm,共有24个引脚。
U244-001-VGA 价格&库存
很抱歉,暂时无法提供与“U244-001-VGA”相匹配的价格&库存,您可以联系我们找货
